  3. [SOLVED] NRF24L01 Radio Fails connecting to Gateway
9 Posts 3 Posters 1.9k Views 3 Watching
    mrhutchinsonmn
    I am attempting to set up my first sensor (motion) on Homeassistant but could not see that the gateway was picking up on it, so I enabled debug on Arduino IDE.
    (Both radios are NRF24L01)
    Serial monitor displays the following:
    10040 TSM:FAIL:RE-INIT
    10042 TSM:INIT
    10048 !TSM:INIT:TSP FAIL
    10050 TSM:FAIL:CNT=2
    10052 TSM:FAIL:DIS
    10054 TSF:TDI:TSL
    Serial Monitor on the gateway shows the following:
    0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    0;255;3;0;9;5 TSM:INIT
    0;255;3;0;9;7 TSF:WUR:MS=0
    0;255;3;0;9;14 TSM:INIT:TSP OK
    0;255;3;0;9;17 TSM:INIT:GW MODE
    0;255;3;0;9;20 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;24 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.1
    0;255;3;0;9;28 MCO:BGN:STP
    0;255;3;0;9;34 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;37 TSM:READY:NWD REQ
    Gateway sketch:
    * The ArduinoGateway prints data received from sensors on the serial link.
    * The gateway accepts input on serial which will be sent out on radio network.
    * The GW code is designed for Arduino Nano 328p / 16MHz
    * Wire connections (OPTIONAL):
    * - Inclusion button should be connected between digital pin 3 and GND
    * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
    * - ERR (red) - fast blink on error during transmission error or receive crc error
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    Motion Sensor sketch:
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    // Enable debug prints
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    // Initialize motion message
      sendSketchInfo("Motion Sensor", "1.0");
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    • M mrhutchinsonmn
      10042 TSM:INIT
      10052 TSM:FAIL:DIS
      10054 TSF:TDI:TSL
      0;255;0;0;18;2.3.1
      Gateway sketch:
      * LEDs (OPTIONAL):
      Hi @mrhutchinsonmn, welcome to the MySensors community!
      Init fail means that the Arduino is unable to find the radio.
      If you haven't already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to troubleshoot them efficiently.
      Triple-check the wiring for the radio. If you can, swap the radio for another module. If you can't find anything wrong please post photos of the wiring, it often helps to get a second pair of eyes.
        mrhutchinsonmn
        wrote on last edited by mrhutchinsonmn
        Thank you for your reply. I did resolve the problem and wanted to share what I did, in hopes of helping other newbies.
        Firstly, I double checked the wiring, compared it to the working gateway and it seemed to be fine but still did not work.
        I ran across this post and it turned out to be ideal for my situation:
        https://forum.arduino.cc/index.php?topic=421081.0
        Got the two radios communicating in a simplistic configuration and once working, uploaded mysensors sketches and the radios continued to work correctly. Maybe dismantling and reconnecting was the fix. Not sure, but things are working now. Thank you for a great resource of information and projects!
        mfalkviddM skywatchS 2 Replies Last reply
        • M mrhutchinsonmn
          Great work @mrhutchinsonmn, thanks for reporting back.
          • M mrhutchinsonmn
            skywatchS
            skywatchS
            skywatch
            @mrhutchinsonmn Most likely is those dupont cables - they can easily work loose whilst appearing to be seated. I use an 4x2 socket for the nrf as it holds everything together and takes a lot more force to get it off. There are many options of dupont multiple connectors, I got a selection and I don't regret doing so.
            • skywatchS skywatch
              @skywatch you mean a kit like https://www.aliexpress.com/item/620pcs-DuPont-wire-terminals-pins-connector-18-26awg-2-54mm-0-1-1p-2p-3p-4p/32919257470.html ?
              skywatchS 1 Reply Last reply
                skywatchS
                skywatchS
                skywatch
                @mfalkvidd Yes, that would do the trick but you would also need 2x4 for the 8pins on the radio module if using nrf24l01+ .
                I didn't get the kit as I got them cheaper as separate items so worth looking into that if you want to save a little ;)
                They do help as if one pin is not well crimped and a little loose, the stronger gripping pins will hold the 'block' in place. I've had much fewer issues in dev using these whenever possible. They also prevent the pins rotating as they do with single connectors.
                  @skywatch the kit contains 10------------2x4P
                  For reference (you probably don't need it), here are some videos
                  https://www.youtube.com/watch?v=5CIWxZEt9NE
                  https://www.youtube.com/watch?v=wwSLdJ1uHag
                  https://www.youtube.com/watch?v=Jeg0kS9AcgY
                    skywatchS
                    skywatchS
                    skywatch
                    @mfalkvidd Great stuff - I didn't see the page, just the link title and it wasn't in there (but I was in a rush to take my Mum shopping).
