  3. Panasonic PIR sensor
5 Posts 4 Posters 769 Views 4 Watching
  • V
    V
    vj_v1
    I bought a Panasonic PIR sensor hoping that they would be a reliable alternative to SR501. However, i am facing trouble understanding the pinout of the panasonic sensors. The Datasheet has not been very helpful.
    https://www.panasonic-electric-works.com/cps/rde/xbcr/pew_eu_en/ca_pir_motionsensors_1192_en.pdf
    From the datasheet, this is the pin out.
    And my understanding is that this is the pin out.
    The senor is however not responding. i have been confused about the pin out and might have fried the sensor already. Please guide of my understanding of the pi out is accurate.
    YveauxY 1 Reply Last reply
    • V vj_v1
      YveauxY
      YveauxY
      @vj_v1 assuming the Panasonic pinout is taken from the bottom, I would say you swapped out and vcc
      V 1 Reply Last reply
      • electrikE
        electrikE
        electrik
        You can't just take the output from the sensor, a circuit is needed to amplify the signal. Is that circuit also in the sensor?
        Nca78N 1 Reply Last reply
        • electrikE electrik
          Nca78N
          Nca78N
          @electrik said in Panasonic PIR sensor:
          This is an "in can" sensor, everything is included and it has a digital output.
          • YveauxY Yveaux
            V
            V
            vj_v1
            @Yveaux - I did try both at some point, but no joy. Sounds like i fried it before it could see anything.
