  3. Why is the output of ACS712 current measurement module unchanged?
mysensors
4 Posts 4 Posters 1.5k Views 4 Watching
  • Tessie TT
    Tessie TT
    Tessie T
    Banned
    Why is the output of [ACS712](dee940ca-34bd-42c3-b68d-c288c88b4412-image.png link url) current measurement module unchanged? I connected 5.0V to VCC, and the output is always 2.56V. After connecting the current of 2-5A in series, the output has not changed. I use an AC power supply, and I directly use an AC voltage regulator to connect the thermal, serial current. Does anyone know the reason?
    • skywatchS
      skywatchS
      skywatch
      I think you need to post a clear drawing or photos of the setup and the code you are using.
      I donlt know what you mean by "connecting the current in series" nor what "AC regulator" you are using or what "thermal serial currenr" is.
      • ZenBlizzardZ
        ZenBlizzardZ
        ZenBlizzard
        It seems the ACS712 current measurement module may not show expected changes due to setup issues, like incorrect wiring or misunderstanding of signal interpretation. Checking if you're measuring the right type of current (AC vs. DC) and ensuring your connections are correct can often resolve this.
        F 1 Reply Last reply
        • ZenBlizzardZ ZenBlizzard
          F
          F
          fsgraz
          @ZenBlizzard in case you are measuring the output with a multimeter, you will get an averaged level, since AC current waveform should be sinusoidal and overlapped with the Vcc/2->2.56V in your case.
          To measure the current you need a decently high sampling and some math.
          #define SENSITIVITY	66		// mV/A
          const float readings = 5;
          const float alpha = 2.0 / (2 * readings + 1);
          for (ifor = 0; ifor < 250; ifor++)
          		// Voltage
          		voltageSampleRead = analogRead(V) * vccRead / 1023 - vccRead / 2;	/* read the sample value including offset value*/
          		voltageSampleSum = voltageSampleSum + sq(voltageSampleRead);		/* accumulate total analog values for each sample readings*/
          		voltageSampleOffsetSum = voltageSampleOffsetSum + voltageSampleRead;
          		// Current
          		currentSampleRead = analogRead(I) * vccRead / 1023 - vccRead / 2;	/* read the sample value including offset value*/
          		currentSampleSum = currentSampleSum + currentSampleRead * currentSampleRead;		/* accumulate total analog values for each sample readings*/
          		currentSampleOffsetSum = currentSampleOffsetSum + currentSampleRead;
          		wait(1);
          	voltageMean = voltageSampleSum / ifor;				/* calculate average value of all sample readings taken*/
          	voltageOffset = voltageSampleOffsetSum / ifor;
          	reading = (sqrt(voltageMean) - voltageOffset) * 230.0 / 1.0;		// read voltage / reported voltage.
          	voltage = round_to_dp(alpha * reading + (1 - alpha) * voltage,1);
          	Serial.println(voltage);
          	if (voltage < 25) voltage = 0;
          	currentMean = currentSampleSum / ifor;				/* calculate average value of all sample readings taken*/
          	currentOffset = currentSampleOffsetSum / ifor;
          	reading = (sqrt(currentMean) - currentOffset) / SENSITIVITY * 1000 - currentZeroOffset;		// subtract no load current.
          	if (reading < 0) reading = 0;
          	current = round_to_dp( alpha * reading + (1 - alpha) * current,2);
