  3. Basic Lcd Node
Basic Lcd Node
7 Posts 4 Posters 4.6k Views 3 Watching
  • andyunoA
    andyunoA
    andyuno
    wrote on last edited by andyuno
    Is there someone who can tell me where I'm going wrong, here I can't seem to get the data from another node, Am I missing something here or do I have to put something in on my transmitting node, not sure where to go from here.:confused: HELP! Please.
    Thanks Andy
    #include <Wire.h>
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define LIGHT_SENSOR_ANALOG_PIN 0
    unsigned long SLEEP_TIME = 100; // Sleep time between reads (in milliseconds) (We do calculations and wait 5 ms between readings)
    int readingscounter      = 0;
    LiquidCrystal_I2C lcd(0x27, 16, 2);
    //DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    int lastLightLevel;
      gw.begin();
      //DHT.setup(HUMIDITY_SENSOR_DIGITAL_PIN); 3
      gw.sendSketchInfo("Hum-Temp-Light-Lcd", "1.0");
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
      gw.present(CHILD_ID_LIGHT, V_HUM);
      gw.present(CHILD_ID_TEMP, V_TEMP);
      delay(3000);
       int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
         // gw.send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      lcd.init();
      lcd.clear();
      lcd.backlight() ;
      lcd.setCursor(0, 0);
      lcd.print("Temperature: ");
      lcd.print("C ");
      lcd.print(V_TEMP );
      lcd.setCursor(0, 1);
      lcd.print("Humidity:    ");
      lcd.print("% ");
      lcd.print(V_HUM );
    :) Any Help is Appreciated Thank You.
    • FotoFieberF
      FotoFieberF
      FotoFieber
      It is just a bunch of code from the internet.... maybe it is useful for you :smiley:
      #include <Time.h>
      #include <Wire.h>
      #include <Timezone.h>    //https://github.com/JChristensen/Timezone
      #include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
      //Central European Time (Frankfurt, Paris)
      TimeChangeRule CEST = {"CEST", Last, Sun, Mar, 2, 120};     //Central European Summer Time
      TimeChangeRule CET = {"CET ", Last, Sun, Oct, 3, 60};       //Central European Standard Time
      Timezone CE(CEST, CET);
      boolean timeReceived = false;
      unsigned long lastUpdate = 0, lastRequest = 0;
      // Sensor IDs
      #define ID_LINE2 1
      #define ID_LINE3 2
      #define ID_LINE4 3
      #define LINE_LENGTH 20
      LiquidCrystal_I2C lcd(0x27, 20, 4);
      TimeChangeRule *tcr;        //pointer to the time change rule, use to get the TZ abbrev
      time_t utc;
         // Attach RTC
       setSyncProvider(RTC.get);   // the function to get the time from the RTC
       setSyncInterval(60);
       if (timeStatus() != timeSet)
         Serial.println("Unable to sync with the RTC");
       else
         Serial.println("RTC has set the system time");
       Serial.println("Starte Gateway");
       gw.sendSketchInfo("Display Sensor 4x20", "1.0");
       gw.present(ID_LINE2, S_CUSTOM);
       gw.present(ID_LINE3, S_CUSTOM);
       gw.present(ID_LINE4, S_CUSTOM);
       // Request latest time from controller at startup
       gw.requestTime(receiveTime);
       Serial.println("Starte LCD");
       // initialize the lcd for 16 chars 2 lines and turn on backlight
       lcd.begin();
       if ((message.sensor >= ID_LINE2) && (message.sensor <= ID_LINE4)) {
         int iline = message.sensor - ID_LINE2 + 1;
         lcd.setCursor(0, iline);
         String sLine = message.getString();
         if (sLine.length() > LINE_LENGTH) {
           sLine = sLine.substring(0, 19);
         lcdPrint(sLine);
         // Todo: Check if this is efficient enough
         for (int i = sLine.length(); i < LINE_LENGTH; i++) lcd.print(" ");
      // This is called when a new time value was received
      void receiveTime(unsigned long controllerTime) {
       // Ok, set incoming time
       Serial.print("Time value received: ");
       Serial.println(controllerTime);
       RTC.set(controllerTime); // this sets the RTC to the time from controller - which we do want periodically
       setTime(controllerTime);
       timeReceived = true;
       unsigned long now = millis();
       gw.process();
       // If no time has been received yet, request it every 10 second from controller
       // When time has been received, request update every hour
       if ((!timeReceived && now - lastRequest > 10 * 1000)
           || (timeReceived && now - lastRequest > 120 * 1000 * 60)) {
         // Request time from controller.
         Serial.println("requesting time");
         lastRequest = now;
       // Update display every second
       if (now - lastUpdate > 1000) {
         updateDisplay();
         lastUpdate = now;
      void updateDisplay() {
       // Print date and time
       lcd.home();
       utc = now();
       printTime(CE.toLocal(utc, &tcr), tcr -> abbrev, "Zurich");
      void printTime(time_t t, char *tz, char *loc)
       sPrintI00(hour(t));
       sPrintDigits(minute(t));
       sPrintDigits(second(t));
       lcd.print(' ');
       sPrintI00(day(t));
       lcd.print('.');
       sPrintI00(month(t));
       lcd.print('.');
       lcd.print(year(t));
      void sPrintI00(int val)
       if (val < 10) lcd.print('0');
       lcd.print(val, DEC);
       return;
      void sPrintDigits(int val)
       lcd.print(':');
      void lcdPrint(String line)
      //  for HD44780 controller with ROM character set A00
       for(byte i=0;i<line.length();i++)
         Serial.println((byte)line.charAt(i));
         switch ((byte)line.charAt(i))
         case 0xC2: Serial.print("C2");
         break;
         case 0xC3: Serial.print("C3");
         break;
         case 0xCE: Serial.print("CE");
         break;
         case 0xCF: Serial.print("CF");
         break; // filtering UTF-8 highbyte
         case 164: lcd.print('\xE1');break; // translate UTF-8 lowbyte
         case 182: lcd.print('\xEF');break; // translate UTF-8 lowbyte
         case 188: lcd.print('\xF5');break; // translate UTF-8 lowbyte
         case 176: lcd.print('\xDF');break; // degree symbol
         default: lcd.print(line.charAt(i));
      It is for a 4x20 LCD and uses an RTC. On the first line of the LCD you can see date an time. The other lines can show whatever you want....
      This code only works, if you have a gateway implementing requestTime and with a DS1307RTC.
      andyunoA 1 Reply Last reply
      • FotoFieberF FotoFieber
        #include <Time.h>
        #include <Wire.h>
        // Sensor IDs
        #define ID_LINE2 1
        #define ID_LINE3 2
        #define ID_LINE4 3
        time_t utc;
           // Attach RTC
         else
         lcd.begin();
           lcdPrint(sLine);
         gw.process();
           lastRequest = now;
           updateDisplay();
           lastUpdate = now;
         lcd.home();
         utc = now();
         sPrintI00(hour(t));
         lcd.print(' ');
         sPrintI00(day(t));
         lcd.print('.');
         lcd.print('.');
         lcd.print(year(t));
         return;
         lcd.print(':');
           break;
           break;
           break;
        andyunoA
        andyunoA
        andyuno
        @FotoFieber Thank you for your response much appreciated I'm not much of a coder but I can feel my way through if I have examples to work from and this will help a bit .
        Thank you Andy.
        • andyunoA
          andyunoA
          andyuno
          Having a bit of problem receiving Data from another node am I missing something here or do I need to add something to the transmitting node. Just can't think where to go from here.:confused: HELP! Please.
          Andy.
          #include <Wire.h>
          #include <DHT.h>
          //DHT dht;
          float lastTemp;
          float lastHum;
          int lastLightLevel;
            gw.begin();
            delay(3000);
            lcd.init();
            lcd.clear();
            lcd.backlight() ;
            lcd.print("C ");
            lcd.print(V_TEMP );
            lcd.print("% ");
            lcd.print(V_HUM );
          • rvendrameR
            rvendrameR
            rvendrame
            @andyuno , if you want to send Temp data from your sensor to the gateway/controller, you need uncomment the gw.send line at your code above.
            Maybe you also want to include a gw.sleep at end of loop process, to avoid too many pooling at the sensor (causes temperature increase as well as drains the battery very fast). Something like a 5-15min sleep between every loop?
            ESP8266 GW + mySensors 2.3.2
            Alexa / Google Home
            • rvendrameR rvendrame
              andyunoA
              andyunoA
              andyuno
              @rvendrame thanks I think I get what you mean I'll give that a go still not sure if I'm On the right path.
              • Lawrence HelmL
                Lawrence HelmL
                Lawrence Helm
                Did you ever get this going if so can you share the code? My project is similar have a few temp sensors around and send them to an lcd screen node. Lcd can be a repeater to the gateway for logging on domoticz, also if so what extra code did you add on the temp sensor side?
