  3. sensors in boxes
sensors in boxes
57 Posts 11 Posters 43.2k Views 16 Watching
  • O
    O
    oded00
    @Moshe-Livne Any progress?
    can you please explain how this pcb be smaller with no need for soldering
    Where are you from?
    • O oded00
      Where are you from?
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @oded00 Still waiting for the 22pf capacitors...
      It was made in resolution for home made PCBs and single layer. oshpark can make the lines much smaller and make more layers so there is no need for soldering the "red" lines. you still need to solder the components (nrf, capacitors etc)
      I live in NZ
      • P
        P
        pjeterinfo
        @GuyP If I order this brd files online, I assume that I need to remove the red lines from the top layer? Or maybe reroute them if possible? Looks like some short circuit connections.
        • P pjeterinfo
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @pjeterinfo Oh I didn't notice them. Darn, and I soldered the wires...
          • GuyPG
            GuyPG
            GuyP
            Yes You'll want to remove or reroute them. I was only think of a single layer board so those are link wires. Sorry I should have talked about those.
            • P
              P
              pjeterinfo
              I order a few with modified toplayer to fit all the "red" wires and removed 2mm of the board width.
              tempsensor.brd
              • GuyPG
                GuyPG
                GuyP
                Excellent...be careful, not to remove too much from the right side, as the radio transmitter will over hang which makes it harder to fit in a box.
                • Moshe LivneM Moshe Livne
                  @GuyP PCB arrived from oshpark!
                  What capacitors did you use for the crystal? and what resistor for the dallas?
                  mntlvrM
                  mntlvrM
                  mntlvr
                  What is the name for this board on OSHpark? I would like to order 3 of these boards myself
                  • mntlvrM mntlvr
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @mntlvr don't use this as it has shorts. Use the corrected one someone posted a few comments back
                    mntlvrM 1 Reply Last reply
                      mntlvrM
                      mntlvrM
                      mntlvr
                      wrote on last edited by mntlvr
                      #50
                      Thanks Moshe-Livne but I can't find any comments on this posting about anyone buying boards that work can you help with this or is it best just to make your own?
                      • mntlvrM mntlvr
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        Just upload the brd file pjeterinfo posted
                        • P
                          P
                          pjeterinfo
                          Use it on your own risk, it's nog yet arrived and thus not tested ;-)
                          • P pjeterinfo
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @pjeterinfo I still need to cut the traces on mine....
                            • P
                              P
                              pjeterinfo
                              All parts received and programmed using a pro mini, man that's frustrating ;-) . But works great..
                              • G
                                G
                                gonzalonal
                                Nice little board.
                                Do you know how long does the dallas temp sensor keeps working on?
                                I ask this because its minumun supply voltage is 3.0V and you are feeding the board exactly with that.
                                So, what happens when the battery voltage get a bit below 3.0V?
                                Thanks, regards.
                                • P
                                  P
                                  pjeterinfo
                                  @gonzalonal We'll see, I have setup datamine for this sensor in Vera.
                                  • 5546dug5
                                    5546dug5
                                    5546dug
                                    @GuyP many posts ago you guided @Moshe-Livne to arduino cc/ file for downloading the bootloader files but I see only the files for 168 DIP and not 328P
                                    Do I use the 168p file?
