  3. Failed to make encryption work on a barebone ATMEGA328P
atmega328prfm69wsecurity
42 Posts 5 Posters 7.4k Views 5 Watching
    I thought the bootloader is overwritten when using ISP? So "you don't need a bootlader" is slightly incorrect, you can not have a bootloader when using isp?
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    #41
    @mfalkvidd The Arduino builder generates two .hex files, one of which contains the bootloader as specified in boards.txt. Depending on the flashing settings you may burn the sketch only or the sketch + bootloader, however, the bootloader is not needed for ISP programming.
    • tekkaT tekka
      @tekka I see. Thanks for explaining.
