  2. Feature Requests
  3. MQTT Request from a node
8 Posts 3 Posters 4.9k Views 2 Watching
  • L Offline
    L Offline
    lafleur
    It would be nice if a node, could make a request for MQTT data..
    ie: My node subscribe to weather/rain from my weather station, and then if its raining, the controller could change it action...
    thanks...
    • F Offline
      F Offline
      FotoFieber
      On my pi2 I have installed node-red and do all the 'wiring' of messages between different nodes there. Maybe this could be a solution for you too.
      V 1 Reply Last reply
      • L Offline
        L Offline
        lafleur
        That interesting way of doing things...
        But I believe that having native support for MQTT subscription by a node would be the ideal way to go... No wiring, no special code, just make a request, and it sent to you via the gateway. You only need to know is name string...
        • F Offline
          F Offline
          FotoFieber
          For me it is important not to wire nodes directly, because I want to be able to change any node without having to make firmware changes to others. I like this abstraction level, e.g. I can change my netatmo devices to mysensor devices without changing anything in openhab. Openhab doesn't know,what type of device is behind an item.
          • F FotoFieber
            V Offline
            V Offline
            vikasjee
            Would you like to share the details of your setup and the flow? It would really be interesting to explore...
            • F Offline
              F Offline
              FotoFieber
              wrote on last edited by FotoFieber
              It is a prototype and not finished yet.
              I use a namespace for the different technologies for the MQTT Topic:
              MyMQTT for MySensors
              Netatmo for netatmo devices
              homegear for Homematic
              nodered for messages generated fom node-red
              openHAB for the openHAB eventbus
              Most of the wiring is defined in a hashtable. As this is more of a hack, I want to clean it up before I publish it.
              Here an example for an RGB Led (MySensors) wired to openhab colorpicker and a homematic wall switch. Note: the wiring is bidirectional, I see the RGB Color in openHAB of the MySensors LED independent of the method I used to set it and openHAB doesn't know anything about Homematic or MySensors. I can evan add another UI (openHAB 2?) and other switches (MySensors Motion or Lux nodes) and everything would be in sync.
              [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"c1a0dd11.3e5f2","type":"mqtt in","name":"RGB Colorpicker","topic":"openHAB/out/RGBLight/command","broker":"ba386057.845d3","x":152.33332061767578,"y":179.66666412353516,"z":"914d079b.6eb2f8","wires":[["46c3882f.b93c78","c1246f87.3edb9"]]},{"id":"1ab94043.e546c","type":"mqtt out","name":"MyRGBLed","topic":"MyMQTT/30/1/S_LIGHT_LEVEL","qos":"","retain":"","broker":"ba386057.845d3","x":617.3333231608073,"y":98.66666412353516,"z":"914d079b.6eb2f8","wires":[]},{"id":"46c3882f.b93c78","type":"function","name":"HSV convert","func":"if (msg.payload == 'OFF') {\n    msg.payload = 'RGB 0,0,0';\n    return msg;\n} \n\nif (msg.payload == 'ON') {\n    msg.payload = 'RGB 255,255,255';\n    return msg;\n} \n\n\nvar res = msg.payload.split(\",\");\n\nh = res[0];\ns = res[1];\nv = res[2];\n\nvar r, g, b;\n\tvar i;\n\tvar f, p, q, t;\n \n\t// Make sure our arguments stay in-range\n\th = Math.max(0, Math.min(360, h));\n\ts = Math.max(0, Math.min(100, s));\n\tv = Math.max(0, Math.min(100, v));\n \n\t// We accept saturation and value arguments from 0 to 100 because that's\n\t// how Photoshop represents those values. Internally, however, the\n\t// saturation and value are calculated from a range of 0 to 1. We make\n\t// That conversion here.\n\ts /= 100;\n\tv /= 100;\n \n\tif(s == 0) {\n\t\t// Achromatic (grey)\n\t\tr = g = b = v;\n\t\t\n\t} else\n\t{\n \n\th /= 60; // sector 0 to 5\n\ti = Math.floor(h);\n\tf = h - i; // factorial part of h\n\tp = v * (1 - s);\n\tq = v * (1 - s * f);\n\tt = v * (1 - s * (1 - f));\n \n\tswitch(i) {\n\t\tcase 0:\n\t\t\tr = v;\n\t\t\tg = t;\n\t\t\tb = p;\n\t\t\tbreak;\n \n\t\tcase 1:\n\t\t\tr = q;\n\t\t\tg = v;\n\t\t\tb = p;\n\t\t\tbreak;\n \n\t\tcase 2:\n\t\t\tr = p;\n\t\t\tg = v;\n\t\t\tb = t;\n\t\t\tbreak;\n \n\t\tcase 3:\n\t\t\tr = p;\n\t\t\tg = q;\n\t\t\tb = v;\n\t\t\tbreak;\n \n\t\tcase 4:\n\t\t\tr = t;\n\t\t\tg = p;\n\t\t\tb = v;\n\t\t\tbreak;\n \n\t\tdefault: // case 5:\n\t\t\tr = v;\n\t\t\tg = p;\n\t\t\tb = q;\n\t}\n\t\n\t}\n\tr = Math.round(r * 255);\n\tg = Math.round(g * 255);\n\tb = Math.round(b * 255);\n\t\n    //var erg = {hue:h,saturation:s,value:v, red:r, green:g, blue:b};\n    \n    msg.payload = 'RGB ' + r + ',' + g + ',' + b;\n\n\n\n\nreturn msg;","outputs":1,"valid":true,"x":395.3333231608073,"y":126.66666412353516,"z":"914d079b.6eb2f8","wires":[["1ab94043.e546c","c1246f87.3edb9"]]},{"id":"c1246f87.3edb9","type":"debug","name":"","active":true,"console":"false","complete":"false","x":621.3333129882812,"y":255.6666488647461,"z":"914d079b.6eb2f8","wires":[]},{"id":"e8effb31.171008","type":"mqtt in","name":"RGBLED Returncode Lichwert","topic":"MyMQTT/30/2/V_LIGHT_LEVEL","broker":"ba386057.845d3","x":195.99996948242188,"y":240.66665649414062,"z":"914d079b.6eb2f8","wires":[["a5d4d602.5a2b28"]]},{"id":"a5d4d602.5a2b28","type":"function","name":"RGB to HSV","func":"b = msg.payload % 256 ;\ng = ((msg.payload - b) / 256) % 256;\nr = (msg.payload - b - g*256) / 256 / 256;\n\n\t\n    r = r/255, g = g/255, b = b/255;\n    var max = Math.max(r, g, b), min = Math.min(r, g, b);\n    var h, s, v = max;\n\n    var d = max - min;\n    s = max == 0 ? 0 : d / max;\n\n    if(max == min){\n        h = 0; // achromatic\n    }else{\n        switch(max){\n            case r: h = (g - b) / d + (g < b ? 6 : 0); break;\n            case g: h = (b - r) / d + 2; break;\n            case b: h = (r - g) / d + 4; break;\n        }\n        h /= 6;\n    }\n\n    h *=360;\n    s*=100;\n    v*=100;\n\n\t\n// var erg = {hue:h,saturation:s,value:v, red:r, green:g, blue:b};\n    \nmsg.payload = h + ',' + s + ',' + v;\n\n\nreturn msg;","outputs":1,"valid":true,"x":505.3333231608073,"y":343.66666412353516,"z":"914d079b.6eb2f8","wires":[["c1246f87.3edb9","792d7484.86d28c"]]},{"id":"792d7484.86d28c","type":"mqtt out","name":"RGB in Openhab setzen","topic":"openHAB/in/RGBLight/state","qos":"","retain":"","broker":"ba386057.845d3","x":736.3333231608073,"y":339.66666412353516,"z":"914d079b.6eb2f8","wires":[]},{"id":"85a991b0.7a567","type":"mqtt in","name":"Laura Fernbedienung","topic":"homegear/1234-5678-9abc/event/10/#","broker":"ba386057.845d3","x":129,"y":36,"z":"914d079b.6eb2f8","wires":[["e913dcc9.16ec2","c1246f87.3edb9"]]},{"id":"e913dcc9.16ec2","type":"function","name":"Fernbedienung auf RGB Licht","func":"if (msg.payload != '[true]') return;\n\n\nif (msg.topic == 'homegear/1234-5678-9abc/event/10/1/PRESS_SHORT') {\n    msg.payload ='OFF';    \n} \nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/2/PRESS_SHORT') {\n    msg.payload = 'RGB 255,187,0';\n}\nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/3/PRESS_SHORT') {\n    msg.payload = 'RGB 255,0,0';\n}\nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/4/PRESS_SHORT') {\n    msg.payload = 'RGB 255,6,226';\n}\nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/5/PRESS_SHORT') {\n    msg.payload = 'RGB 177,10,255';\n}\nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/6/PRESS_SHORT') {\n    msg.payload = 'RGB 0,255,0';\n}\n\nreturn msg;","outputs":1,"valid":true,"x":388,"y":57,"z":"914d079b.6eb2f8","wires":[["1ab94043.e546c","c1246f87.3edb9"]]}]
              • F FotoFieber
                V Offline
                V Offline
                vikasjee
                @FotoFieber said:
                [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"c1a0dd11.3e5f2","type":"mqtt in","name":"RGB Colorpicker","topic":"openHAB/out/RGBLight/command","broker":"ba386057.845d3","x":152.33332061767578,"y":179.66666412353516,"z":"914d079b.6eb2f8","wires":[["46c3882f.b93c78","c1246f87.3edb9"]]},{"id":"1ab94043.e546c","type":"mqtt out","name":"MyRGBLed","topic":"MyMQTT/30/1/S_LIGHT_LEVEL","qos":"","retain":"","broker":"ba386057.845d3","x":617.3333231608073,"y":98.66666412353516,"z":"914d079b.6eb2f8","wires":[]},{"id":"46c3882f.b93c78","type":"function","name":"HSV convert","func":"if (msg.payload == 'OFF') {\n    msg.payload = 'RGB 0,0,0';\n    return msg;\n} \n\nif (msg.payload == 'ON') {\n    msg.payload = 'RGB 255,255,255';\n    return msg;\n} \n\n\nvar res = msg.payload.split(\",\");\n\nh = res[0];\ns = res[1];\nv = res[2];\n\nvar r, g, b;\n\tvar i;\n\tvar f, p, q, t;\n \n\t// Make sure our arguments stay in-range\n\th = Math.max(0, Math.min(360, h));\n\ts = Math.max(0, Math.min(100, s));\n\tv = Math.max(0, Math.min(100, v));\n \n\t// We accept saturation and value arguments from 0 to 100 because that's\n\t// how Photoshop represents those values. Internally, however, the\n\t// saturation and value are calculated from a range of 0 to 1. We make\n\t// That conversion here.\n\ts /= 100;\n\tv /= 100;\n \n\tif(s == 0) {\n\t\t// Achromatic (grey)\n\t\tr = g = b = v;\n\t\t\n\t} else\n\t{\n \n\th /= 60; // sector 0 to 5\n\ti = Math.floor(h);\n\tf = h - i; // factorial part of h\n\tp = v * (1 - s);\n\tq = v * (1 - s * f);\n\tt = v * (1 - s * (1 - f));\n \n\tswitch(i) {\n\t\tcase 0:\n\t\t\tr = v;\n\t\t\tg = t;\n\t\t\tb = p;\n\t\t\tbreak;\n \n\t\tcase 1:\n\t\t\tr = q;\n\t\t\tg = v;\n\t\t\tb = p;\n\t\t\tbreak;\n \n\t\tcase 2:\n\t\t\tr = p;\n\t\t\tg = v;\n\t\t\tb = t;\n\t\t\tbreak;\n \n\t\tcase 3:\n\t\t\tr = p;\n\t\t\tg = q;\n\t\t\tb = v;\n\t\t\tbreak;\n \n\t\tcase 4:\n\t\t\tr = t;\n\t\t\tg = p;\n\t\t\tb = v;\n\t\t\tbreak;\n \n\t\tdefault: // case 5:\n\t\t\tr = v;\n\t\t\tg = p;\n\t\t\tb = q;\n\t}\n\t\n\t}\n\tr = Math.round(r * 255);\n\tg = Math.round(g * 255);\n\tb = Math.round(b * 255);\n\t\n    //var erg = {hue:h,saturation:s,value:v, red:r, green:g, blue:b};\n    \n    msg.payload = 'RGB ' + r + ',' + g + ',' + b;\n\n\n\n\nreturn msg;","outputs":1,"valid":true,"x":395.3333231608073,"y":126.66666412353516,"z":"914d079b.6eb2f8","wires":[["1ab94043.e546c","c1246f87.3edb9"]]},{"id":"c1246f87.3edb9","type":"debug","name":"","active":true,"console":"false","complete":"false","x":621.3333129882812,"y":255.6666488647461,"z":"914d079b.6eb2f8","wires":[]},{"id":"e8effb31.171008","type":"mqtt in","name":"RGBLED Returncode Lichwert","topic":"MyMQTT/30/2/V_LIGHT_LEVEL","broker":"ba386057.845d3","x":195.99996948242188,"y":240.66665649414062,"z":"914d079b.6eb2f8","wires":[["a5d4d602.5a2b28"]]},{"id":"a5d4d602.5a2b28","type":"function","name":"RGB to HSV","func":"b = msg.payload % 256 ;\ng = ((msg.payload - b) / 256) % 256;\nr = (msg.payload - b - g*256) / 256 / 256;\n\n\t\n    r = r/255, g = g/255, b = b/255;\n    var max = Math.max(r, g, b), min = Math.min(r, g, b);\n    var h, s, v = max;\n\n    var d = max - min;\n    s = max == 0 ? 0 : d / max;\n\n    if(max == min){\n        h = 0; // achromatic\n    }else{\n        switch(max){\n            case r: h = (g - b) / d + (g < b ? 6 : 0); break;\n            case g: h = (b - r) / d + 2; break;\n            case b: h = (r - g) / d + 4; break;\n        }\n        h /= 6;\n    }\n\n    h *=360;\n    s*=100;\n    v*=100;\n\n\t\n// var erg = {hue:h,saturation:s,value:v, red:r, green:g, blue:b};\n    \nmsg.payload = h + ',' + s + ',' + v;\n\n\nreturn msg;","outputs":1,"valid":true,"x":505.3333231608073,"y":343.66666412353516,"z":"914d079b.6eb2f8","wires":[["c1246f87.3edb9","792d7484.86d28c"]]},{"id":"792d7484.86d28c","type":"mqtt out","name":"RGB in Openhab setzen","topic":"openHAB/in/RGBLight/state","qos":"","retain":"","broker":"ba386057.845d3","x":736.3333231608073,"y":339.66666412353516,"z":"914d079b.6eb2f8","wires":[]},{"id":"85a991b0.7a567","type":"mqtt in","name":"Laura Fernbedienung","topic":"homegear/1234-5678-9abc/event/10/#","broker":"ba386057.845d3","x":129,"y":36,"z":"914d079b.6eb2f8","wires":[["e913dcc9.16ec2","c1246f87.3edb9"]]},{"id":"e913dcc9.16ec2","type":"function","name":"Fernbedienung auf RGB Licht","func":"if (msg.payload != '[true]') return;\n\n\nif (msg.topic == 'homegear/1234-5678-9abc/event/10/1/PRESS_SHORT') {\n    msg.payload ='OFF';    \n} \nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/2/PRESS_SHORT') {\n    msg.payload = 'RGB 255,187,0';\n}\nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/3/PRESS_SHORT') {\n    msg.payload = 'RGB 255,0,0';\n}\nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/4/PRESS_SHORT') {\n    msg.payload = 'RGB 255,6,226';\n}\nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/5/PRESS_SHORT') {\n    msg.payload = 'RGB 177,10,255';\n}\nelse if (msg.topic == 'homegear/1234-5678-9abc/event/10/6/PRESS_SHORT') {\n    msg.payload = 'RGB 0,255,0';\n}\n\nreturn msg;","outputs":1,"valid":true,"x":388,"y":57,"z":"914d079b.6eb2f8","wires":[["1ab94043.e546c","c1246f87.3edb9"]]}]```
                Seems to be some simple syntax error here. Is there a way to find out these kind of errors in some editor or visual tools? NodeRED import from clipboard doesnt even let it go any further.
                • F Offline
                  F Offline
                  FotoFieber
                  Please try again. Lesson learned: Don't answer posts on holiday with a tablet... :+1:
