  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 35.8k Views 40 Watching
  • H haloway13
    @ncollins
    I will check tonight.
    I really appreciate all help so far.
    When you refer to the broker password: do you mean when you install the mqtt using the openhabian-config utility from the command line while being logged in with ssh to the Pi?
    N
    N
    ncollins
    @haloway13 yeah, when you did the initial mqtt setup, did you protect it with a password? If not, make sure you clear out the username and password from the OpenHAB broker settings. (I’m not sure if it will fail if you provide credentials to an instance that is not password protected)
    • fabyteF fabyte
      @haloway13 I had exactly the same problem.
      Here is what I did to fix it:
      1. uninstalled the mqtt binding
        1.1 make sure the /opt/openhab/userdata/config/org/openhab/mqttbroker.config is removed
      2. installed the mqtt binding
      3. setup the system broker
      After that, the system broker connection could be established and the Try to restore connection to '192.168.1.151'. Next attempt in 60000ms messaged disappeared.
      Then you can proceed and set up the MySensors MQTT Bridge.
      H
      H
      haloway13
      @fabyte
      I am not showing such a file as mentioned in 1.1
      2 & 3 refer to using the web interface?
      Thanks!
      fabyteF N 2 Replies Last reply
      • H haloway13
        @fabyte
        Thanks!
        fabyteF
        fabyteF
        fabyte
        @haloway13 Yes, everything via the web interface
        • H haloway13
          @fabyte
          Thanks!
          N
          N
          ncollins
          wrote on last edited by ncollins
          #64
          @haloway13 Here are all of my settings in my sandbox environment.
          A couple things to note, NO MQTT BINDING INSTALLED, no special MQTT thing configured, my mqtt install is not password protected.
          Screen Shot 2021-03-05 at 12.49.22 PM.png Screen Shot 2021-03-05 at 12.53.23 PM.png Screen Shot 2021-03-05 at 12.54.34 PM.png Screen Shot 2021-03-05 at 12.55.27 PM.png Screen Shot 2021-03-05 at 12.55.50 PM.png Screen Shot 2021-03-05 at 1.01.14 PM.png
          My Gateway code:
          //#define MY_RADIO_RF24
          //#define MY_RADIO_RFM95
          #define MY_GATEWAY_ESP8266
          #define MY_BAUD_RATE 9600
          #define MY_MQTT_CLIENT_ID "MYSGW01"
          #define MY_MQTT_PUBLISH_TOPIC_PREFIX "tele/mysgw01-out"
          #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX  "cmnd/mysgw01-in"
          // Set MQTT client id
          // Enable these if your MQTT broker requires username/password
          // Set WIFI SSID and password
          #define MY_WIFI_SSID "--------"
          #define MY_WIFI_PASSWORD "*********"
          // passed to the DHCP server if not static.
          #define MY_HOSTNAME MY_MQTT_CLIENT_ID
          // MQTT broker ip address.
          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 62
          //MQTT broker if using URL instead of ip address.
          // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
          #define MY_PORT 1883
          // Enable inclusion mode
          //#define MY_INCLUSION_MODE_BUTTON_PIN D1
          // Set blinking period
          //#define MY_DEFAULT_LED_BLINK_PERIOD 300
          // Flash leds on rx/tx/err
          //#define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
          #include <ArduinoOTA.h>
            pinMode(LED_BUILTIN, OUTPUT);
           ArduinoOTA.setHostname(MY_HOSTNAME);
            ArduinoOTA.onStart([]() {
              Serial.println("ArduinoOTA start");
            ArduinoOTA.onEnd([]() {
              Serial.println("\nArduinoOTA end");
            ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
              Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
            ArduinoOTA.onError([](ota_error_t error) {
              Serial.printf("Error[%u]: ", error);
              if (error == OTA_AUTH_ERROR) {
                Serial.println("Auth Failed");
              } else if (error == OTA_BEGIN_ERROR) {
                Serial.println("Begin Failed");
              } else if (error == OTA_CONNECT_ERROR) {
                Serial.println("Connect Failed");
              } else if (error == OTA_RECEIVE_ERROR) {
                Serial.println("Receive Failed");
              } else if (error == OTA_END_ERROR) {
                Serial.println("End Failed");
            ArduinoOTA.begin();
            sendSketchInfo("MYSGW01-TEST Gateway","1.0");
            present(0, S_BINARY);
             ArduinoOTA.handle();
              if (message.type==V_STATUS) {
                  // Change relay state
                  digitalWrite(LED_BUILTIN, message.getBool() ? LOW:HIGH);
                  // Store state in eeprom
                  // Write some debug info
                  Serial.print(message.sensor);
          H 1 Reply Last reply
          • N ncollins
            My Gateway code:
              ArduinoOTA.begin();
            H
            H
            haloway13
            wrote on last edited by haloway13
            #65
            @ncollins
            Thank you so much. This has gotten me so much closer to actually getting the test temp and humidity arduino thing working.
            I am seeing this output from the mysensors gateway:
            Mar 05 22:55:07 DEBUG GWT:RMQ:OK
            Mar 05 22:55:07 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
            Mar 05 22:55:07 DEBUG TSM:READY:NWD REQ
            Mar 05 22:55:07 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            Mar 05 22:55:07 DEBUG TSF:MSG:READ,1-1-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
            Mar 05 22:55:07 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/255/3/0/21,MSG SENT
            Mar 05 22:55:41 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
            Mar 05 22:55:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
            Mar 05 22:55:51 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
            Mar 05 22:55:51 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
            Mar 05 22:57:01 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.1
            Mar 05 22:57:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
            Mar 05 22:57:11 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
            Mar 05 22:57:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
            Mar 05 22:57:41 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
            Mar 05 22:57:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
            Mar 05 22:59:01 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
            Mar 05 22:59:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
            Mar 05 22:59:21 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.9
            Mar 05 22:59:21 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
            Mar 05 22:59:41 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
            Mar 05 22:59:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
            Mar 05 23:00:51 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
            Mar 05 23:00:51 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
            Mar 05 23:01:11 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.7
            Mar 05 23:01:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
            Mar 05 23:01:21 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
            My Sensors Gateway configuration: not letting me upload the image/screenshot, getting an error.
            ![0_1615011411135_SS_2021-03-05_23-09-13.jpg](Uploading 100%)
            Humidity Sensor thing: same problem here.
            ![0_1615011449159_SS_2021-03-05_23-12-48.jpg](Uploading 100%)
            I will try to edit this in the morning
            The short of it is that I am not seeing the values I am expecting from the sensor. I am leaning towards just not identifying the id/node for each of the things/channel.
            • H
              H
              haloway13
              #66
              Here is the humidity sensor thing page:
              Here is the temperature:
              Do I have the node and child id right? What should I check?
              Or maybe I need to do a follow on configuration to see the values?
              Thank you!
              N 1 Reply Last reply
              • H haloway13
                Thank you!
                N
                N
                ncollins
                @haloway13 progress!
                Check the channels tab of your temperature sensor thing:
                "Add link to item" then follow the directions to create a new item
                • N ncollins
                  H
                  H
                  haloway13
                  @ncollins
                  I tried just as you describe. However I think something is failing before this should be expected to succeed.
                  Thoughts?
                  openhab> log:tail
                  22:37:44.426 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                  22:37:44.428 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mygateway1-out/+/+/+/+/+
                  22:37:44.434 [WARN ] [protocol.mqtt.MySensorsMqttConnection] - Skipping I_VERSION connection test, not recommended...
                  22:37:44.438 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:3976df7e54' changed from INITIALIZING to ONLINE
                  22:37:44.446 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
                  22:37:44.443 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                  22:37:44.451 [INFO ] [protocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
                  22:37:44.454 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                  22:37:44.460 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  22:37:44.464 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                  22:37:44.465 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  22:37:44.467 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                  22:37:44.469 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Merging child map: {1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]} with: {0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}
                  22:37:44.472 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                  22:37:44.474 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                  22:37:44.479 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from INITIALIZING to ONLINE
                  22:41:47.918 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from ONLINE to UNINITIALIZED
                  22:41:47.936 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                  22:41:49.778 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                  22:41:49.786 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  22:41:49.788 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                  22:41:49.791 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                  22:41:49.795 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                  22:41:51.075 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from ONLINE to UNINITIALIZED
                  22:41:51.090 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                  22:41:51.806 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                  22:41:51.814 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  22:41:51.817 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                  22:41:51.819 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                  22:41:51.825 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                  22:42:06.748 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from ONLINE to UNINITIALIZED
                  22:42:06.762 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                  22:42:07.739 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                  22:42:07.749 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  22:42:07.751 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}]
                  22:42:07.753 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                  22:42:07.756 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from INITIALIZING to ONLINE
                  22:51:49.195 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuation update for thing 1-1: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=18, nodeId=1, revertState=true, requestAck=false}
                  22:51:49.214 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=18, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  22:51:49.217 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={18=MySensorsChild [childId=18, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                  22:51:49.218 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-18 not registered yet, registering...
                  23:01:04.984 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Temperature
                  23:01:08.762 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: TemperatureSensor_Temperature
                  23:04:05.921 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: TemperatureSensor_Variable1
                  23:05:12.626 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuation update for thing 1-18: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=0, nodeId=1, revertState=true, requestAck=false}
                  23:05:12.636 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  23:05:12.638 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                  23:05:12.643 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                  22:35:59.095 [WARN ] [orsAbstractConnection$MySensorsWriter] - Message returned from queue is null
                  22:37:44.434 [WARN ] [orsAbstractConnection$MySensorsWriter] - Message returned from queue is null
                  • H haloway13
                    @ncollins
                    Thoughts?
                    openhab> log:tail
                    N
                    N
                    ncollins
                    @haloway13 can you send a screenshot of your item?Screen Shot 2021-03-08 at 9.09.23 AM.png
                    • N ncollins
                      H
                      H
                      haloway13
                      @ncollins
                      • H haloway13
                        @ncollins
                        N
                        N
                        ncollins
                        @haloway13 Can you post your sketch?
                        Your humidity sensor and your temperature sensor Thing configurations both point to Child Id = 0. I think your humidity sensor should be Child Id = 1.
                        • N ncollins
                          H
                          H
                          haloway13
                          #72
                          @ncollins
                          Fixed the child ID. Good catch. No change.
                          Here is the sketch
                          #include <DHT.h>
                          #define MY_DEBUG 1
                          #define MY_NODE_ID 1
                          #define CHILD_ID_TEMP 0
                          #define CHILD_ID_HUM 1
                          #define DHT_DATA_PIN 3
                          #define SENSOR_TEMP_OFFSET 0
                          /****************** CONSTANTS *********************/
                          static const uint64_t UPDATE_INTERVAL = 10000;
                          /****************** VARIABLES *********************/
                          float lastTemp;
                          float lastHum;
                          float temperature;
                          float humidity;
                          uint8_t nNoUpdatesTemp;
                          uint8_t nNoUpdatesHum;
                          /****************** MESSAGES **********************/
                          DHT dht;
                          present(CHILD_ID_HUM, S_HUM);
                          delay(2000); //Wait 2 seconds before starting sequence
                          if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod())
                          dht.setup(DHT_DATA_PIN);
                          sendTemperatureHumiditySensor();
                          wait(UPDATE_INTERVAL);
                          /**************** AUX. FUNCTIONS ******************/
                          void sendTemperatureHumiditySensor()
                          dht.readSensor(true);
                          temperature = dht.getTemperature();
                          humidity = dht.getHumidity();
                          if (isnan(temperature))
                          } else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
                          lastTemp = temperature;
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                          Serial.print("T: ");
                          Serial.println(temperature);
                          } else
                          nNoUpdatesTemp++;
                          if (isnan(humidity))
                          } else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS)
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                          Serial.print("H: ");
                          Serial.println(humidity);
                          } else
                          nNoUpdatesHum++;
                          I am able to see the debug output from the sensors
                          • H haloway13
                            @ncollins
                            Here is the sketch
                            #include <DHT.h>
                            #define MY_DEBUG 1
                            float lastTemp;
                            float lastHum;
                            float temperature;
                            float humidity;
                            DHT dht;
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                            } else
                            nNoUpdatesTemp++;
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                            } else
                            nNoUpdatesHum++;
                            N
                            N
                            ncollins
                            @haloway13 I mean, last suggestion is restarting your openhab instance. If that doesn't work, please post your openhab log.
                            H 2 Replies Last reply
                            • N ncollins
                              H
                              H
                              haloway13
                              @ncollins
                              My sdcard corrupted, had to restart from scratch. Hopefully, I can get back to the same point tonight.
                              Thanks!
                              • N ncollins
                                H
                                H
                                haloway13
                                @ncollins QQ: Did you install mosquitto through the openhabian-config utility?
                                • H haloway13
                                  H
                                  H
                                  haloway13
                                  @haloway13
                                  I assumed yes since the log was showing no connection to MQTT
                                  I am now getting this error:
                                  20:56:49.983 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid cc150d9b-7fcc-45d0-93d2-00ad80ddb9a9
                                  20:56:50.005 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
                                  com.hivemq.client.mqtt.exceptions.ConnectionClosedException: java.io.IOException: Connection reset by peer
                                  Caused by: java.io.IOException: Connection reset by peer
                                  	at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
                                  	at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:?]
                                  	at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:276) ~[?:?]
                                  	at sun.nio.ch.IOUtil.read(IOUtil.java:233) ~[?:?]
                                  	at sun.nio.ch.IOUtil.read(IOUtil.java:223) ~[?:?]
                                  	at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:358) ~[?:?]
                                  	at io.netty.buffer.PooledByteBuf.setBytes(PooledByteBuf.java:247) ~[bundleFile:4.1.42.Final]
                                  	at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1147) ~[bundleFile:4.1.42.Final]
                                  	at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:347) ~[bundleFile:4.1.42.Final]
                                  	at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:148) [bundleFile:4.1.42.Final]
                                  	at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
                                  	at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
                                  	at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
                                  	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
                                  	at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
                                  	at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
                                  	at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
                                  	at java.lang.Thread.run(Thread.java:834) [?:?]
                                  • H haloway13
                                    @haloway13
                                    H
                                    H
                                    haloway13
                                    #77
                                    @haloway13
                                    @ncollins
                                    Woot!!! massive success!!!
                                    in /srv/openhab-userdata/config/org/openhab/mqttbroker.config
                                    added at the end secure="false"
                                    as you suggested.
                                    21:42:04.192 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.1 to 33.3
                                    21:42:54.224 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.2
                                    21:42:54.226 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
                                    21:42:54.228 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.2
                                    21:42:54.231 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.2
                                    21:42:54.234 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                    21:42:54.236 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
                                    21:42:54.238 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.2
                                    21:42:54.244 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.3 to 33.2
                                    21:42:54.246 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:42:54.000-0700
                                    21:43:04.250 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.3
                                    21:43:04.252 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
                                    21:43:04.253 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.3
                                    21:43:04.260 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.3
                                    21:43:04.262 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                    21:43:04.263 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
                                    21:43:04.265 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.3
                                    21:43:04.270 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.2 to 33.3
                                    21:43:04.271 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:43:04.000-0700
                                    21:43:14.266 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.2
                                    21:43:14.268 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
                                    21:43:14.271 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.2
                                    21:43:14.276 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.2
                                    21:43:14.278 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                    21:43:14.280 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
                                    21:43:14.281 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.2
                                    21:43:14.285 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.3 to 33.2
                                    21:43:14.286 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:43:14.000-0700
                                    • H haloway13
                                      @haloway13
                                      @ncollins
                                      as you suggested.
                                      N
                                      N
                                      ncollins
                                      @haloway13 Yes!! Impressive perseverance.
                                      Somehow I've become emotionally invested in your outcome, so this is extremely satisfying. Great work.
                                      • N ncollins
                                        H
                                        H
                                        haloway13
                                        @ncollins
                                        I could not have done it without you! I really appreciate the feedback and continued support. I would not have continued without it.
                                        Now... to get the darn data to display both in C and F. I am missing something conceptually.
                                        I should probably do this in another thread after I completely document all the steps I have done for posterity.
                                        Thanks again!
                                        • H haloway13
                                          @ncollins
                                          Thanks again!
                                          N
                                          N
                                          ncollins
                                          @haloway13 oooof, I found that to be confusing too.
                                          If your platform settings Settings -> Regional Settings [advanced] -> Metric / Imperial are set,
                                          and you define your items as Number:Temperature, they should "magically" display in the correct format and auto converted, but I've had a lot of trouble with that.
                                          There are also settings to have the gateway confirm "isMetric" and have you node respond in the appropriate unit.
                                          Lastly, in your item definition, you can "Add Metadata" -> State Description, and set a display format that supposedly converts value, but I'm not sure I understand exactly when it's suppose to override platform settings.
                                          Screen Shot 2021-03-12 at 5.51.47 PM.png Screen Shot 2021-03-12 at 5.52.00 PM.png
                                          More info here: https://community.openhab.org/t/solved-the-right-place-to-do-temperature-conversion/91233
