  3. Switching gateway issues
4 Posts 3 Posters 627 Views 3 Watching
  • B
    B
    Brian Morris
    wrote on last edited by Brian Morris
    Howdy all,
    I currently have a ESP8266 Wemos based gateway that I have been using for years. I am flipping over to using a Orange Pi Zero based gateway and everything is working with the MQTT part, it connects to the MQTT gateway on my Home Assistant instance, but I only see the "/mysgw1-in/0/255/0/0/18 2.3.1" message. I see its doing things like:
    Dec 02 14:35:45 INFO  Starting gateway...
    Dec 02 14:35:45 INFO  Protocol version - 2.3.1
    Dec 02 14:35:45 DEBUG MCO:BGN:INIT GW,CP=RNNGL-Q-,REL=255,VER=2.3.1
    Dec 02 14:35:45 DEBUG TSF:LRT:OK
    Dec 02 14:35:45 DEBUG TSM:INIT
    Dec 02 14:35:45 DEBUG TSF:WUR:MS=0
    Dec 02 14:35:45 DEBUG TSM:INIT:TSP OK
    Dec 02 14:35:45 DEBUG TSM:INIT:GW MODE
    Dec 02 14:35:45 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Dec 02 14:35:45 DEBUG MCO:REG:NOT NEEDED
    Dec 02 14:35:45 DEBUG MCO:BGN:STP
    Dec 02 14:35:45 DEBUG MCO:BGN:INIT OK,TSP=1
    Dec 02 14:35:45 DEBUG GWT:RMQ:MQTT RECONNECT
    Dec 02 14:36:00 DEBUG connected to 10.200.62.50
    Dec 02 14:36:00 DEBUG GWT:RMQ:MQTT CONNECTED
    Dec 02 14:36:00 DEBUG GWT:TPS:TOPIC=/mysgw1-in/0/255/0/0/18,MSG SENT
    Dec 02 14:36:00 DEBUG TSM:READY:NWD REQ
    Dec 02 14:36:13 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Dec 02 14:50:45 DEBUG TSF:SAN:OK
    But the nodes I have deployed dont want to talk to this new gateway. Even though its the same gateway ID and such. Here is a debug from one of my sensors. Any ideas?
     __  __       ____
            |___/                      2.3.1
    208 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
    331 TSM:INIT
    344 TSF:WUR:MS=0
    368 TSM:INIT:TSP OK
    389 TSM:INIT:STATID=14
    413 TSF:SID:OK,ID=14
    436 TSM:FPAR
    483 TSF:MSG:SEND,14-14-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2560 !TSM:FPAR:NO REPLY
    2584 TSM:FPAR
    2633 TSF:MSG:SEND,14-14-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4710 !TSM:FPAR:NO REPLY
    4734 TSM:FPAR
    4784 TSF:MSG:SEND,14-14-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6860 !TSM:FPAR:NO REPLY
    6885 TSM:FPAR
    6934 TSF:MSG:SEND,14-14-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    9011 !TSM:FPAR:FAIL
    9031 TSM:FAIL:CNT=1
    9052 TSM:FAIL:DIS
    9070 TSF:TDI:TSL
    skywatchS 1 Reply Last reply
    • B Brian Morris
      Howdy all,
       __  __       ____
              |___/                      2.3.1
      331 TSM:INIT
      344 TSF:WUR:MS=0
      368 TSM:INIT:TSP OK
      436 TSM:FPAR
      2584 TSM:FPAR
      4734 TSM:FPAR
      6885 TSM:FPAR
      9011 !TSM:FPAR:FAIL
      9031 TSM:FAIL:CNT=1
      9052 TSM:FAIL:DIS
      9070 TSF:TDI:TSL
      skywatchS
      skywatchS
      skywatch
      @brian-morris Maybe clear eeprom and reflash all devices? Could be old routing data retained? Just a thought.
      • B
        B
        Brian Morris
        Tried that. No change.
        • electrikE
          electrikE
          electrik
          Are you sure the node can reach the gateway? So is the connection okay?
