  3. sensors in boxes
sensors in boxes
57 Posts 11 Posters 44.1k Views 16 Watching
  • GuyPG
    GuyPG
    GuyP
    wrote on last edited by GuyP
    I think I must have read almost every page on this site when I discovered it. I really loved this idea. For ages I've wanted to monitor and interact with my surroundings via some home automation solution, but all the commercial solutions are really expensive and limited. MySenors and OpenHAB really give me the customisation I want.
    The only thing missing was putting everything together. I'm working on that. But first I needed to create my sensors, as small/cheap as possible and battery powered.
    Here's my first pass at building the temperature sensor, in a 3D printed box which also houses the battery compartment.
    The circuit board (Single Sides Etch) slides in on groves in the walls. I added the battery monitoring to the Arduino as I really need to know if/when the batteries are going flat. That's all pushed back to openHAB which I can then create a rule to watch for battery low, however so far the batteries seem that they will last for ever!
    The contacts on the battery box are small flat metal. Aluminium between the batteries, and Copper for the terminals. I used copper as I could more easily solder to it.
    Making it very easy to assemble.
      A Former User
      Hi, great project!
      Would you mind sharing a bit more about your circuit? Are you using step-up regulators to power the atmega? Did you etch the PCB yourself or ordered it somewhere?
      I was thinking of a similar project. My idea is to add 3.5mm female jacks to easily add external sensors, e.g external temperature probes, pulse watt counter, etc, and maybe a latching on off switch (but then again, who wants to power off their sensors).
      • GuyPG
        GuyPG
        GuyP
        I'm running everything at 3 volts from the 2 AAA batteries. The box is 3D printed and integrates the battery box. I'm not using any screws, just slide rails for the PCB , top and back.
        TempSensorBase.stl
        I have two board types now. One with just the single Dallas temp sensor on it, which turns out to be what I need most of.
        I also created another board which has three Connectors, JP1-3, which allows to additional Dallas Temp sensors. I have these in locations where I can run wires more easily, like my loft spaces.
        I'm etching everything myself. Very simple really. I'm using the print on to glossy paper and transfer onto copper board, using a laminator, method. Works really well. As these boards are small I tend to etch a few at a time onto a single copper board and then cut the board at the end.
        DrJeffD Moshe LivneM 2 Replies Last reply
        • 5546dug5
          5546dug5
          5546dug
          @GuyP Great looking project! How is your battery level usage so far?
          • GuyPG
            GuyPG
            GuyP
            Project has now been running for over a month. The study is the Longest running sensor at closer to 2 months.
            As you can see the batteries are still in very good shape... Also I'm still polling every 30seconds for the temp. So if I was worried about the battery I could reduce the poll to say once every 5 minutes and not lose anything in resolution.
            • 5546dug5
              5546dug5
              5546dug
              @GuyP would you care to share your code for this project?
              • GuyPG
                GuyPG
                GuyP
                Sure no problem.. It's the stock code for the dallas temperature sensor with the simple addition for the battery monitoring.
                oh and just as an update on that.. still haven't replaced the batteries in the sensors and they are still reporting 82%, which is a run time of over 4 months now.
                BatteryStatus.tiff
                // Example sketch showing how to send in OneWire temperature readings
                #include <OneWire.h>
                OneWire oneWire(ONE_WIRE_BUS);
                int numSensors=0;
                boolean metric = true;
                MyMessage msg(0,V_TEMP);
                MyMessage msgvolt(1,V_VOLTAGE);
                int BATTERY_SENSE_PIN = A0;
                int oldBatteryPcnt = 0;
                  analogReference(INTERNAL);
                  // Startup OneWire
                  sensors.begin();
                  gw.begin();
                  gw.sendSketchInfo("Temperature Sensor", "1.0");
                     gw.present(i, S_TEMP);
                  gw.process();
                  // Battery Monitoring
                  float batteryV = sensorValue * 0.003363075;
                  Serial.print(batteryV);
                  Serial.println(" V");
                  Serial.print(batteryPcnt);
                  Serial.println(" %");
                    gw.send(msgvolt.set(batteryPcnt,1));
                    oldBatteryPcnt = batteryPcnt;
                    if (lastTemperature[i] != temperature && temperature != -127.00) {
                  gw.sleep(SLEEP_TIME);
                • GuyPG GuyP
                  BatteryStatus.tiff
                  int numSensors=0;
                    // Startup OneWire
                    sensors.begin();
                    gw.begin();
                    gw.process();
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @GuyP what kind of chip is the big one? Does not look like nano or pro mini. Terrific run time so must be efficient.
                  • GuyPG
                    GuyPG
                    GuyP
                    It's an ATMEGA328P, which is the Arduino processor, I buy them in bulk from China, write the boot loader and flash the code onto them using an uno board.
                    Moshe LivneM H 2 Replies Last reply
                    • GuyPG GuyP
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @GuyP Cool! these are really cheap and they save on cutting the LED and voltage regulator.... it looks like they are even more economical in energy then the modified (no LED no voltage reg) pro mini. Can you detail for a complete idiot the bootloader and flash thing?
                      GuyPG 1 Reply Last reply
                      • GuyPG GuyP
                        TempSensorBase.stl
                        DrJeffD
                        DrJeffD
                        DrJeff
                        @GuyP Can you post the pdf images of the boards, I want to etch some I like the use of 328P chip, The only problem the png file is scaled wrong too large.
                        • GuyPG GuyP
                          H
                          H
                          hawk_2050
                          @GuyP Do you have a favourite seller for those mega328 DIP parts? Mostly when I've looked on eBay the clone Arduino Mini's come in cheaper than a DIP package mega328 IC. I also would prefer to use a design that utilises the mega328 DIP directly rather than an Arduino Mini if I could. Cost per node is very important to me to enable affordable expansion of my network. Thanks.
                          • H hawk_2050
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @hawk_2050 look here
                            That is much cheaper.... 1.4$/node
                            • Moshe LivneM Moshe Livne
                              GuyPG
                              GuyPG
                              GuyP
                              @hawk_2050 I buy them from banggood.com where they discount for quantity so I'm usually paying about £1.66 a chip and free delivery.
                              However looking at @Moshe-Livne he's found a cheaper place.. so I think I'll be using them from now on :)
                                GuyPG
                                GuyPG
                                GuyP
                                @Moshe-Livne the boot loader..
                                https://www.arduino.cc/en/Hacking/Bootloader?from=Tutorial.Bootloader
                                I use this method to write the boot loaders using an uno..
                                https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
                                works great. I use a Zero insertion socket for the chip and rattle through the chips in a seconds.
                                • DrJeffD DrJeff
                                  GuyPG
                                  GuyPG
                                  GuyP
                                  @DrJeff Sure no problem..
                                  TempSensor.pdf
                                  I've also now built a "Repeater Board", this board can either act as a repeater, and be powered by USB mini, or battery (Best not on battery when in repeater mode). It also has the expansion to add multiple Dallas Temperature sensors. JP1-3 sensors can be daisy chained up to around 16 in total. I have these boards in loft spaces, and garage where I want to watch temperature in lots of locations and I don't mind a few wires.
                                  TempSensorRepeater.pdf
                                  Let me know if those work out better...
                                  DrJeffD 1 Reply Last reply
                                  • GuyPG GuyP
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @GuyP That looks pretty simple... what boot loader do you write? do you really remove the processor from the uno or did you make a dedicated one? do you use the minimal breadboard version? This system also has the upside of not having to deal with the irritating counterfeit or ch340 ftdi chips, so bonus points...
                                    • GuyPG GuyP
                                      TempSensor.pdf
                                      DrJeffD
                                      DrJeffD
                                      DrJeff
                                      @GuyP Cool thanks, Time to etch some boards, have you used this method/setup for other nodes? Just trying to get some ideas :grinning:
                                        GuyPG
                                        GuyPG
                                        GuyP
                                        @Moshe-Livne When writing the boot loader you need to keep the uno chip in the board.
                                        Once you've written all the board loaders, then you can pull the chip from uno and replace it with all the new ones to write the temperature sensor codes.
                                        • DrJeffD DrJeff
                                          GuyPG
                                          GuyPG
                                          GuyP
                                          @DrJeff At the moment just temperature sensors.. however the plan is to also control my heating system around the house.
                                          I will put putting controllers on all the radiators around the house, and replacing the controller in the house with simple radio buttons which feed back to openhab for manual over ride.
                                          Just not had time yet! :(
