  3. [Solved]ProMini Will Not Sleep/ Enter Low Power Mode - what is best avr sleep or smartsleep?
8 Posts 4 Posters 1.8k Views 4 Watching
  • GardenShedDevG
    GardenShedDevG
    GardenShedDev
    wrote on last edited by GardenShedDev
    I have created a very simple 4 button battery powered scene controller using a promini, an nrf24, 4 button membrane keypad and 2xAAA.
    On intial run the device regeisters itself then after a short period it goes to sleep and stays asleep until a button ispressed. I use interupts on PCINT1 (4 pins) to wake up the device and transmit the subsequent scene ID which works really well - however- after 3 weeks of use the batterys died and then I realised that the promini wasnt actaully going to sleep which means not powering down.
    When transmitting the device consumes 18mA, in 'so called' sleep mode it consumes 14mA.
    I suspect that I am not putting the promini to sleep correctly within the MySensors framework - I have put an extract of my sketch below - can someone check the sleep mode calls and let me know if im doing something wrong?
    Thx
    Sleep Routine:
        if((millis() - StartTime) >= SleepWaitTime)   // Wait for some time before going to sleep
            Serial.println("Sleeping....");
            delay(10);
            cli();                                    //disable interrupts
            sleep_enable ();                          // enables the sleep bit in the mcucr register
            set_sleep_mode (SLEEP_MODE_PWR_DOWN);     // set sleep mode
            ADCSRA = 0;                               //disable the ADC
            sleep_bod_disable();                      //save power
            sei();                                    //enable interrupts
            sleep_mode ();                            // goto sleep
            sleep_disable ();                         // first thing after waking from sleep:
            StartTime = millis();
            Serial.println("Awake...");
            int battery_read;                          // call function - Send the battery status
            battery_read = SendBattery();
    Main sketch:
    #define MY_DEBUG true                                     // Enable debug prints
    #define MY_RADIO_NRF24                                    // Enable and select radio type attached
    #define MY_NODE_ID 7                                      // >>>>>>>>Set the node ID manually - this must be set the mysensors.h call<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    #include <OneButton.h>                                    // https://github.com/mathertel/OneButton
    #include <avr/sleep.h>
    #define MIN_V 1.9                                         // Minimum Battery Voltage
    #define MAX_V 3.1                                         // Max Battery Voltage
    #define CHILD_ID_BUTTON1 1
    #define CHILD_ID_BUTTON2 2
    #define CHILD_ID_BUTTON3 3
    #define CHILD_ID_BUTTON4 4
    #define CHILD_ID_BATTERY 5
    #define CHILD_ID_ADC 6
    #define SN "Scene Controller"
    #define SV "0.4"
    OneButton button4(A1, true);                              // Setup a new OneButton on pin A1.
    OneButton button1(A2, true);                              // Setup a new OneButton on pin A2.
    OneButton button3(A0, true);                              // Setup a new OneButton on pin A0.
    OneButton button2(A3, true);                              // Setup a new OneButton on pin A3.
    int SendDelay = 500;                                      // Time to wait before sending data over the radio
    int BATTERY_SENSE_PIN = A5;                               // Define battery sense pins
    int oldBatteryPcnt = 0;
    //int batteryCounter = BATTERY_REPORT_CYCLE -1;             // counter for battery update
    //int reportCounter = FORCE_TRANSMIT_CYCLE -1;              // counter for the loop and forcing updates
    unsigned long StartTime = 10000;
    unsigned long SleepWaitTime = 10000;                      // 10 seconds
    int MessageA = 0;                                         // Button Message Values 0- no value
    int MessageB = 1;                                         // up
    int MessageC = 2;                                         // down
    int MessageD = 3;                                         // toggle on/off
    MyMessage msgButton1(CHILD_ID_BUTTON1, V_SCENE_ON);
    MyMessage msgButton2(CHILD_ID_BUTTON2, V_SCENE_ON);
    MyMessage msgButton3(CHILD_ID_BUTTON3, V_SCENE_ON);
    MyMessage msgButton4(CHILD_ID_BUTTON4, V_SCENE_ON);
    MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
    MyMessage msgADCValue(CHILD_ID_ADC, V_VOLTAGE);
    #                   Presentaion                    #
        sendSketchInfo(SN, SV); wait(SendDelay);                                    // Send the sketch version information to the gateway
        present(CHILD_ID_BUTTON1, S_SCENE_CONTROLLER); wait(SendDelay);             // Register all sensors to gw (they will be created as child devices)
        present(CHILD_ID_BUTTON2, S_SCENE_CONTROLLER); wait(SendDelay);
        present(CHILD_ID_BUTTON3, S_SCENE_CONTROLLER); wait(SendDelay);
        present(CHILD_ID_BUTTON4, S_SCENE_CONTROLLER); wait(SendDelay);
        present(CHILD_ID_BATTERY, S_MULTIMETER); wait(SendDelay);
        present(CHILD_ID_ADC, S_MULTIMETER); wait(SendDelay);
      //  metric = getControllerConfig().isMetric;
    #           Interupt Service Routine               #
    ISR (PCINT1_vect)                             // handle pin change interrupt for A0 to A5 here
         //Serial.println("--**-INTERRUPT-**--"); //debug
    #                     Void Setup                   #
          analogReference(INTERNAL);
          Serial.begin(115200);                           // Setup the Serial port. see http://arduino.cc/en/Serial/IfSerial
          Serial.println("Starting..."); delay(10);
                                                          // Setup Interrupts
          PCMSK1 |= bit (PCINT8);                         // enable pin A0
          PCMSK1 |= bit (PCINT9);                         // enable pin A1
          PCMSK1 |= bit (PCINT10);                        // enable pin A2
          PCMSK1 |= bit (PCINT11);                        // enable pin A3
          PCIFR  |= bit (PCIF1);                          // clear any outstanding interrupts
          PCICR  |= bit (PCIE1);                          // enable pin change interrupts for A0 to A5
          button1.attachClick(click1);                    // Button 1 functions.
          button1.attachDoubleClick(doubleclick1);
          button1.attachLongPressStop(longPressStop1);
          button2.attachClick(click2);                    // Button 2 functions.
          button2.attachDoubleClick(doubleclick2);
          button2.attachLongPressStop(longPressStop2);
          button3.attachClick(click3);                    // Button 3 functions.
          button3.attachDoubleClick(doubleclick3);
          button3.attachLongPressStop(longPressStop3);
          button4.attachClick(click4);                    // Button 4 functions.
          button4.attachDoubleClick(doubleclick4);
          button4.attachLongPressStop(longPressStop4);
    #                 Void Loop                        #
            delay(10);
        button1.tick();                               // Watch the push buttons:
        button2.tick();
        button3.tick();
        button4.tick();
        delay(10);
    YveauxY 1 Reply Last reply
    • GardenShedDevG GardenShedDev
      Thx
      Sleep Routine:
              delay(10);
      Main sketch:
      #define SV "0.4"
      #                   Presentaion                    #
      #                     Void Setup                   #
                                                            // Setup Interrupts
      #                 Void Loop                        #
              delay(10);
          button2.tick();
          button3.tick();
          button4.tick();
          delay(10);
      YveauxY
      YveauxY
      @gardensheddev If you use either pin 2 or 3 you can use the MySensors sleep() method to handle all the sleeping -- so much easier.
      • GardenShedDevG
        GardenShedDevG
        GardenShedDev
        Thank you for the reply
        I am using 4 pins/ switches that I need to monitor
        Is it possible to use PCINT1 for the interupt definition (pin change) when using the mysensors sleep() method or does it have to be definined as pin 2 and 3 only?
        update: answering my own question no its not possible - while a sketch compiles using the PCINT1 it does not wake up the device
        • electrikE
          electrikE
          electrik
          Check this for an example
          https://github.com/rikki78/MySensors/blob/master/WallRemote/WallRemote.ino
          GardenShedDevG 1 Reply Last reply
          • electrikE electrik
            GardenShedDevG
            GardenShedDevG
            GardenShedDev
            @electrik I assume the example if for an earlier version of MySensors 1.x - is this method still valid for 2.x onwards?
            • electrikE
              electrikE
              electrik
              Hmm is it that old already 🤔
              The sketch uses a different library for the sleep functions, if I remember correctly. So if you use this sketch you should port the mysensors part to 2.x, otherwise just use the sleep functions in your own sketch.
              Hope it helps
                zboblamontZ
                zboblamontZ
                zboblamont
                @gardensheddev Perhaps you might clarify how your pro-mini has been modified and that it has been modified for low voltage operation?
                Even a 3.3v pro-mini with power LED and regulator removed should be <5mA active ( minus effects of active radio of course) and <5 nA asleep.
                I second @Yveaux's observation MySensors Sleep is way easier to implement.
                For multiple inputs on either pin 2 or 3, I'm certain somebody did this here already using a resistor matrix, an analogue pin and an Interrupt pin.
                The principle was the promini is wakened from Sleep on pin 2 or 3, and the voltage read on the analogue pin determines which button was pressed.
                Perhaps worth considering? ;)
                • GardenShedDevG
                  GardenShedDevG
                  GardenShedDev
                  ok, so I figured it out... and just recording my observatios and fix in the hope it helps others or me if I forget :)
                  @yveaux and @zboblamont said to use the MyS sleep() function which can handle interupts on pins 2 & 3. For me this is too limitiing as I am using 4 pins.
                  What I needed was something simple for a rapid build. When I intially built the node a month ago I read up on the MyS sleep function, realised that it couldnt handle more than 2 pins for interupts and opted to go down the route of interupts as laid out on www.gammon.com.au. After a little more reading I then implemented the AVR sleep function, so far so good or so I thought - move fwd to my problem. While everything was working well:
                  • scene controller HW built - check,
                  • Software created - check,
                  • Enclosure printed - check,
                  • hooked up to home assitant - check,
                  • WAF (very important) - check,
                  ...the node wasnt actaully sleeping DOH!
                  Upto this point I had spent less than 6 hours in dev and implementation time....
                  So heres the problem, after a lot of reading over the last 36 hours I found a post that states MyS library only implements interupts for pins 2&3 on the pro mini - it doesnt implement interupt groups such as PCINT1 (A0-A5) etc AND the node cannot be woken up via interupt if it is not done via pins 2&3.
                  @electrik posted a link to his excellent sketch that hacks the core code a little - as I was looking into this method I stumbled on a post by @freynder that implements a 'dirty hack' here which forces the node to wake up on interupt when using the MyS sleep() function. This then led me to a post on a 6/8 button controller here. These two posts have be pivotal in fixing my problem. Thank you @electrik for triggering the thought process that lead to a simple solution :)
                  @yveaux and @zboblamont you where both correct I need to use the MyS sleep() function which I have now implemented alongside the external interupt library form the 6/8 button controller link and the added the two lines of code as per the 'dirty hack'
                  My node now reads 18mA when active (transmitting) and when sleeping it is less than 0.5mA - which is the limitation of my equipment!
                  @zboblamont to answer your Q about node setup, I have a pro mini and with both the power led and regulator removed as per the MySensors hack for battery nodes - however the transmit led is still connected which will draw extra current when transmitting, which I am ok with for the moment lol
                  thank you to all that have contributed !!
                  heres the schematic of the controller:
                  and an updated extract of the code
                  #define EI_NOTEXTERNAL                                    // External interrupts managed by built-in routines
                  #include <EnableInterrupt.h>                              // Pin-change interrupts
                  #define SV "0.4"
                  #define BUTTON4 A1                                        // Interput pin and button definitions
                  #define BUTTON1 A2
                  #define BUTTON3 A0
                  #define BUTTON2 A3
                  OneButton button4(BUTTON4, true);                         // Setup a new OneButton on pin A1.
                  OneButton button1(BUTTON1, true);                         // Setup a new OneButton on pin A2.
                  OneButton button3(BUTTON3, true);                         // Setup a new OneButton on pin A0.
                  OneButton button2(BUTTON2, true);                         // Setup a new OneButton on pin A3.
                  unsigned long StartTime = 0;                              // sleep startime variable
                  unsigned long SleepWaitTime = 10000;                      // Time to wait before going to sleep 10 seconds
                  unsigned long Sleep_Time = 86400000;                      // 86400000 Sleep for 24 hours
                  #                   Presentaion                    #
                  #                     Void Setup                   #
                        enableInterrupt(BUTTON1,Int_vect,CHANGE);
                        enableInterrupt(BUTTON2,Int_vect,CHANGE);
                        enableInterrupt(BUTTON3,Int_vect,CHANGE);
                        enableInterrupt(BUTTON4,Int_vect,CHANGE);
                  #                 Void Loop                        #
                          delay(10);
                          sleep(Sleep_Time);                            // Sleepy Time :)
                          // WAKE UP HERE
                          _wokeUpByInterrupt = INVALID_INTERRUPT_NUM;   //dirty hack wake up routine - clear interupt
                      button1.tick();                                   // Check the push buttons:
                      button2.tick();
                      button3.tick();
                      button4.tick();
                      delay(10);
                  void Int_vect()                                   // handle pin change interrupt for A0 to A5 here
                       _wokeUpByInterrupt = 0xFE;                     // Dirty hack to get out of MySensors sleep loop
