  3. Handling NACKs
Handling NACKs
44 Posts 9 Posters 8.8k Views 13 Watching
  • alowhumA alowhum
    Very cool stuff.
    @mfalkvidd Would it be possible to create the functionality, but to measure the successrate of outgoing messages from the gateway node?
    For example, I'l love to be able to see how often the controller/gateway tries to toggle a distant node, but fails.
    @alowhum unless I misunderstand your suggestion, that's exactly what I have already done.
    • alowhumA
      alowhumA
      alowhum
      Ah, now I see. Thanks!
      • sundberg84S sundberg84
        @mfalkvidd i didnt fins time yet to implement more. But very good for two repeaters.
        E
        E
        evb
        @sundberg84 If I get it correct you implemented in your repeater sketch the use of the MySensors indication handler?
        void indication(indication_t ind)
          switch (ind)
            case INDICATION_TX:
              txOK++;
              break;
            case INDICATION_ERR_TX:
              txERR++;
              break;
        txOk and txErr are always incremented in the sketch and send to the gateway.
        Yet I see in your graphs a hourly count? Graphs from Grafana?
        Can you explain how you did this?
        • sundberg84S
          @evb - yes, that is correct, here is a complete sketch with a GW (Nrf24 - ethernet)
          #define MY_GATEWAY_W5100
          // radio on the same spi bus.
          #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
          #define MY_IP_ADDRESS 192,168,1,8   // If this is disabled, DHCP is used to retrieve address
          #define MY_PORT 5003
          //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
          #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0x01, 0x08 //AF-A0-F2-15-3B-1C
          // Set blinking period
          // Enable inclusion mode
          #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
          #define MY_DEFAULT_RX_LED_PIN  9  // Receive led pin
          #define MY_DEFAULT_TX_LED_PIN  8  // the PCB, on board LED
          #define MY_INDICATION_HANDLER
          static uint32_t txOK = 0;
          static uint32_t txERR = 0;
          #define REPORT_INTERVAL 300000 // Report every 5 minutes
          #define CHILD_ID_TX_OK 0
          #define CHILD_ID_TX_ERR 1
          #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
          #include <Ethernet.h>
          MyMessage txOKmsg(CHILD_ID_TX_OK, V_CUSTOM);
          MyMessage txERRmsg(CHILD_ID_TX_ERR, V_CUSTOM);
            switch (ind)
              case INDICATION_TX:
                txOK++;
                break;
                txERR++;
                break;
            //Send the sensor node sketch version information to the gateway
            sendSketchInfo("Gateway #1", "1.0");
            present(CHILD_ID_TX_OK, S_CUSTOM);
            present(CHILD_ID_TX_ERR, S_CUSTOM);
            static unsigned long last_send = 0;
            if (millis() - last_send > REPORT_INTERVAL) {
              send(txOKmsg.set(txOK));
              send(txERRmsg.set(txERR));
              last_send = millis();
          In Home Assistant you need to create a sensor that breaks down the incrementing number to each intervall you want.
          I use a utility_meter.
          utility_meter:
          hourly_ok_gw:
              source: sensor.gateway_1_0_0
              cycle: hourly
            hourly_err_gw:
              source: sensor.gateway_1_0_1
              cycle: hourly
          This sensors will be sent to Grafana each hour just like any other sensor and you can create a graph there:
