  3. Failed to make encryption work on a barebone ATMEGA328P
atmega328prfm69wsecurity
42 Posts 5 Posters 7.4k Views 5 Watching
  • EncryptE
    EncryptE
    Encrypt
    Hello everyone!
    First of all, thank you for building MySensors, it's really an awesome project!
    I had been searching a few months ago for a low-cost (and DIY) alternative to Zigbee / ZWave / Enocean... I'm glad I found it!
    This is my first post here ; I'm currently struggling to make encryption and signing work on a barebone ATMEGA328P, using the internal 8MHz clock.
    First, a bit of context:
    I am working on a project to control my heaters via MySensors and HomeAssistant.
    Basically, the idea is to send a (part) of the mains signal to the heater so that it enters the right mode: Comfort, Eco, Frost protection or Off mode.
    Pilot wire function
    The circuit behind that is really simple to build: a 3.3V power adapter, two optotriacs, two diodes, a microcontroller, a few resistors and a radio basically.
    On the gateway side, HomeAssistant is running on a Raspberry Pi 1 and I attached to that board an RFM69W radio in the "serial gateway" configuration.
    It has been built with the right configuration options: encryption enabled, rmf69w radio defined, etc.
    I also defined a random AES and HMAC key in the configuration file used by the gateway.
    On the "actuator" side if I can say so, I first tested the setup I'm trying to build with an Arduino Uno, another RFM69W, the right level converter between the radio and the Arduino Uno, and finally the controlling circuit.
    I followed the procedure to make signing work: run the SecurityPersonalizer sketch with the keys defined and then uploaded my pilot wire code.
    This first prototype using the Arduino Uno worked well: I could see nonces being exchanged in the debug view of the gateway, the commands sent / received and the state changing on the Arduino side (thanks to diodes). I am now planning to make a second more "realistic" prototype.
    My goal is to produce PCBs with the minimum number of components ; I'll therefore replace the Arduino Uno by an ATMEGA328P with the internal 8MHz clock, two capacitors between (A)Vin and GND, and a resistor near the "not RESET" pin.
    An important note before talking about the issue: I bought the ATMEGAs directly from Microchip (RIP Atmel :P) and the RFM69W radios directly from HopeRF.
    So, these are genuine components! ;)
    Now, the issue:
    I uploaded the SecurityPersonalizer sketch to the ATMEGA328P, made sure it was executed correctly and then I pushed my "pilot wire" sketch.
    For an unknown reason, the node fails to register and I can't see any message on the gateway side.
    Here are the "actuator" logs:
     __  __       ____
            |___/                      2.3.1
    16 MCO:BGN:INIT NODE,CP=RPNNAS-X,REL=255,VER=2.3.1
    63 TSM:INIT
    63 TSF:WUR:MS=0
    67 TSM:INIT:TSP OK
    67 TSM:FPAR
    75 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2390 TSF:MSG:READ,51-180-176,s=199,c=3,t=129,pt=3,l=23,sg=1:0
    2398 !TSF:MSG:LEN=7,EXP=32
    2400 !TSM:FPAR:NO REPLY
    2402 TSM:FPAR
    2410 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4278 TSF:MSG:READ,51-180-176,s=199,c=3,t=129,pt=3,l=23,sg=1:0
    4286 !TSF:MSG:LEN=7,EXP=32
    4419 !TSM:FPAR:NO REPLY
    4421 TSM:FPAR
    4427 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6436 !TSM:FPAR:NO REPLY
    6438 TSM:FPAR
    6445 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8454 !TSM:FPAR:FAIL
    8456 TSM:FAIL:CNT=1
    8458 TSM:FAIL:DIS
    8460 TSF:TDI:TSL
    18462 TSM:FAIL:RE-INIT
    18464 TSM:INIT
    18466 TSM:INIT:TSP OK
    18468 TSM:FPAR
    18477 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20486 !TSM:FPAR:NO REPLY
    20488 TSM:FPAR
    20494 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22503 !TSM:FPAR:NO REPLY
    22505 TSM:FPAR
    22511 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24520 !TSM:FPAR:NO REPLY
    24522 TSM:FPAR
    24528 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26540 !TSM:FPAR:FAIL
    26542 TSM:FAIL:CNT=2
    26544 TSM:FAIL:DIS
    26546 TSF:TDI:TSL
    36550 TSM:FAIL:RE-INIT
    (etc)
    When this problem appeared, I followed the pieces of advice given on this forum: I ran the "clear EEPROM" sketch, re-run the SecurityPersonalizer sketch and re-pushed my pilot wire sketch. Still no luck :(
    I started to believe the problem could be at the hardware level.
    I disabled encryption on the gateway (after rebuilding it) and in my sketch... and the actuator managed to register:
     __  __       ____
            |___/                      2.3.1
    16 MCO:BGN:INIT NODE,CP=RPNNA---,REL=255,VER=2.3.1
    28 TSM:INIT
    28 TSF:WUR:MS=0
    30 TSM:INIT:TSP OK
    32 TSM:FPAR
    38 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    440 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    446 TSF:MSG:FPAR OK,ID=0,D=1
    2048 TSM:FPAR:OK
    2048 TSM:ID
    2050 TSM:ID:REQ
    2066 TSF:MSG:SEND,255-255-0-0,s=2,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2574 TSF:MSG:READ,0-0-255,s=2,c=3,t=4,pt=0,l=1,sg=0:1
    2580 TSF:SID:OK,ID=1
    2584 TSM:ID:OK
    2584 TSM:UPL
    2600 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2820 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2824 TSF:MSG:PONG RECV,HP=1
    2828 TSM:UPL:OK
    2830 TSM:READY:ID=1,PAR=0,DIS=1
    2844 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    3055 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    3080 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
    3602 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    3649 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    3674 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=OK:Fil pilote
    4196 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    4229 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
    4237 MCO:REG:REQ
    4751 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4968 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4974 MCO:PIM:NODE REG=1
    4978 MCO:BGN:STP
    4978 MCO:BGN:INIT OK,TSP=1
    4995 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
    5521 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:2
    589813 TSF:MSG:READ,0-0-1,s=0,c=1,t=3,pt=0,l=1,sg=0:6
    599988 TSF:MSG:READ,0-0-1,s=0,c=1,t=3,pt=0,l=1,sg=0:1
    611840 TSF:MSG:READ,0-0-1,s=0,c=1,t=3,pt=0,l=1,sg=0:3
    I could of course see messages being received / send on the gateway side too.
    To sum up
    Communication is successfully working between an Arduino Uno and the Serial Gateway with encryption + signing enabled but fails to work on a barebone ATMEGA328P.
    Here are a few questions / ideas I have regarding the issue:
    • Could the problem be the bootloader I used to flash the ATMEGA328P? I used the " breadboard-1-6-x.zip" found on the official Arduino website: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard. Maybe the fuses / EEPROM address it set / uses conflicts with what the SecurityPersonalizer sketch does?
    • It seems the encrypted packet is just ignored with encryption enabled since I can't see any logs on the gateway side. I was wondering: are the messages dropped at the radio level or at the software level?
    Thanks in advance for your help!
    Appendix -- Pilot wire code
    // MySensors configuration
    #define MY_RADIO_RFM69
    #define MY_RFM69_NEW_DRIVER
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    #define MY_RFM69_ENABLE_ENCRYPTION
    // Include the libraries
    // Global settings
    #define CHILD_ID 0
    #define INITIAL_MODE 2
    #define MOC_P 3
    #define MOC_N 4
    // Global variables
    bool first_msg_sent = false;
    MyMessage status_msg(CHILD_ID, V_STATUS);
    MyMessage mode_msg(CHILD_ID, V_PERCENTAGE);
    void set_mode(int16_t mode) {
    	digitalWrite(MOC_N, mode & 1);
    	digitalWrite(MOC_P, mode & 2);
    void presentation() {
    	sendSketchInfo("Fil pilote", "1.0");
    	present(CHILD_ID, S_DIMMER);
    	// Make the MOC pins outputs
    	pinMode(MOC_P, OUTPUT);
    	pinMode(MOC_N, OUTPUT);
    	// Set the initial mode (2 = OFF)
    	set_mode(INITIAL_MODE);
    	if (!first_msg_sent) {
    		send(status_msg.set((int16_t) 1));
    		send(mode_msg.set((int16_t) INITIAL_MODE));
    		first_msg_sent = true;
    	if(message.type == V_PERCENTAGE) {
    		set_mode(message.getInt());
    Come have fun with me on IRC: #mysensors on Libera.chat :)
    • EncryptE Encrypt
      Hello everyone!
      Pilot wire function
      Now, the issue:
       __  __       ____
              |___/                      2.3.1
      63 TSM:INIT
      63 TSF:WUR:MS=0
      67 TSM:INIT:TSP OK
      67 TSM:FPAR
      2402 TSM:FPAR
      4421 TSM:FPAR
      6438 TSM:FPAR
      8454 !TSM:FPAR:FAIL
      8456 TSM:FAIL:CNT=1
      8458 TSM:FAIL:DIS
      8460 TSF:TDI:TSL
      18464 TSM:INIT
      18468 TSM:FPAR
      20488 TSM:FPAR
      22505 TSM:FPAR
      24522 TSM:FPAR
      26544 TSM:FAIL:DIS
      26546 TSF:TDI:TSL
      (etc)
       __  __       ____
              |___/                      2.3.1
      28 TSM:INIT
      28 TSF:WUR:MS=0
      30 TSM:INIT:TSP OK
      32 TSM:FPAR
      2048 TSM:FPAR:OK
      2048 TSM:ID
      2050 TSM:ID:REQ
      2584 TSM:ID:OK
      2584 TSM:UPL
      2828 TSM:UPL:OK
      4237 MCO:REG:REQ
      4978 MCO:BGN:STP
      To sum up
      // Global settings
      #define CHILD_ID 0
      #define MOC_P 3
      #define MOC_N 4
      // Global variables
      Nice work @encrypt
      Does the gateway startup CP=... line match the settings for the node?
      • EncryptE
        EncryptE
        Encrypt
        Hello @mfalkvidd, thanks for trying to help me :)
        I've just run the gateway compiled with encryption + signing enabled and here are the logs:
        Apr 20 16:26:01 INFO  Starting gateway...
        Apr 20 16:26:01 INFO  Protocol version - 2.3.1
        Apr 20 16:26:01 DEBUG Serial port /dev/ttyMySensorsGateway (115200 baud) created
        Apr 20 16:26:01 DEBUG MCO:BGN:INIT GW,CP=RPNGLS-X,REL=255,VER=2.3.1
        Apr 20 16:26:01 DEBUG TSF:LRT:OK
        Apr 20 16:26:01 DEBUG TSM:INIT
        Apr 20 16:26:01 DEBUG TSF:WUR:MS=0
        Apr 20 16:26:01 DEBUG TSM:INIT:TSP OK
        Apr 20 16:26:01 DEBUG TSM:INIT:GW MODE
        Apr 20 16:26:01 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
        Apr 20 16:26:01 DEBUG MCO:REG:NOT NEEDED
        Apr 20 16:26:01 DEBUG MCO:BGN:STP
        Apr 20 16:26:01 DEBUG MCO:BGN:INIT OK,TSP=1
        Apr 20 16:26:01 DEBUG TSM:READY:NWD REQ
        Apr 20 16:26:01 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        So I get CP=RPNGLS-X on the gateway side and I got CP=RPNNAS-X previously on the node side.
        Is that correct?
        • EncryptE Encrypt
          Is that correct?
          @encrypt yes they look good
          • EncryptE
            EncryptE
            Encrypt
            I tried again pushing my pilot wire code to the ATMEGA328P with encryption and signing enabled... same issue :(
            I really don't know what is wrong here...
            AnticimexA 1 Reply Last reply
            • EncryptE Encrypt
              AnticimexA
              AnticimexA
              Anticimex
              @encrypt what is your memory utilization?
              • EncryptE
                EncryptE
                Encrypt
                @Anticimex: According to my Arduino 1.8.7 IDE -- with the DEBUG mode, encryption and signign enabled -- the sketch uses 18830 bytes (61%) of program storage space and 953 bytes of dynamic memory.
                Also, for an unknown reason, the SerialGateway stopped working 10 minutes ago when I re-launched the mysgw binary. I now get "!TSM:INIT:TSP FAIL" messages :'(
                • EncryptE Encrypt
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @encrypt hm, usage is not alarmingly high. The only thing that comes to my mind is if your sketch for the bare atmega328p is compiled with the correct frequency specified. Some timing specific code rely on the CPU_FREQ define (note, I am not sure if that name is the correct one) and if that does not reflect the actual clock rate things might not work as expected.
                  • EncryptE
                    EncryptE
                    Encrypt
                    Hmm... I haven't specified the frequency anywhere in a #define...
                    @Anticimex: What should I add in my sketch if that is necessary? (I've posted the code of my sketch in the first post)
                    K AnticimexA 2 Replies Last reply
                    • EncryptE Encrypt
                      K
                      K
                      kimot
                      @encrypt
                      I do not see encryption kye for RFM69 in your code...
                      • EncryptE Encrypt
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @encrypt normally when using the arduino IDE it is automatically added when you pick board variant. F_CPU or something like that.
                        • K kimot
                          @encrypt
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @kimot all security secrets are stored in eeprom or in an atsha204a device. Never in the sketch unless you use the simple security option.
                          Exception being the personalizer sketch for obvious reasons :)
                          • EncryptE
                            EncryptE
                            Encrypt
                            @kimot: I used the SecurityPersonalizer sketch with the keys defined in it.
                            Here is the beginning of the sketch:
                             * @ingroup MySigninggrp
                             * @file SecurityPersonalizer.ino
                             * @brief Security personalization sketch
                             *  - See git log (git log libraries/MySensors/examples/SecurityPersonalizer/SecurityPersonalizer.ino)
                             * @example SecurityPersonalizer.ino
                             * This sketch will personalize either none-volatile memory or ATSHA204A for security functions
                             * available in the MySensors library.<br>
                             * Details on personalization procedure is given in @ref personalization.<br>
                             * This sketch will when executed without modifications also print a guided workflow on the UART.
                            #include "sha204_library.h"
                            #include "sha204_lib_return_codes.h"
                            /** @brief Make use of the MySensors framework without invoking the entire system */
                            #define MY_CORE_ONLY
                            /************************************ User defined key data ***************************************/
                            /** @brief The user-defined HMAC key to use unless @ref GENERATE_HMAC_KEY is set */
                            #define MY_HMAC_KEY 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x01,0x02,0x03,0x04,0x05
                            /** @brief The user-defined AES key to store in EEPROM unless @ref GENERATE_AES_KEY is set */
                            #define MY_AES_KEY 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x01,0x02,0x03,0x04,0x05,0x06,0x07
                            /** @brief The user-defined soft serial to use for soft signing unless @ref GENERATE_SOFT_SERIAL is set */
                            #define MY_SOFT_SERIAL 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
                            /***************************** Flags for guided personalization flow ******************************/
                             * @def GENERATE_KEYS_ATSHA204A
                             * @brief Default settings for generating keys using ATSHA204A
                             * @note The generated keys displayed in the serial log with this setting needs to be written down
                             *       and transferred to all nodes this gateway will communicate with. This is mandatory for ALL
                             *       nodes for encryption (AES key). For signing (HMAC key) it is only required for nodes that
                             *       use signing. Typically you set the values for @ref MY_HMAC_KEY and @ref MY_AES_KEY.
                            //#define GENERATE_KEYS_ATSHA204A
                             * @def GENERATE_KEYS_SOFT
                             * @brief Default settings for generating keys using software
                             * @b Important<br>
                             * You will need to ensure @ref MY_SIGNING_SOFT_RANDOMSEED_PIN is set to an unconnected analog pin
                             * in order to provide entropy to the software RNG if your hardware has no HWRNG.
                            //#define GENERATE_KEYS_SOFT
                             * @def PERSONALIZE_ATSHA204A
                             * @brief Default settings for personalizing an ATSHA204A
                             * It is assumed that you have updated @ref MY_HMAC_KEY and @ref MY_AES_KEY with the keys displayed
                             * when executing this sketch with @ref GENERATE_KEYS_ATSHA204A or @ref GENERATE_KEYS_SOFT defined.
                            //#define PERSONALIZE_ATSHA204A
                             * @def PERSONALIZE_SOFT
                             * @brief Default settings for personalizing EEPROM for software signing
                            #define PERSONALIZE_SOFT
                             * @def PERSONALIZE_SOFT_RANDOM_SERIAL
                             * @brief This is an alternative to @ref PERSONALIZE_SOFT which will also store a randomly generated
                             * serial to EEPROM in addition to the actions performed by @ref PERSONALIZE_SOFT. Take note of the
                             * generated soft serial as it will be needed if you plan to use whitelisting. It should be
                             * unique for each node.
                             * @note This is only needed for targets that lack unique device IDs. The sketch will inform you if
                             *       there is a need for generating a random serial or not. Check the "Hardware security
                             *       peripherals" listing. If a target has a unique device ID and a serial in EEPROM, the serial
                             *       in EEPROM will be used. If erased (replaced with FF:es) the unique device ID will be used
                             *       instead.
                            //#define PERSONALIZE_SOFT_RANDOM_SERIAL
                            /*************************** The settings below are for advanced users ****************************/
                             * @def USE_SOFT_SIGNING
                             * @brief Uncomment this to generate keys by software and store them to EEPROM instead of ATSHA204A
                            //#define USE_SOFT_SIGNING
                             * @def LOCK_ATSHA204A_CONFIGURATION
                             * @brief Uncomment this to enable locking the ATSHA204A configuration zone
                             * It is still possible to change the key, and this also enable random key generation.
                             * @warning BE AWARE THAT THIS PREVENTS ANY FUTURE CONFIGURATION CHANGE TO THE CHIP
                            //#define LOCK_ATSHA204A_CONFIGURATION
                             * @def SKIP_UART_CONFIRMATION
                             * @brief Uncomment this for boards that lack UART
                             * This will disable additional confirmation for actions that are non-reversible.
                             * @b Important<br> For ATSHA204A, no confirmation will be required for locking any zones with this
                             * configuration! Also, if you generate keys on a board without UART, you have no way of determining
                             * what the key is unless it is stored in EEPROM.
                            //#define SKIP_UART_CONFIRMATION
                             * @def GENERATE_HMAC_KEY
                             * @brief Uncomment this to generate a random HMAC key using ATSHA204A or software depending on
                             *        @ref USE_SOFT_SIGNING
                             * @note If not enabled, key defined by @ref MY_HMAC_KEY will be used instead.
                            //#define GENERATE_HMAC_KEY
                             * @def STORE_HMAC_KEY
                             * @brief Uncomment this to store HMAC key to ATSHA204A or EEPROM depending on @ref USE_SOFT_SIGNING
                            //#define STORE_HMAC_KEY
                             * @def GENERATE_AES_KEY
                             * @brief Uncomment this to generate a random AES key using ATSHA204A or software depending on
                             * @note If not enabled, key defined by @ref MY_AES_KEY will be used instead.
                            //#define GENERATE_AES_KEY
                             * @def STORE_AES_KEY
                             * @brief Uncomment this to store AES key to EEPROM
                            //#define STORE_AES_KEY
                             * @def GENERATE_SOFT_SERIAL
                             * @brief Uncomment this to generate a random serial number for software signing
                             * @note If not enabled, serial defined by @ref MY_SOFT_SERIAL will be used instead.
                            #define GENERATE_SOFT_SERIAL
                             * @def STORE_SOFT_SERIAL
                             * @brief Uncomment this to store the serial number to EEPROM
                            //#define STORE_SOFT_SERIAL
                             * @def PRINT_DETAILED_ATSHA204A_CONFIG
                             * @brief Uncomment to print the detailed ATSHA204A configuration
                            //#define PRINT_DETAILED_ATSHA204A_CONFIG
                             * @def RESET_EEPROM_PERSONALIZATION
                             * @brief Uncomment to reset the personalization data in EEPROM to 0xFF:es
                            //#define RESET_EEPROM_PERSONALIZATION
                            /********************* Guided mode flag configurations (don't change these) ***********************/
                            #ifdef GENERATE_KEYS_ATSHA204A
                            #define LOCK_ATSHA204A_CONFIGURATION // We have to lock configuration to enable random number generation
                            #define GENERATE_HMAC_KEY // Generate random HMAC key
                            #define GENERATE_AES_KEY // Generate random AES key
                            #define SKIP_UART_CONFIRMATION // This is an automated mode
                            #ifdef GENERATE_KEYS_SOFT
                            #define USE_SOFT_SIGNING // Use software backend
                            #ifdef PERSONALIZE_ATSHA204A
                            #define STORE_HMAC_KEY // Store the HMAC key
                            #define STORE_AES_KEY // Store the AES key
                            #ifdef PERSONALIZE_SOFT_RANDOM_SERIAL
                            #define GENERATE_SOFT_SERIAL // Generate a soft serial number
                            #define PERSONALIZE_SOFT // Do the rest as PERSONALIZE_SOFT
                            #define STORE_SOFT_SERIAL // Store the soft serial number
                            #if defined(GENERATE_HMAC_KEY) || defined(GENERATE_AES_KEY) || defined(GENERATE_SOFT_SERIAL)
                            #define GENERATE_SOMETHING
                            #if defined(MY_LOCK_MCU)
                            #undefine MY_LOCK_MCU  // The Sketch after SecurityPersonaliter should lock the MCU
                            /********************************** Preprocessor sanitychecks *************************************/
                            Note that the values of MY_HMAC_KEY and MY_AES_KEY in the text above are not the ones I'm currently using.
                            I re-checked that the AES and HMAC keys are indeed the same on the gateway and that's correct.
                            I don't use the MY_SOFT_SERIAL key yet, so I let the sketch generate a random one.
                            @Anticimex: I could indeed see in the file ~/Arduino/hardware/breadboard/avr/boards.txt that atmega328bb.build.f_cpu=8000000L is defined.
                            AnticimexA K 2 Replies Last reply
                            • EncryptE Encrypt
                               * @b Important<br>
                               *       instead.
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @encrypt then I am fresh out of alternatives. Have you tried the verbose flag for signing just to see if it is signing/encryption that is causing the problems? Or try using signing / encryption one at a time.
                              Signing can be set up on a per device/gw basis but encryption has to be configured for all devices (that need to communicate).
                              • EncryptE
                                EncryptE
                                Encrypt
                                I've enabled MY_DEBUG_VERBOSE_SIGNING and MY_DEBUG_VERBOSE_RFM69, here is what I get:
                                 __  __       ____
                                        |___/                      2.3.1
                                40 !SGN:PER:TAMPERED
                                77 SGN:INI:BND OK
                                79 TSM:INIT
                                81 TSF:WUR:MS=0
                                83 RFM69:INIT
                                83 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                90 RFM69:PTX:LEVEL=5 dBm
                                92 TSM:INIT:TSP OK
                                94 TSM:FPAR
                                96 SGN:SGN:NREQ=255
                                98 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                                102 RFM69:CSMA:RSSI=-108
                                108 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                2117 !TSM:FPAR:NO REPLY
                                2119 TSM:FPAR
                                2121 SGN:SGN:NREQ=255
                                2123 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                                2127 RFM69:CSMA:RSSI=-108
                                2136 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                4145 !TSM:FPAR:NO REPLY
                                4147 TSM:FPAR
                                4149 SGN:SGN:NREQ=255
                                4151 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                                4155 RFM69:CSMA:RSSI=-107
                                4163 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                6172 !TSM:FPAR:NO REPLY
                                6174 TSM:FPAR
                                6176 SGN:SGN:NREQ=255
                                6178 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                                6182 RFM69:CSMA:RSSI=-108
                                6191 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                8200 !TSM:FPAR:FAIL
                                8202 TSM:FAIL:CNT=1
                                8204 TSM:FAIL:DIS
                                8206 TSF:TDI:TSL
                                8206 RFM69:RSL
                                I'm wondering: maybe I should try to dump the EEPROM memory to be sure the keys were properly set?
                                Also, regarding my question in the first post, do you know where messages are dropped if the AES key isn't correct? Is it at the radio or software level?
                                • EncryptE Encrypt
                                   * @b Important<br>
                                   *       instead.
                                  K
                                  K
                                  kimot
                                  wrote on last edited by kimot
                                  @encrypt
                                  I am not sure, if we speak about the same AES key.
                                  I mean encryption key for RFM69 chip, because you select using encryption by this radio in your network.
                                  But I am on my mobile only, so it is dificult study source codes Now.
                                  • K kimot
                                    @encrypt
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @kimot AES key is stored in eeprom for all radios. It is fetched and loaded to the radio in runtime. Not compiletime.
                                    • EncryptE Encrypt
                                       __  __       ____
                                              |___/                      2.3.1
                                      77 SGN:INI:BND OK
                                      79 TSM:INIT
                                      81 TSF:WUR:MS=0
                                      83 RFM69:INIT
                                      92 TSM:INIT:TSP OK
                                      94 TSM:FPAR
                                      96 SGN:SGN:NREQ=255
                                      2119 TSM:FPAR
                                      4147 TSM:FPAR
                                      6174 TSM:FPAR
                                      8200 !TSM:FPAR:FAIL
                                      8202 TSM:FAIL:CNT=1
                                      8204 TSM:FAIL:DIS
                                      8206 TSF:TDI:TSL
                                      8206 RFM69:RSL
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @encrypt
                                      The key here is "!SGN:PER:Tampered".
                                      The security backend checks a checksum of the eeprom data used for security. If it is not valid, it considers data tampered and will not use it. So your eeprom has been corrupted one way or another. Or you use either a really old personalizer or a really old library version.
                                      Edit: not old library. And old library would not care about checksum.
                                      • EncryptE
                                        EncryptE
                                        Encrypt
                                        Hello again,
                                        I don't know why I'm getting that "!SGN:PER:Tampered" message...
                                        I've run the SecurityPersonalizer sketch again and it reported that everything went as expected:
                                        |                           MySensors security personalizer                          |
                                        |                               Configuration settings                               |
                                        | * Guided personalization/storage of keys in EEPROM                                 |
                                        | * Software based personalization (no ATSHA204A usage whatsoever)                   |
                                        | * Will not require any UART confirmations                                          |
                                        | * Will store HMAC key to EEPROM                                                    |
                                        | * Will store AES key to EEPROM                                                     |
                                        | * Will generate soft serial using software                                         |
                                        | * Will store soft serial to EEPROM                                                 |
                                        |                           Hardware security peripherals                            |
                                        | Device       | Status       | Revision     | Serial number                | Locked |
                                        | AVR          | DETECTED     | N/A          | N/A (generation required)    | N/A    |
                                        |                                   Key generation                                   |
                                        | Key ID | Status | Key                                                              |
                                        | SERIAL | OK     | 2DFECBDAE05BB8414C                                               |
                                        |                                  Key copy section                                  |
                                        #define MY_SOFT_SERIAL 0x2D,0xFE,0xCB,0xDA,0xE0,0x5B,0xB8,0x41,0x4C
                                        |                                    Key storage                                     |
                                        | HMAC   | OK     | XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX |
                                        | AES    | OK     | XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX                                 |
                                        |                                       EEPROM                                       |
                                        |                      This nodes whitelist entry on other nodes                     |
                                        {.nodeId = <ID of this node>,.serial = {0x2D,0xFE,0xCB,0xDA,0xE0,0x5B,0xB8,0x41,0x4C}}
                                        |                                  WHAT TO DO NEXT?                                  |
                                        | This device has now been personalized. Run this sketch with its current settings   |
                                        | on all the devices in your network that have security enabled.                     |
                                        |                                  Execution result                                  |
                                        | SUCCESS        |
                                        Also, note I'm running the latest version of the SecurityPersonalizer sketch, which can be found here: https://github.com/mysensors/MySensors/blob/development/examples/SecurityPersonalizer/SecurityPersonalizer.ino
                                        I really don't know what can be wrong here...
                                        Could the 8MHz internal clock be the faulty part? Maybe it fails to correctly read the EEPROM data due to a misconfigured clock?
                                        Here is what avrdude shows in the debug view of the Arduino IDE ; using the Arduino Uno as a programmer:
                                        /opt/arduino-1.8.7/hardware/tools/avr/bin/avrdude -C/opt/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyACM0 -b19200 -Uflash:w:/tmp/arduino_build_879921/fil_pilote.ino.hex:i
                                        avrdude: Version 6.3-20171130
                                                 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                                 Copyright (c) 2007-2014 Joerg Wunsch
                                                 System wide configuration file is "/opt/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf"
                                                 User configuration file is "/home/encrypt/.avrduderc"
                                                 User configuration file does not exist or is not a regular file, skipping
                                                 Using Port                    : /dev/ttyACM0
                                                 Using Programmer              : arduino
                                                 Overriding Baud Rate          : 19200
                                                 AVR Part                      : ATmega328P
                                                 Chip Erase delay              : 9000 us
                                                 PAGEL                         : PD7
                                                 BS2                           : PC2
                                                 RESET disposition             : dedicated
                                                 RETRY pulse                   : SCK
                                                 serial program mode           : yes
                                                 parallel program mode         : yes
                                                 Timeout                       : 200
                                                 StabDelay                     : 100
                                                 CmdexeDelay                   : 25
                                                 SyncLoops                     : 32
                                                 ByteDelay                     : 0
                                                 PollIndex                     : 3
                                                 PollValue                     : 0x53
                                                 Memory Detail                 :
        Block Poll               Page                       Polled
                                                   Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                                                   eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                                                   flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                                                   lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                                   hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                                   efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                                   lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                                   calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                                                   signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                                                 Programmer Type : Arduino
                                                 Description     : Arduino
                                                 Hardware Version: 2
                                                 Firmware Version: 1.18
                                                 Topcard         : Unknown
                                                 Vtarget         : 0.0 V
                                                 Varef           : 0.0 V
                                                 Oscillator      : Off
                                                 SCK period      : 0.1 us
                                        avrdude: AVR device initialized and ready to accept instructions
                                        Reading | ################################################## | 100% 0.01s
                                        avrdude: Device signature = 0x1e950f (probably m328p)
                                        avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
                                                 To disable this feature, specify the -D option.
                                        avrdude: erasing chip
                                        avrdude: reading input file "/tmp/arduino_build_879921/fil_pilote.ino.hex"
                                        avrdude: writing flash (21394 bytes):
                                        Writing | ################################################## | 100% 23.60s
                                        avrdude: 21394 bytes of flash written
                                        avrdude: verifying flash memory against /tmp/arduino_build_879921/fil_pilote.ino.hex:
                                        avrdude: load data flash data from input file /tmp/arduino_build_879921/fil_pilote.ino.hex:
                                        avrdude: input file /tmp/arduino_build_879921/fil_pilote.ino.hex contains 21394 bytes
                                        avrdude: reading on-chip flash data:
                                        Reading | ################################################## | 100% 13.37s
                                        avrdude: verifying ...
                                        avrdude: 21394 bytes of flash verified
                                        avrdude done.  Thank you.
                                        • EncryptE Encrypt
                                          Hello again,
                                          |                                   Key generation                                   |
                                          |                                  Key copy section                                  |
                                          |                                    Key storage                                     |
                                          |                                       EEPROM                                       |
                                          |                                  WHAT TO DO NEXT?                                  |
                                          |                                  Execution result                                  |
                                          | SUCCESS        |
                                                   PAGEL                         : PD7
                                                   BS2                           : PC2
                                                   RETRY pulse                   : SCK
                                                   Timeout                       : 200
                                                   StabDelay                     : 100
                                                   CmdexeDelay                   : 25
                                                   SyncLoops                     : 32
                                                   ByteDelay                     : 0
                                                   PollIndex                     : 3
                                                   PollValue                     : 0x53
                                                   Memory Detail                 :
                                                   Hardware Version: 2
                                                   Topcard         : Unknown
                                                   Vtarget         : 0.0 V
                                                   Varef           : 0.0 V
                                                   Oscillator      : Off
                                                   SCK period      : 0.1 us
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @encrypt normally when this happens, it is the main sketch that writes something to eeprom without taking into consideration what parts of the eeprom the MySensors library reserves for internal use.
                                          Could you try to run the personalizer to write the eeprom, then your main sketch, and after that the personalizer again, but this time, configured to not write any data, just print out what is already there?
                                          Sara should be identical but I strongly suspect it will not be (as the main sketch consider data "tampered").
