  3. Gateway W5100 with RFM69 fails to compile
9 Posts 4 Posters 966 Views 2 Watching
  • D
    D
    Dirk_H
    im trying to build a Gateway based on ATMEGA2560 with W5100 Ethnernet Chip and RF69 Radio Module.
    I'm using the stock GatewayW5100 from the MySensors Examples folder. Becuase I'm using a RF69 and not a NRF24 I disable the NRF24 driver and enable the RF69 Driver by (dis)commenting the specific lines.
    However my Arduino 1.8.8 gives me an error message: 'class SoftSPI<16u, 15u, 14u, 0u>' has no member named 'setDataMode'. Arduino.cc says that setDataMode shall not be used anymore. I think something is screwed up here...
    The debug output of Arduino says the following Versions are used:
    Bibliothek Ethernet in Version 2.0.0 im Ordner: D:\Program Files (x86)\Arduino\libraries\Ethernet wird verwendet
    Bibliothek MySensors in Version 2.3.2 im Ordner: D:\EigeneDaten\Dokumente\Arduino\libraries\MySensors wird verwendet
    Bibliothek SPI in Version 1.0 im Ordner: D:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI wird verwendet
    Source of the Gateway Sketch (only put a comment on #define MY_RADIO_RF24 and removed comment from #define MY_RADIO_RFM69.
     * Version 1.0 - Henrik Ekblad
     * Contribution by a-lurker and Anticimex
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
    //#define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RFM69_NEW_DRIVER
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_IP_ADDRESS 192,168,178,66
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
      I’m unable to find any recent changes that seem to cause this problem (checked the Arduino changelog and the MySensors code). But I noticed that only the old rfm69 driver uses setDataMode(). Maybe nobody has tried to build a mega-based gateway with w5100 and rfm69 before, so the problem has not been observed until now.
      If you are building a new MySensors network, you could use the new rfm69 driver by uncommenting MY_RFM69_NEW_DRIVER
      • D
        D
        Dirk_H
        Sorry for replying this late, just having some "real world" issues ;)
        Yes, with the new driver it works. Do we have a comparison about pros/cons of the new RFM69 driver. As I'm migrating all my nodes from nrf24 to rfm69 its no problem to use the new driver in all sketches. Just wondering what has changed in the new driver..
        Thanks, DirkH
        • D Dirk_H
          Thanks, DirkH
          @Dirk_H - I have the same issue, but I do not get softSPI to work on a Uno + Ethernet Module + RFM69. Can you confirm that softSPI works for you and Ethernet Module? What pins do you use for softSPI (analog?)
          • scalzS
            scalzS
            wrote on last edited by scalz
            @Dirk_H
            • old driver is based on an old lowpowerlab lib version
            • new driver has been refactored and optimized. It's not compatible with old driver. Which means it should be deployed on gw and all nodes
            About new driver:
            • more features like : automatic power level control so it does not use more rf power than needed
            • unified driver with Lora modules so they can communicate with rfm69 (rfm95<->rfm69 for example)
            • handles SPI transaction so it should be compatible with HW SPI+W5100
            • memory and speed optimizations
            • etc
            I don't know if it still works, but I tried (years ago) Nano gw + W5100 + RFM69 + HW SPI, and it was ok. No time for the moment to re-test it unfortunately (I don't use this setup in prod).
            That said if you got it working with new driver, that's what I would use for sure
            • D
              D
              Dirk_H
              thank you scalz for the very good clarification.
              @sundberg84 I can confirm that it does compile with the #define MY_RFM69_NEW_DRIVER option. AFAIK Arduino changed the way setDataMode should be called (see links in first post). I'm not a SW-Expert but I think Someone would have to change the coresponding SoftSPI calls in the old RFM69 (old) driver if you want to use it. I currently use an ATMega2560+W5100+NRF24PA with SoftSPI which is working (but I do not know with which Arduino Verison it was compiled).
              I will go with the new driver. I think it takes some time until I really do the change in HW, because I have to change several productive nodes. As we have big heat at the moment and my lab is under the roof my motivation is currently not that high... :thermometer: :disappointed_relieved:
              • D
                D
                Dirk_H
                @sundberg84
                It does not work for me with softspi too. Although the debug output does not look that bad..
                MCO:BGN:INIT GW,CP=RPNGA---,FQ=16,REL=255,VER=2.3.2<\n>
                4 TSM:INIT<\n>
                5 TSF:WUR:MS=0<\n>
                8 TSM:INIT:TSP OK<\n>
                10 TSM:INIT:GW MODE<\n>
                12 TSM:READY:ID=0,PAR=0,DIS=0<\n>
                14 MCO:REG:NOT NEEDED<\n>
                577 GWT:TIN:IP=192.168.178.203<\n>
                1581 MCO:BGN:STP<\n>
                1583 MCO:BGN:INIT OK,TSP=1<\n>
                1585 TSM:READY:NWD REQ<\n>
                • D Dirk_H
                  @sundberg84
                  4 TSM:INIT<\n>
                  5 TSF:WUR:MS=0<\n>
                  @Dirk_H - this is exactly the same for me. Are you using logic level converters?
                  D 1 Reply Last reply
                  • sundberg84S sundberg84
                    D
                    D
                    Dirk_H
                    @sundberg84 Hi, I'm not using level converters becuse I use a ProMini with 3,3V (with W5100 and rfm69hw).
                    Maybe I have a small clue: The Interrupt Pin is high all the time. It seems that the interrupt request from the RFM Module is not processed. I cant see interrupts when I start a node. (With a working setup with ESP8266 and RFM69, the pin is low most of the time except when new packets arrive from a sensor).
