  3. Help sending payload with more decimal places
5 Posts 3 Posters 2.8k Views 1 Watching
  • T
    therik
    Hey guys,
    Just wondering if someone would be so kind as to help me figure out how to use setters to send a payload with more decimal places than the standard custom variable.
    I saw that perhaps I could construct the msg "on the fly", but I don't know the proper syntax to get that accomplished. Even easier, I would simply like to send a custom variable with two decimal places (or however many one should like). Right now the default is a single decimal place as I gather from the data that is being sent currently.
    In the plainest terms, I would like to send the battery voltage in a format X.XX using a custom variable, but using the standard custom variable constructor the payload is X.X.
    Thanks for your help.
    • E
      E
      ericvdb
      multiply your float with 100 or 1000 before sending and divide again on the receiving end.
        the second argument to the MyMessage.set-method is the number of decimals.
        • T
          therik
          @hek okay, I guess I was being stupid....
          With this msg constructor...
          MyMessage msgVolt(CHILD_ID_VOLT, V_VAR1);
          With this type def...
           float batteryV  = sensorValue * 0.003363075;
          I had the following thinking that I had turned on auto ack...
            gw.send(msgVolt.set(batteryV, 1));
          but that sets the decimal places to "1". So, if I want to set the decimal places to "2" and enable auto ack it would look like this...?
            gw.send(msgVolt.set(batteryV, 2),1);
          Thanks again.
          hekH 1 Reply Last reply
          • T therik
            Thanks again.
            Yes, this is correct.
