  3. Domoticz
  4. [SOLVED] MySensors Raspberry Pi Gateway + Domotics Controller
23 Posts 5 Posters 3.6k Views 5 Watching
  • EmeE Eme
    @mfalkvidd so how do I change the title to reflect "SOLVED"?
    YveauxY
    YveauxY
    @Eme I did it for you, but next time choose to edit the top post, and change the topic
    • EmeE Eme
      I have good news. I used a small prototype board for everything. made sure no line was more than 6 inches long. I soldered (My soldering sucks!) the capacitator right next to the radio and Bahm! Domoticz picked up all powered devices. :grinning:
      Lessons learnt, keep length of your wires short, nRf24 MUST have a decent capacitator to smoothen out power. Don't rely on GPIO pins to power it, use a regulator. Though help may come from all and sundry, its all up to you to check their suggestions... Thanks all for helping me.
      I can finally retire my Nano-Serial Gateway! Wont be upgrading for a long time to come :sneezing_face:
      zookazimZ
      zookazimZ
      zookazim
      @Eme Thanks for letting us know how you solved the problem - helps us all to learn. I've recently upgraded my Raspberry Pi 1b to 4 and just got it working as an ethernet gateway with standard NRF24 radio. I'm curious about a few things as I've been trying to also use a PA LNA radio but without success;
      • Any reason you have set up your gateway as serial and not ethernet?
      • What did you mean by "Don't rely on GPIO pins to power it, use a regulator". By regulator did you mean the capacitor, did you use another regulator component - I can't see from your image
      • Did you change the power setting of you configuration file MyConfig.h -lowering the power to "RF24_PA_LOW'?
      EmeE 1 Reply Last reply
      • zookazimZ zookazim
        EmeE
        EmeE
        Eme
        @zookazim so sorry I haven't been on here in years. I actually left the IoT nodes for a while. I was running into so many issues. To answer your question... not sure if it's still required or even relevant.
