  3. Sketch problems.... I think
5 Posts 3 Posters 600 Views 3 Watching
  • J
    J
    JCH
    wrote on last edited by JCH
    I am trying to create a outdoor weather station which runs on batterys.
    I am having issues with the light level readings.... they were working fine now all of a sudden they arent.
    I am pretty sure that it is an issue with my sketch but i cant find any problems?? Am i missing something??
     * Version 1.0 - Henrik Ekblad
     * Pressure sensor example using BMP085 module
     * http://www.mysensors.org/build/pressure
    #define MY_NODE_ID 5
    #include <Wire.h>
    #include <Adafruit_BMP085.h>
    #include <DHT.h>
    #define DHT_DATA_PIN 2
    #define LIGHT_SENSOR_ANALOG_PIN 1
    #define LUX_ON 5
    #define POWER_ON 1  //  value to write to turn on sensor
    #define POWER_OFF 0 //  value to write to turn off sensor
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define VOLTAGE_CHILD_ID 3
    #define CHILD_ID_HUM 4
    #define CHILD_ID_LIGHT 5
    static const uint64_t UPDATE_INTERVAL = 30000;
    int oldBatteryPcnt = 0;
    const float ALTITUDE = 59; // <-- adapt this value to your own location's altitude.
    // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
      STABLE = 0,     // "Stable Weather Pattern"
      SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
      CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
      UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
      THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
      UNKNOWN = 5     // "Unknown (More Time needed)
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    //float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    //bool metric = true;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    bool metric;
    MyMessage tempMsg(TEMP_CHILD, V_TEMP);
    MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
    DHT dht;
    int lastLightLevel;
    //Serial.println("Setting Pin Mode to Output");
    //pinMode(LUX_ON, OUTPUT);
    Serial.println("Setup Sensor");
        analogReference(INTERNAL1V1);
    #else
        analogReference(INTERNAL);
      if (!bmp.begin())
        Serial.println("Could not find a valid BMP085 sensor, check wiring!");
        while (1) {}
      metric = getConfig().isMetric;
    void presentation()  {
      sendSketchInfo("Pressure Sensor", "1.1");
    Serial.println("Present sensors to gateway");
      // Register sensors to gw (they will be created as child devices)
      present(BARO_CHILD, S_BARO);
      present(TEMP_CHILD, S_TEMP);
      present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery " );
      present(CHILD_ID_HUM, S_HUM);
     // metric = getConfig().isMetric;
        int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
            Serial.println("LUX:");
        Serial.println(lightLevel);
            send(msg.set(lightLevel));
            lastLightLevel = lightLevel;
        sleep(5000);
        Serial.println("Humidity");
      dht.readSensor(true);
      if (isnan(humidity)) {
        lastHum = humidity;
        // Reset no updates counter
        nNoUpdatesHum = 0;
       #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      //sleep(UPDATE_INTERVAL);
        // get the battery Voltage
    #ifdef MY_DEBUG
        Serial.println(sensorValue);
    #ifdef MY_DEBUG
        float batteryV  = sensorValue * 0.003363075;
        float voltage = sensorValue * 0.003363075;
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
            // Power up radio after sleep
            oldBatteryPcnt = batteryPcnt;
            send(voltageMsg.set(voltage,2));
    //    sleep(SLEEP_TIME);
      float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
      float temperature = bmp.readTemperature();
      if (!metric)
        // Convert to fahrenheit
        temperature = temperature * 9.0 / 5.0 + 32.0;
      int forecast = sample(pressure);
      Serial.print("Temperature = ");
      Serial.print(temperature);
      Serial.println(metric ? " *C" : " *F");
      Serial.print("Pressure = ");
      Serial.print(pressure);
      Serial.println(" hPa");
      Serial.print("Forecast = ");
      Serial.println(weather[forecast]);
      if (temperature != lastTemp)
        send(tempMsg.set(temperature, 1));
        lastTemp = temperature;
      if (pressure != lastPressure)
        send(pressureMsg.set(pressure, 0));
        lastPressure = pressure;
      if (forecast != lastForecast)
        send(forecastMsg.set(weather[forecast]));
        lastForecast = forecast;
      sleep(SLEEP_TIME);
    float getLastPressureSamplesAverage()
      float lastPressureSamplesAverage = 0;
      for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        lastPressureSamplesAverage += lastPressureSamples[i];
      lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
      return lastPressureSamplesAverage;
    // Algorithm found here
    // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
      // Calculate the average of the last n minutes.
      int index = minuteCount % LAST_SAMPLES_COUNT;
      lastPressureSamples[index] = pressure;
      minuteCount++;
      if (minuteCount > 185)
        minuteCount = 6;
      if (minuteCount == 5)
        pressureAvg = getLastPressureSamplesAverage();
      else if (minuteCount == 35)
        float lastPressureAvg = getLastPressureSamplesAverage();
        float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
        if (firstRound) // first time initial 3 hour
          dP_dt = change * 2; // note this is for t = 0.5hour
        else
          dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
      else if (minuteCount == 65)
        if (firstRound) //first time initial 3 hour
          dP_dt = change; //note this is for t = 1 hour
        else
          dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
      else if (minuteCount == 95)
          dP_dt = change / 1.5; // note this is for t = 1.5 hour
        else
          dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
      else if (minuteCount == 125)
        pressureAvg2 = lastPressureAvg; // store for later use.
          dP_dt = change / 2; // note this is for t = 2 hour
        else
          dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
      else if (minuteCount == 155)
          dP_dt = change / 2.5; // note this is for t = 2.5 hour
        else
          dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
      else if (minuteCount == 185)
          dP_dt = change / 3; // note this is for t = 3 hour
        else
          dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
        pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
        firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
      int forecast = UNKNOWN;
      if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
        forecast = UNKNOWN;
      else if (dP_dt < (-0.25))
        forecast = THUNDERSTORM;
      else if (dP_dt > 0.25)
        forecast = UNSTABLE;
      else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
        forecast = CLOUDY;
      else if ((dP_dt > 0.05) && (dP_dt < 0.25))
        forecast = SUNNY;
      else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
        forecast = STABLE;
      else
        forecast = UNKNOWN;
      // uncomment when debugging
      Serial.print(F("Forecast at minute "));
      Serial.print(minuteCount);
      Serial.print(F(" dP/dt = "));
      Serial.print(dP_dt);
      Serial.print(F("kPa/h --> "));
      return forecast;
    EDIT: ignore the commented out sections.. i was playing around with powering the sensor off an arduino pin so try and save on power :)
    • MasMatM
      MasMatM
      MasMat
      I dont know what controller you are using but I had similar problems with domoticz when presenting s_light_level and V_Level vs v_light_level. It had to do with domoticz update.
      Thats what came to mind. I didnt find a sketch problem if this wasn't part of your problem.
      • J
        J
        JCH
        Turns out i had a bad battery...... Must of shorted internally and was causing my arduino to go crazy :ghost:.
        Node is up and running and reporting perfectly. Power consumption is approx 220uA.
        Reporting temp, humidity, light level , barometer, forecast and battery level.
        Here is the code if anyone wants..................
        OUTDOOR WEATHER STATION SKETCH
        TEMP AND PRESSURE VIA BMP180
        HUMIDITY VIA DHT22
        LIGHT SENSOR VIA LM393
        SOIL MOISTURE VIA SOIL MOISTURE SENSOR
        CREATED BY J.H 4.3.2020
        REV 2
        // Define Node ID
        // Includes
        #include <Wire.h>
        #include <DHT.h>
        // Pin Defines
        #define LUX_ON 5
        // Defines
        enum FORECAST
        //float lastTemp;
        float lastHum;
        float pressureAvg;
        float pressureAvg2;
        float dP_dt;
        bool metric;
        DHT dht;
        int lastLightLevel;
        #else
          if (!bmp.begin())
            while (1) {}
          present(BARO_CHILD, S_BARO, "Pressure" );
          present(TEMP_CHILD, S_TEMP, "Temperature" );
          present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery" );
          present(CHILD_ID_HUM, S_HUM, "Humidity" );
          present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "Lux" );
          ////////// Lux Sensor Code /////////////
            digitalWrite(LUX_ON, POWER_ON); // Power the Lux sensor of Digital Pin to save power
            Serial.print("Sensor Power on pin "); Serial.print(LUX_ON); Serial.print(" is..."); Serial.println((POWER_ON));
            wait(1000); // Wait a second for sensor to power up before reading
                Serial.println("Light Lux Level:");
           digitalWrite(LUX_ON, POWER_OFF); // turn it off
           Serial.print("Sensor Power on pin "); Serial.print(LUX_ON); Serial.print(" is..."); Serial.println((POWER_OFF));
            wait(1000);
          ////////// DHT22 Sensor Code ///////////
            lastHum = humidity;
            nNoUpdatesHum = 0;
           #ifdef MY_DEBUG
            Serial.print("Humidity: ");
          } else {
            nNoUpdatesHum++;
          ////////// Battery Reporting Code ///////////
        #ifdef MY_DEBUG
        #ifdef MY_DEBUG
          ////////// BMP180 Pressure Sensor Code ///////////
          if (!metric)
          sleep(SLEEP_TIME);
          ////////// Forecast Algorithm ///////////
          minuteCount++;
            minuteCount = 6;
            else
            else
            else
            else
            else
            else
            forecast = UNKNOWN;
            forecast = CLOUDY;
            forecast = SUNNY;
            forecast = STABLE;
          else
            forecast = UNKNOWN;
          return forecast;
        • J JCH
          HUMIDITY VIA DHT22
          REV 2
          // Define Node ID
          // Includes
          #include <Wire.h>
          #include <DHT.h>
          // Pin Defines
          #define LUX_ON 5
          // Defines
          enum FORECAST
          //float lastTemp;
          float lastHum;
          float pressureAvg;
          float pressureAvg2;
          float dP_dt;
          bool metric;
          DHT dht;
          int lastLightLevel;
          #else
            if (!bmp.begin())
              while (1) {}
              wait(1000);
              lastHum = humidity;
              nNoUpdatesHum = 0;
             #ifdef MY_DEBUG
            } else {
              nNoUpdatesHum++;
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
            if (!metric)
            sleep(SLEEP_TIME);
            minuteCount++;
              minuteCount = 6;
              else
              else
              else
              else
              else
              else
              forecast = UNKNOWN;
              forecast = CLOUDY;
              forecast = SUNNY;
              forecast = STABLE;
            else
              forecast = UNKNOWN;
            return forecast;
          Great work @JCH, thanks for reporting back and for sharing the sketch.
          • J
            J
            JCH
            So after running this weather station for a few weeks i decided to switch out the lux sensor for a soil moisture sensor without modifying the code....
            The readings are working but they are very up and down.... they are not a steady decline..... how are people measuring the analog values of soil moisture ?
