  3. Ethernet Gateway Library
gateway
6 Posts 2 Posters 1.2k Views 2 Watching
  • R
    R
    Rez
    Hello everybody.
    I'm work on ethernet gateway.
    I used from meny library for run this but it gives errors.
    Can you please run this code in your Arduino ide and if it work ,send me your libraries?
    It's very important to me.
    code EthernetGateway
    • R Rez
      Hello everybody.
      Welcome to the forum @Rez
      That code looks like it was made for MySensors 1.x, which quite old.
      Try the latest version instead: https://www.mysensors.org/build/ethernet_gateway
      • R
        R
        Rez
        Thank you Mr @mfalkvidd .
        I found the library of this code but got the following error.
        • R
          R
          Rez
          Mr @mfalkvidd
          I want to recive data from this code:meter
          how i get this data with your ethernet gateway code:GatewayW5100.ino
          can you Please fill in (void setup) and (void presentation) and (void loop) according to the meter code? I thank you very much.
          • R Rez
            Mr @mfalkvidd
            @Rez sorry, that sketch is way too complex for me to understand.
            • R
              R
              Rez
              thanks Mr @mfalkvidd .
