  3. Node-RED
  4. [Solved] problems trying to save on two measurements
Scheduled Pinned Locked Moved Node-RED
2 Posts 1 Posters 950 Views 1 Watching
  • Sergio RiusS
    Sergio RiusS
    Sergio Rius
    wrote on last edited by Sergio Rius
    I'm trying to save the sensor data received from mqtt into two different measurements, if they are internal network messages, I want them in "internal" and all the sensor values into "values"
    For that I tried using a switch module checking the "sensor" attribute being 255, but I can't make it save on the internal "table"
    To my confussion, the switch seems to work, as I put debug nodes on the output (1, 2) and it keeps printing 1 or 2 correctly depending on the message.
    But from the two DB/measurement connections that hangs on it only executes the second one. Nothing is written into "internal", although the debug is hit and also the measurement has received the series :scream: :
    key
    internal,node=0,sensor=255,subType=I_HEARTBEAT_RESPONSE
    internal,node=1,sensor=255,subType=I_DISCOVER_RESPONSE
    values,node=1,sensor=1,subType=V_KWH
    values,node=1,sensor=1,subType=V_VAR1
    values,node=1,sensor=1,subType=V_WATT
    values,node=1,sensor=2,subType=V_WATT
    values,node=1,sensor=3,subType=V_WATT
    values,node=1,sensor=4,subType=V_WATT
    Can someone give me a clue of what is happening? I'm newb with node-red and influxdb.
    • Sergio RiusS
      Sergio RiusS
      Sergio Rius
      Seems that the problem was that influxdb always configures the field type the first time a series is accessed.
      I thought that the value was something like a "variant" and would eat anything I throw at it. So when I altered the data types in the flow, the db refused to save.
      A drop and re create solved the problem.
