  3. Compiling error gdb_hooks.h
3 Posts 2 Posters 632 Views 2 Watching
  • B
    B
    Bramz
    Re: 💬 Building a WiFi Gateway using ESP8266
    After failing to install the GatewayESP8266.ino on my Node MCU from Windows 10, I tried to install the sketch from Linux Ubuntu with MySensors library v.2.3.1 and ESP8266 Board definitions v.2.4.1 but again a compiling error shows up in Arduino IDE v.1.8.9:
    Arduino: 1.8.9 (Linux), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    In file included from /home/Name/Arduino/libraries/MySensors/MySensors.h:441:0,
                     from /home/Name/Arduino/GatewayESP8266/GatewayESP8266.ino:119:
    /home/Name/Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:33:23: fatal error: gdb_hooks.h: No such file or directory
     #include "gdb_hooks.h"
    compilation terminated.
    exit status 1
    Error compiling for board NodeMCU 1.0 (ESP-12E Module).
    Anybody with a suggestion how to solve this?
    • B Bramz
      exit status 1
      @bramz perhaps https://forum.mysensors.org/topic/9563/esp8266-fatal-error-gdb_hooks-h-no-such-file-or-directory-solved ?
      • B
        B
        Bramz
        @mfalkvidd Thanks, that solution worked and sorry I should have found that posting myself of course.
        FYI, for loading the ESP8266 Board definitions the usual URL https://arduino.esp8266.com/stable/package_esp8266com_index.json did not work for me anymore. Instead I had to use https://github.com/esp8266/Arduino/releases/download/2.4.2/package_esp8266com_index.json
