  3. Domoticz
  4. [SOLVED] MySensors Raspberry Pi Gateway + Domotics Controller
23 Posts 5 Posters 3.8k Views 5 Watching
  • EmeE
    EmeE
    Eme
    I finally made up my mind to move from MySensors Ver 2.1.1 to the new 2.3.2 release. Before now, I had been using a Nano - Rf24 Gateway connected to USB of a Pi2 with Domoticz controller running. This had served me well over the years with minimal issues. I have several Nodes running 2.1 sketches scattered around my home.
    From research, I noticed it was possible to run both Gateway & Controller off the Pi without need for additional hardware. I followed the step by step release notes at and also a procedue for building-a-raspberry-pi-gateway.
    I used Cleareeprom Sketch to clear one Node (Node ID 5) and proceeded to biuld a new gateway on the Pi itself.
    My configuration values were
    ./configure --my-transport=rf24 --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-controller-ip-address=127.0.0.1 --my-port=5003 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    make
    tested with sudo ./bin/mysgw
    sudo make install
    sudo systemctl enable mysgw.service
    sudo systemctl start mysgw.service
    my "tail -f /var/log/syslog" revealed the following
    /home/pi/MySensors$ tail -f /var/log/syslog
    Aug 21 11:57:54 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
    Aug 21 11:57:54 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:57:54 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:57:55 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:57:56 IoTGateway mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:57:56 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:57:56 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=7
    Aug 21 11:57:56 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:57:56 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:57:56 IoTGateway mysgw: !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:57:58 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:57:58 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:57:58 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
    Aug 21 11:57:58 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:57:58 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:57:59 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:57:59 IoTGateway mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:57:59 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:57:59 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=7
    Aug 21 11:57:59 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:57:59 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:58:01 IoTGateway mysgw: !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:13 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:13 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:58:13 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
    Aug 21 11:58:13 IoTGateway mysgw: TSF:PNG:SEND,TO=0
    Aug 21 11:58:13 IoTGateway mysgw: TSF:CKU:OK
    Aug 21 11:58:13 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:58:13 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:17 IoTGateway mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:17 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:58:17 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=7
    Aug 21 11:58:17 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:58:17 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:58:17 IoTGateway mysgw: !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:19 IoTGateway mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:19 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:58:19 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=7
    Aug 21 11:58:19 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:58:19 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:58:19 IoTGateway mysgw: !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:31 IoTGateway mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:31 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:58:31 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=7
    Aug 21 11:58:31 IoTGateway mysgw: TSF:PNG:SEND,TO=0
    Aug 21 11:58:31 IoTGateway mysgw: TSF:CKU:OK
    Aug 21 11:58:31 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:58:31 IoTGateway mysgw: !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:31 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:31 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
    Aug 21 11:58:31 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:58:32 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:33 IoTGateway mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:33 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:58:33 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=7
    Aug 21 11:58:33 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:58:33 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:58:33 IoTGateway mysgw: !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:33 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:33 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
    Aug 21 11:58:34 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:35 IoTGateway mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:35 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:58:35 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=7
    Aug 21 11:58:35 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:58:35 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:58:35 IoTGateway mysgw: !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:35 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:35 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
    Aug 21 11:58:36 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Aug 21 11:58:37 IoTGateway mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Aug 21 11:58:37 IoTGateway mysgw: TSF:MSG:BC
    Aug 21 11:58:37 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=7
    Aug 21 11:58:37 IoTGateway mysgw: TSF:CKU:OK,FCTRL
    Aug 21 11:58:37 IoTGateway mysgw: TSF:MSG:GWL OK
    Aug 21 11:58:37 IoTGateway mysgw: !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    I can see 3 Nodes (Two Nodes running Ver 2.0 version sketches and one with the new Ver 2.3 sketch) trying to request for registration without luck. This tells me Transport with Rf24 is okay, but nothing else.
    What must I do? How can I get the Domoticz to accept the new requests and create the devices? I have deleted the old MySensors hardware from Domoticz but it still wont register.
    EmeE YveauxY 2 Replies Last reply
    • EmeE Eme
      make
      sudo make install
      EmeE
      EmeE
      Eme
      Please someone help me...
      • EmeE Eme
        make
        sudo make install
        YveauxY
        YveauxY
        @Eme judging from the log, your gateway is receiving messages, but fails to send any (i only see nodes 2 & 7 in the log btw, not a third).
        Powering of your gateway radio could be an issue (as a radio consumes more power on send than on receive).
        Also, you had success using a serial gateway instead of running everything on rpi. Did you try that? Some users have reported issues running everything on rpi.
        EmeE 1 Reply Last reply
          The lines with
          mean that the gateway is sending a response to the node, but the gateway does not receive an acknowledgement from the node.
          Are you using the very same nrf24 as you did on your nano gateway, or a different one?
          How is the nrf24 powered?
          What capacitor(s) are you using? Where are they connected?
          What antenna are you using?
          Is there any conducting material near the antenna? This can block the signal.
          Are the nodes in the same place as before or have you moved them?
          Is the gateway in the same place as before or have you moved it?
          What is the distance between the nodes and the gateway?
          Posting a few photos of your setup would help us understand the environment you are working in.
          • E
            E
            eiten
            Hello @Eme,
            Sending only works for an unacknowledge msg. Now the question is did the gateway not send the message or did the sensor not receive the message thus not sending an ACK. Yould you ckeck on the sensor side what the debug says?
            • YveauxY Yveaux
              EmeE
              EmeE
              Eme
              Thanks for your response @Yveaux , l did notice 3 nodes at the time, but perhaps it didn't show on the portion of the log l shared. Yes l had been using a USB serial gateway attached to a Pi3 for over 2 years. I have tried my best to stay away from the "Bleeding Edge" of technology by staying with a stable version that has worked for me. I've been on MySenosors Ver 2.1.1 for a very long time. Just thought to update and Bahm! I'm in trouble. Can't connect to several nodes. Luckily MQTT still works, but all my MySensors nodes are down.
                The lines with
                EmeE
                EmeE
                Eme
                wrote on last edited by Eme
                Hello @mfalkvidd , l am a fan! I very honoured to have you look into my issue... to answer your questions...
                No it's another Rf24 but from the same batch as the one on the nano Gateway and all my nodes. I still have a spare one lying around. I'll try it see if it makes any difference.
                The Rf24 is powered directly from the Pi with a 220uf cap connected next to GPIO pins as described in the official Rasberry Pi Gateway guide. I'll post a picture of the setup.
                Everything is still on the fly with Dupont cables and Leds on a bread board until everything works well.
                Concerning proximity of nodes to Gateway and if I've moved them from their original place. Besides the Gateway now lying on my desk, all my nodes are still in their place around the hose. Node ID 2 is the Sprinkler from my kitchen downstairs (over 10 metres away between concrete walls) Node ID 7 is the Gate node outside the house (about 9 meters from my desk) and Node ID 5 which didn't show in the log (probably disconnected at the time) is right next to the PiGateway.
                See the picture of my setup
                • E eiten
                  Hello @Eme,
                  EmeE
                  EmeE
                  Eme
                  Thanks @eiten I thought I already shared that. I just hooked Node 5 to the laptop to get its log...
                   __  __       ____
                          |___/                      2.3.2
                  16 MCO:BGN:INIT REPEATER,CP=RNNRA---,FQ=16,REL=255,VER=2.3.2
                  27 MCO:BGN:BFR
                  28 TSM:INIT
                  29 TSF:WUR:MS=0
                  36 TSM:INIT:TSP OK
                  38 TSM:INIT:STATID=5
                  40 TSF:SID:OK,ID=5
                  41 TSM:FPAR
                  46 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  764 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  770 TSF:MSG:BC
                  1880 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  1884 TSF:MSG:BC
                  2053 !TSM:FPAR:NO REPLY
                  2055 TSM:FPAR
                  2059 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2810 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  2816 TSF:MSG:BC
                  3924 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  3930 TSF:MSG:BC
                  4066 !TSM:FPAR:NO REPLY
                  4068 TSM:FPAR
                  4072 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4845 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  4850 TSF:MSG:BC
                  5971 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  5977 TSF:MSG:BC
                  6079 !TSM:FPAR:NO REPLY
                  6081 TSM:FPAR
                  6085 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  6887 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  6892 TSF:MSG:BC
                  8008 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  8013 TSF:MSG:BC
                  8092 !TSM:FPAR:FAIL
                  8093 TSM:FAIL:CNT=1
                  8095 TSM:FAIL:DIS
                  8097 TSF:TDI:TSL
                  18099 TSM:FAIL:RE-INIT
                  18101 TSM:INIT
                  18107 TSM:INIT:TSP OK
                  18109 TSM:INIT:STATID=5
                  18112 TSF:SID:OK,ID=5
                  18114 TSM:FPAR
                  18118 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  20059 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  20064 TSF:MSG:BC
                  20125 !TSM:FPAR:NO REPLY
                  20127 TSM:FPAR
                  20131 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  22094 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  22099 TSF:MSG:BC
                  22140 !TSM:FPAR:NO REPLY
                  22142 TSM:FPAR
                  22147 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  24135 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  24140 TSF:MSG:BC
                  24155 !TSM:FPAR:NO REPLY
                  24157 TSM:FPAR
                  24161 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  26169 !TSM:FPAR:FAIL
                  26170 TSM:FAIL:CNT=2
                  26172 TSM:FAIL:DIS
                  26174 TSF:TDI:TSL
                  36177 TSM:FAIL:RE-INIT
                  36179 TSM:INIT
                  36186 TSM:INIT:TSP OK
                  36188 TSM:INIT:STATID=5
                  36191 TSF:SID:OK,ID=5
                  36193 TSM:FPAR
                  36197 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  38204 !TSM:FPAR:NO REPLY
                  38206 TSM:FPAR
                  38210 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  38228 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  38234 TSF:MSG:BC
                  40218 !TSM:FPAR:NO REPLY
                  40220 TSM:FPAR
                  40224 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  40258 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  40263 TSF:MSG:BC
                  42232 !TSM:FPAR:NO REPLY
                  42234 TSM:FPAR
                  42238 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  42304 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  42309 TSF:MSG:BC
                  44247 !TSM:FPAR:FAIL
                  44249 TSM:FAIL:CNT=3
                  44250 TSM:FAIL:DIS
                  44252 TSF:TDI:TSL
                  54255 TSM:FAIL:RE-INIT
                  54257 TSM:INIT
                  54263 TSM:INIT:TSP OK
                  54265 TSM:INIT:STATID=5
                  54268 TSF:SID:OK,ID=5
                  54270 TSM:FPAR
                  54275 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  56282 !TSM:FPAR:NO REPLY
                  56284 TSM:FPAR
                  56288 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  56393 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  56398 TSF:MSG:BC
                  58296 !TSM:FPAR:NO REPLY
                  58298 TSM:FPAR
                  58302 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  58434 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  58439 TSF:MSG:BC
                  59362 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  59367 TSF:MSG:BC
                  It still cant find the Gateway, and I see it reads Node 7 and 2 request for registration too.
                  • E
                    E
                    eiten
                    So the sensors do not receive Messages from the gateway, but not from other sensors. Is the nrf24 on the gateway a module with PA? Then maybe test different PA settings, this helped once on a setup here.
                    BTW: Your picture is not visible: access denied
                    • E eiten
                      EmeE
                      EmeE
                      Eme
                      @eiten based on the suggestions "leaning towards" powering the rf24 from you and @mfalkvidd l fed the radio a regulated 3.3 with LD33V and l also brought the capacitator near the radio... yet I still cant register the nodes.
                      Pls what does "TSF:CKU:OK:FCTRL" mean?
                      • E
                        E
                        eiten
                        @Eme said in MySensors Raspberry Pi Gateway + Domotics Controller:
                        TSF:CKU:OK,FCTRL
                        Uplink OK, flood control prevents pinging GW in too short intervals
                        • E eiten
                          TSF:CKU:OK,FCTRL
                          EmeE
                          EmeE
                          Eme
                          @eiten Yes what does that mean in English: :blush:
                          • EmeE Eme
                            EmeE
                            EmeE
                            Eme
                            @eiten Don't know if the Pi model matters. I used a Pi Model A with wifi.
                            • E
                              E
                              eiten
                              @Eme did'nt I write English :grinning:
                              So, if you look at the source:
                              bool transportCheckUplink(const bool force)
                                      if (!force && (hwMillis() - _transportSM.lastUplinkCheck) < MY_TRANSPORT_CHKUPL_INTERVAL_MS) {
                                              TRANSPORT_DEBUG(PSTR("TSF:CKU:OK,FCTRL\n"));    // flood control
                                              return true;
                              The transport prevented an uplink check, since the last was done less then MY_TRANSPORT_CHKUPL_INTERVAL_MS milliseconds ago (defaults to 10 seconds)
                              • EmeE Eme
                                E
                                E
                                eiten
                                Sure? AFAIK A had no WiFi. Or do you use a USB dongle?
                                • E eiten
                                  EmeE
                                  EmeE
                                  Eme
                                  @eiten l think it's A+ it has Wifi and l run it "headless" with my old Nano Gateway connected to the 1 USB. But I'll looking forward to getting the Pi to work as both Gateway and Controller.
                                  I want to use a prototype board and drop the long lines. Plus I'll also bring the cap closer to the nrf24 to see if that helps.
                                  • EmeE Eme
                                    E
                                    E
                                    eiten
                                    @Eme i usually solder a tantalum directly to the pins on the top side of the board :blush:
                                    • EmeE
                                      EmeE
                                      Eme
                                      I have good news. I used a small prototype board for everything. made sure no line was more than 6 inches long. I soldered (My soldering sucks!) the capacitator right next to the radio and Bahm! Domoticz picked up all powered devices. :grinning:
                                      Lessons learnt, keep length of your wires short, nRf24 MUST have a decent capacitator to smoothen out power. Don't rely on GPIO pins to power it, use a regulator. Though help may come from all and sundry, its all up to you to check their suggestions... Thanks all for helping me.
                                      I can finally retire my Nano-Serial Gateway! Wont be upgrading for a long time to come :sneezing_face:
                                      mfalkviddM zookazimZ 2 Replies Last reply
                                      • EmeE Eme
                                        Great work @Eme! Thanks for reporting the result.
                                          EmeE
                                          EmeE
                                          Eme
                                          @mfalkvidd so how do I change the title to reflect "SOLVED"?
                                          YveauxY 1 Reply Last reply
