  3. Crazy timer on my sketch
7 Posts 2 Posters 1.2k Views 2 Watching
  • TmasterT
    TmasterT
    Tmaster
    hello . i'm finishing an second version from my water irrigation(1 valve control) and i have an issue with one of the timers that i can't understand.
    its set for 1 hour,but never reach 1 hour, sometimes 47minutes ,other times 5 minutes.... annoying.
    Can anyone understand this ? i'm too limited on programming :s
    this is the crazy timer that i talk about:
    this timer close the valv after 3600second(1hour) but won't work..
      unsigned long nowMillis = millis();
       if ((timer==true) && (nowMillis - startMillis >= VALVE_TIME))
          startMillis =  nowMillis ;
           VALV1_OFF();
           timer==false;
    full code:
    // Set blinking period (in milliseconds)
    #define MY_DEFAULT_LED_BLINK_PERIOD 500
    #define MY_WITH_LEDS_BLINKING_INVERSE
    //#define MY_DEFAULT_ERR_LED_PIN 17
    #define MY_DEFAULT_TX_LED_PIN 17
    #define MY_DEFAULT_RX_LED_PIN 17
    //#define MY_DEBUG
    #define MY_RADIO_RFM69
    //#define MY_REPEATER_FEATURE
    #include <TimeLib.h>
    #include <OneWire.h>
    #define ONE_WIRE_BUS 6
    OneWire oneWire(ONE_WIRE_BUS);
    //#define CHILD_ID_MOISTURE 4
    #define CHILD_ID_TEMP 21
    #define CHILD_ID_VALV1 10
    //#define CHILD_ID_VALV2 11
    #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay  VALV 1
    #define RELAY_PIN2  5  // Arduino Digital I/O pin number for relay VALV 2
    #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
    #define LEDR1   16  // LED A2 pin
    #define LEDR2  15// LED A1 pin
    //#define LEDERRO 17  // LED A3  pin
    #define VALVE_TIME 3600000UL    //selenoid 1 goes off after () time  (7200000UL)-2HOUR
    #define readtime 1800000UL  //time between read TEMPERATURE (3600000UL) - 1HOUR
    //xxxxxxxxxxxxxxxxxxxxxxxxxxxxx |SET TIME HERE|     - valve1-  xxxxxxxxxxxxxxxxxxxxxxxx |
    //TIME1
    const int H1 = 17; //HOURS START PROGRAM     //time to start  selenoid1                 |
    const int M1 = 00; //MINUTES START PROGRAM                                              |
    //TIME2
    const int H2 = 8; //HOURS START PROGRAM     //time to start  selenoid1                 |
    const int M2 = 00; //MINUTES START PROGRAM
    //----------------------------------------valve2--------------------------------------- |
    unsigned long startMillis = 0;
    unsigned long startMillisA = 0;
    int reading;// the current reading from the input pin
    bool RH = false;
    int previous = LOW;
    int timer = false;
    bool timeReceived = false;
    unsigned long  lastRequest=0;
    MyMessage msg1(CHILD_ID_TEMP,V_TEMP);
    MyMessage msg2(CHILD_ID_VALV1,V_LIGHT);
    bool state;
    void before()
      sensors.begin();  //DS18B20 LIBRARY START
    //request time from gw
       requestTime(receiveTime);
      // Setup the button
       pinMode(BUTTON_PIN,INPUT);
       pinMode(RELAY_PIN, OUTPUT);
       pinMode(RELAY_PIN2, OUTPUT);
       pinMode(LEDR1, OUTPUT);
       pinMode(LEDR2, OUTPUT);
      digitalWrite(RELAY_PIN,LOW);
      sendSketchInfo("irrigation_temp_soilMoisture", "2.0");
      present(CHILD_ID_VALV1, S_LIGHT);
    void receiveTime(unsigned long time)
      // Ok, set incoming time
      setTime(time);
      timeReceived = true;
    Serial.print("Time now is: ");
      Serial.print(hour());
      Serial.print(":");
      Serial.print(minute());
      Serial.print(":");
      Serial.print(second());
     void VALV1_ON()
         analogWrite(RELAY_PIN,255);
         delay(400);
         analogWrite(RELAY_PIN,90);
         digitalWrite(LEDR1,HIGH);
         send(msg2.set(true),false);
    void VALV1_OFF()
          analogWrite(RELAY_PIN,LOW);
          digitalWrite(LEDR1,LOW);
          send(msg2.set(false),false);
    //#########################################################################################################3
    // ✓ ORDER RECEIVED FROM GW  #   ORDER RECEIVED FROM GW  #  ORDER RECEIVED FROM GW  ORDER RECEIVED FROM GW  ORDER RECEIVED FROM GW ✓
      if (message.isAck()) {
        // Serial.println("This is an ack from gateway");
         // Change relay state
         state = message.getBool();
          if (state == 1)
            VALV1_ON();
        else if (state == 0)
          VALV1_OFF();
    void loop() //loop    loop         loop        loop        loop        loop        loop        loop        loop        loop        loop
       unsigned long nows = millis();
       // If no time has been received yet, request it every 10 second from controller
      // When time has been received, request update every 12h
      if ((!timeReceived && (nows-lastRequest) > (10UL*1000UL))
        || (timeReceived && (nows-lastRequest) > (43200000UL)))
        // Request time from controller.
     //   Serial.println("requesting time");
        lastRequest = nows;
       //       toogle  switch   toogle  switch   toogle  switch   toogle  switch   toogle  switch
    //toogle  switch----------selenoid 1-------------------------------
     reading = digitalRead(BUTTON_PIN);
       if (reading == HIGH && RH == false)
           VALV1_ON();
          RH = true;
          timer = true;
           delay(400);
      else if(reading == HIGH &&RH == true)
        VALV1_OFF();
        RH = false;
        timer==false;
        delay(400);
    // ✓ time out ✓
           VALV1_OFF();
           timer==false;
      //✓ ON by time ✓
      if ((hour() == H1 && minute() == M1) ||(hour() == H2 && minute() == M2)  )
         VALV1_ON();
         timer = true;
    //✓ time to send temperature ? ✓
     float temperature =sensors.getTempCByIndex(0);
    unsigned long nowMillisA = millis();
        if (nowMillisA - startMillisA >= readtime)
    //✓ read temperature  sensors ✓
         send(msg1.set(temperature,1));  //send  temp to gw
         startMillisA =  nowMillisA ;  //reset time
    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
    • TmasterT Tmaster
             VALV1_OFF();
             timer==false;
      full code:
      //#define MY_DEBUG
      //TIME1
      //TIME2
      bool RH = false;
      int previous = LOW;
      int timer = false;
      bool state;
      void before()
        // Setup the button
        setTime(time);
        Serial.print(":");
        Serial.print(":");
       void VALV1_ON()
           delay(400);
      void VALV1_OFF()
            if (state == 1)
              VALV1_ON();
            VALV1_OFF();
          lastRequest = nows;
             VALV1_ON();
            RH = true;
            timer = true;
             delay(400);
          VALV1_OFF();
          RH = false;
          timer==false;
          delay(400);
      // ✓ time out ✓
             VALV1_OFF();
             timer==false;
        //✓ ON by time ✓
           VALV1_ON();
           timer = true;
      @tmaster the debug log will probably give good insight to why the node reacts early.
      If you use the auto-formatting feature in the Arduino IDE, it will be much easier to follow the code.
      • TmasterT
        TmasterT
        Tmaster
        wrote on last edited by Tmaster
        @mfalkvidd said in Crazy timer on my sketch:
        i just discovered the auto-formatting right now :)
        About debug (mydebug) just reacts as normal,everything as should, but in shorter time... less 70-80% of the time most the times. Tomorrow i will get the arduino that its watering right know and change the code a bit..try some "while" instead of "if" or hammering it ;)
        • TmasterT Tmaster
          @tmaster the sketch has a few
          timer==false;
          that probably should be
          timer=false;
          TmasterT 1 Reply Last reply
          • TmasterT
            TmasterT
            Tmaster
            Nice catch! i didn´t see that . thank you
              timer==false;
              timer=false;
              TmasterT
              TmasterT
              Tmaster
              @mfalkvidd that was the problem! I correct the code and timers are working perfect now. I will post the skematic and code this night on projects for if someone want to use it . Very handy on summer for water some vegetables like i do. It's a very simple build.
              • TmasterT Tmaster
                @tmaster great work!
