  3. OpenHAB
  4. UNINITIALIZED - BRIDGE_UNINITIALIZED after reboot
2 Posts 1 Posters 905 Views 1 Watching
  • mariogagnonM Offline
    mariogagnon
    I have a MQTT Gateway, 1 sensor, 2 things, one for the temperature and the other for the humidity.
    Node is is 105 and child 0 and 1.
    2 items are configured, everything is working well.
    But when I restart the Raspberry PI, the status for the 2 things is UNINITIALIZED - BRIDGE_UNINITIALIZED. In the openHab log viewer I see
    Node 105 found in gateway
    Child 0 not present in node 105
    Child 1 not present in node 105.
    To fix the issue, I delete the 2 things and create them again with node 105 child 0 and 1
    After that no more issue.
    I don't want to delete the 2 things every time I reboot the PI.
    Any suggestions
      mariogagnon
      Found a work around. Instead of configuring the things in PaperUI, I configure the MQTT Gateway and the sensor through the openHab things file. I followed the example that @dakipro wrote in the openHab controller main Web page (https://www.mysensors.org/controller/openhab). Thanks @dakipro.
      12.1k
