  3. NodeManager
  4. is mesh n/w possible using RFM69 without using gateway?
10 Posts 5 Posters 2.1k Views 3 Watching
  • abtA Offline
    abtA Offline
    abt
    I am new to RFM69. I want to make a mesh network using RFM69 and Arduino. Is it possible to make this without using a gateway? Help me in the programming of this.
    • abtA abt
      Hi @abt, welcome to the MySensors community.
      MySensors uses a tree topology, so it won't give you a mesh network.
      All MySensors networks need a gateway.
      But it may very well be that MySensors can handle your use case. Would you mind sharing what you want to do?
      abtA 3 Replies Last reply
        abtA Offline
        abtA Offline
        abt
        wrote on last edited by abt
        @mfalkvidd
        Thanks for the reply. Not at all.I do not have any problem with this.
          abtA Offline
          abtA Offline
          abt
          Hi @mfalkvidd,
          how can i make a simple mesh network which directly sends message to the concerned node and that node acknowledge to the main node from which that message has been received with or without a gateway ?
          K 1 Reply Last reply
          • nagelcN Offline
            nagelcN Offline
            nagelc
            It can be done in the MySensors framework, but I am not sure I would call it simple. See this thread:
            https://forum.mysensors.org/topic/1085/node-to-node-communication
            I used node-node communication once to reduce latency on a button press, but as @mfalkvidd states, this is not the norm for MySensors. After more fiddling, I determined I did not actually need the node-to-node to make my application work.
            • abtA abt
              Hi @mfalkvidd,
              K Offline
              K Offline
              kimot
              @abt
              Look at LowPowerLab RFM69 examples.
              In gateway sketch you can see how to handle incoming messages, in others how to send messages.
              Combine this two and you obtain node, which is able to send messages to any node and receive messages too.
              But it is not realy "mesh" , it is normal "peer to peer" network.
              RFM69 has got good range, so in normal house real mesh is not needed, I think.
              What I consider real mesh is MySensors with parent nodes or ESP-MESH:
              https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/mesh.html
                abtA Offline
                abtA Offline
                abt
                Hi @mfalkvidd,
                If you don't mind ,could you share your tree topology code?
                • abtA abt
                  Hi @mfalkvidd,
                  @abt I don't have any tree topology code.
                  MySensor's routing code should be somewhere in https://github.com/mysensors/MySensors/tree/development/core I think.
                  • CarywinC Offline
                    CarywinC Offline
                    Carywin
                    Check out the RadioHead library, it implements a mesh network on RFM69
                    abtA 1 Reply Last reply
                    • CarywinC Carywin
                      abtA Offline
                      abtA Offline
                      abt
                      Hi @carywin Which library is good for any network you want to build rfm69, RadioHead ? Does it make any difference in code?
