  3. Hypothetical Project question
15 Posts 4 Posters 2.7k Views 3 Watching
    mrhutchinsonmn
    I am using Home Assistant as a controller, with a serial gateway. My garden irrigation project required I place my garden water pump directly off of my rain barrel, a full 100' away from the garden and water manifold that is controlled by my arduino nano and 12v solenoids. Is it possible to connect the pump to a nano, relay & NRF24L01 and trigger it (via wireless) to power up when a solenoid is activated on the mainifold and power off again when the solenoid turns off?
    mfalkviddM G 2 Replies Last reply
    • skywatchS
      skywatchS
      skywatch
      @mrhutchinsonmn YES! - this is really what automation is all about and mysensors will be a perfect fit for this.
      Have a look at the build page here for relay and irrigation ideas.....
      One node and sensor monitor the solenoid position or power.
      The other node connects to the pump power relay.
      Simple! ;)
      But.....you should also have a sensor to make sure you have enough water in the rain barrel otherwise you risk burning out the pump!
        mrhutchinsonmn
        Very cool! I will dig into things and see if I can figure it out.
        • M mrhutchinsonmn
          @mrhutchinsonmn do you mean that you want to trigger the pump or the Arduino? (”It” is a bit ambigous in your post)
            mrhutchinsonmn
            I need to trigger the relay on/off (via wireless) that is connected to the power of the pump via an arduino nano.
            • M mrhutchinsonmn
              @mrhutchinsonmn thanks for explaining. This project definitely sounds doable.
              • M mrhutchinsonmn
                G
                G
                Grubstake
                @mrhutchinsonmn
                I agree with the previous responses.
                I know you said wireless, but if feasible I would strongly favor 100 feet of direct-burial irrigation cable and a relay for pump, and a hardware float switch, for simplicity and reliability.
                  mrhutchinsonmn
                  I am ready to start dinging around with one sensor state controlling a 2nd sensor, using Home Assistant as the controller but I am not finding what I am looking for. I need the state (on/off) of sensor 1 to signal sensor 2 to turn on/off (turn relays on/off) . I am assuming that will require a script setup on Home Assistant to do this.
                  Just need some examples (sketches) and supporting docs. It was mentioned this could be accomplished with the irrigation project build (which I plan on implementing) but for now, I just want a pinout high on relay-1 to trigger a 2nd relay to also go high (via wireless) .
                  Maybe this question is for Home Assistant? Not sure.
                  • skywatchS
                    skywatchS
                    skywatch
                    A simple test would be to build.....
                    https://www.mysensors.org/build/binary - For the sending node.
                    and...
                    https://www.mysensors.org/build/relay - for the receive end (at the pump).
                    I can't help with HA as I have never used it, but this setup is as good a start as you will get and you'll learn lots tinkering with it! ;)
                      mrhutchinsonmn
                      I decided to look at things from the Home Assistant side and found what I was looking for under "automations". This simple script triggers my relay when motion is detected. Obviously, that would be a bad idea for watering a garden but now I understand how to trigger an action based on the state of a sensor.
                      - id: '1561653332262'
                        alias: New Automation
                        trigger:
                        - entity_id: binary_sensor.relay_motion_105_0
                          platform: state
                        condition:
                        - condition: state
                          state: 'on'
                        action:
                        - service: script.1561137758707
                      Thank you for your assistance!!
                      skywatchS mfalkviddM 2 Replies Last reply
                      • M mrhutchinsonmn
                          trigger:
                            platform: state
                          condition:
                          - condition: state
                            state: 'on'
                          action:
                        skywatchS
                        skywatchS
                        skywatch
                        @mrhutchinsonmn Good work! - let us know how it works in the end if you can.
                        M 1 Reply Last reply
                        • M mrhutchinsonmn
                            trigger:
                              platform: state
                            condition:
                            - condition: state
                              state: 'on'
                            action:
                          @mrhutchinsonmn it might be a good deterrent ;-)
                          • skywatchS skywatch
                            mrhutchinsonmn
                            @skywatch What fun!! I figured out how to turn the pump relay on and off, based on the state of the water solenoid relay. This automation.yaml script works :
                            - id: '1562092064918'
                              alias: Relay UP
                              trigger:
                              - entity_id: switch.relay_4_2
                                platform: state
                                to: 'on'
                              condition:
                              - condition: state
                                state: 'on'
                              - condition: state
                                entity_id: switch.relay_2_1
                                state: 'off'
                              action:
                              - alias: ''
                                data: {}
                                service: switch.turn_on
                            - id: '1562093186484'
                              alias: Relay Down
                              trigger:
                                platform: state
                                to: 'off'
                              condition:
                              - condition: state
                                state: 'on'
                              action:
                              - service: switch.turn_off```
                            skywatchS 1 Reply Last reply
                            • M mrhutchinsonmn
                                alias: Relay UP
                                trigger:
                                  platform: state
                                  to: 'on'
                                condition:
                                - condition: state
                                  state: 'on'
                                - condition: state
                                  state: 'off'
                                action:
                                - alias: ''
                                  data: {}
                                alias: Relay Down
                                trigger:
                                  platform: state
                                  to: 'off'
                                condition:
                                - condition: state
                                  state: 'on'
                                action:
                              skywatchS
                              skywatchS
                              skywatch
                              @mrhutchinsonmn YAY! - What fun indeed! - I am happy that you have made such good progress - now I am sure you'll be thinking of more things you can do ;)
                                mrhutchinsonmn
                                This script will be more helpful for beginners. The previous script turns on/off all relays. This one controls only the specified relay.
                                  alias: Power Up Relay_2.1
                                  trigger:
                                    platform: state
                                    to: 'on'
                                  condition: []
                                  action:
                                  - alias: ''
                                    data:
                                  alias: Power Down Relay_2.1
                                  trigger:
                                    platform: state
                                    to: 'off'
                                  condition: []
                                  action:
                                  - data:
