  3. Vera
  4. Scene too fast for gateway?
55 Posts 6 Posters 32.3k Views 3 Watching
  • Z Zeph
    Has it been determined that the messages are getting to the gateway's radio (transmitter)? If so, then caps on the nRF24L01's power supply may indeed help if power sag is the issue; if not, then we're looking in the wrong place and some of the other suggestions may be relevant.
    IF it's about power sag in the radio, that may require large caps. Sometimes small caps help the radio, if it's having problems with high frequency spikes and noise in the power supply. But if the problem occurs over hundreds of uSec (one packet affecting the following one) then it would be very low frequency and relatively long duration.
    However, a better power supply would be a better solution if so. A scope (even an arduino based software scope given the frequencies involved) might help determine if the supply is really the problem.
    AND of course, the first question is whether the controller firmware is even TRYING to send every packet, as this post began.
    O Offline
    O Offline
    olaeke
    @Zeph I dont't think it has to do with the powersupply. I have the same problem and I power my Gateway with 2A supply and on the radio I have 47uF. I have a coulple of scenes that turn on/off lamps and in my case it looks like there is a limit around 4 devices, if the scene contains more than 4 devices whith no delay then it often miss some of them. But when I added 1 sec delay between every third device then it works fine.
    ferpandoF 1 Reply Last reply
    • hekH Offline
      hekH Offline
      Could it be the serial buffer of the arduino (64 bytes) that fills up to quick with the baudrate?
      What happens if you lower baudrate to say 9600?
      Change here and re-compile gateway:
      https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L38
      And in the Vera serial configuration.
      ferpandoF 2 Replies Last reply
      • Z Zeph
        ferpandoF Offline
        ferpandoF Offline
        ferpando
        @Zeph
        As you can see in the log above, the gateway starts to send messages and only the first and second reach the corresponding node.
        Maybe it is a power issue. I'll try a powered hub and see what happens.
        • O olaeke
          ferpandoF Offline
          ferpandoF Offline
          ferpando
          @olaeke
          If you are able to turn 4 devices at the same time that is more than I can do at the moment. Maybe power is one of the issues as @Zeph suggested, but not the only one.
            ferpandoF Offline
            ferpandoF Offline
            ferpando
            wrote on last edited by ferpando
            #25
            @hek
            I'll try lowering the rate after upgrading the powersupply. Maybe this will also help a bit more.
            About the buffer, would an ethernet gateway behave better in this matter?
            Maybe all this could resolve itself changing gateway type?
            • ferpandoF Offline
              ferpandoF Offline
              ferpando
              Powered hub alone did not make any improvements.
              I'll try bigger capacitor next.
              • ferpandoF Offline
                ferpandoF Offline
                ferpando
                #27
                10 mF also no change. I'll try someting bigger when i can
                  ferpandoF Offline
                  ferpandoF Offline
                  ferpando
                  #28
                  @hek
                  I recompiled the gateway with 9600 bauds but the vera plugin won't start if not 115200.
                  Any way to change this without messing everything up?
                  I reuploaded L_Arduino.lua changing the setting but vera does not use the new file. I can see both in the list.
                  I'll try to delete both via ssh and reupload to see what happens
                  • ferpandoF Offline
                    ferpandoF Offline
                    ferpando
                    After deleting the files and reuploading the 9600 version, nothing changed, so this is not the problem.
                    From the lua file, I see there is a function that sends the data to the nodes.
                    How does it work? Is it invoked by vera when you push some button?
                    Would it be too complex to make the function store command on an array for instance and send a command to a node from that array queue and not sending another until acknowledge is recevied?
                    hekH 1 Reply Last reply
                    • ferpandoF ferpando
                      hekH Offline
                      hekH Offline
                      @ferpando
                      Perhaps you could do some research buffering the outgoing messages.
                      I think they all requires ack back from nodes today so this new feature could also try to resend non-acked messages after some timeout.
                        @ferpando
                        ferpandoF Offline
                        ferpandoF Offline
                        ferpando
                        @hek
                        Nothing seems to work.
                        I will upgrade the capacitor for the radio but I don't have many expectations.
                        As for the plugin, I would need to know more about how vera works.
                        Is there a main function in the plugin?
                        Also, how do you debug the code in vera?
                        • hekH Offline
                          hekH Offline
                          The closest to "main" is this:
                          https://github.com/mysensors/Vera/blob/master/L_Arduino.lua#L543
                          Debugging isn't easy. I usually ssh:ed into the box and tailed the logfile. Was also able to mount the NAS from Vera so I didn't have to scp/file upload changes.
                            ferpandoF Offline
                            ferpandoF Offline
                            ferpando
                            @hek
                            I'll take a look at this. Thank you.
                            I already have my NAS mounted for datamine storage. How can I send the vera logs to the nas?
                            • hekH Offline
                              hekH Offline
                              You can do a soft link to from the mount to your logfile.
                                ferpandoF Offline
                                ferpandoF Offline
                                ferpando
                                @hek
                                I'm no linux expert, but I tried this:
                                ln -s /var/log/cmh/LuaUPnP.log /dataMine/log/vera.log
                                ln: /dataMine/log/vera.log: Permission denied
                                and it didn't work
                                • hekH Offline
                                  hekH Offline
                                  Might be a cifs problem when linking.
                                  http://ubuntuforums.org/showthread.php?t=1600541
                                  Maybe I did it the other way around. Can't recall now.
                                    ferpandoF Offline
                                    ferpandoF Offline
                                    ferpando
                                    #37
                                    @hek
                                    I think the problem might be that I'm trying to create the symLink as root and the cfis is using another user to connect to the nas
                                      ferpandoF Offline
                                      ferpandoF Offline
                                      ferpando
                                      #38
                                      @hek
                                      Here's a basic implementation of the sending queue I came up with.
                                      First I modified this functions:
                                      function sendCommandWithMessageType(altid, messageType, ack, variableId, value)
                                      	local cmd = altid..";".. msgType[messageType] .. ";" .. ack .. ";" .. variableId .. ";" .. value
                                      	-- only add to list if of SET type
                                      	if (messageType =="SET") then
                                      		addToMyQueue(cmd)
                                       	end
                                      	if (luup.io.write(cmd) == false)  then
                                      		task("Cannot send command - communications error", TASK_ERROR)
                                      		luup.set_failure(true)
                                      		return false
                                      	end
                                      	return true
                                      end
                                      function processIncoming(s)
                                      	local incomingData = s:split(";")
                                      	if (#incomingData >=4) then
                                      		-- check if msg is in the list to remove it
                                      		checkMyQueue(s);
                                      		local nodeId = incomingData[1]
                                      end
                                      And added this other functions:
                                      -- adds cmd msg to the list before sending
                                      function addToMyQueue(myCmd)
                                      	local isFound = inTable(MyMsgs, myCmd);
                                      	-- if not already in the list, add it
                                      	if (isFound == false) then
                                      		table.insert( MyMsgs, myCmd )
                                      	end
                                      end
                                      function checkMyQueue(msg)
                                      	log(MyPrefix .. ">T> queue        : " .. printTable(MyMsgs) )
                                      	local isFound = inTable(MyMsgs, msg);
                                      	-- if msg found, remove it because has been executed
                                      	if (isFound ~= false) then
                                      		log("msg found in pos: "..isFound..". Removing from list...")
                                      		table.remove (MyMsgs , isFound)
                                      		else
                                      			log("msg not found in list")
                                      		end
                                      	log(MyPrefix .. ">T> queue updated: " .. printTable(MyMsgs) )
                                      end
                                      function inTable(tbl, item)
                                          for key, value in pairs(tbl) do
                                              if value == item then return key end
                                          end
                                          return false
                                      end
                                      It basically works but the problem with this is that processIncoming() is only processed when a new message arrives, so there is no way we could re-send lost messages when iddle.
                                      We need a function that could be executed at regular intervals to check if there are any messages left in the queue to be re-send.
                                        @hek
                                        		addToMyQueue(cmd)
                                         	end
                                        		return false
                                        	end
                                        	return true
                                        end
                                        		checkMyQueue(s);
                                        end
                                        	end
                                        end
                                        		else
                                        		end
                                        end
                                            end
                                            return false
                                        end
                                        hekH Offline
                                        hekH Offline
                                        http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_call_timer
                                          ferpandoF Offline
                                          ferpandoF Offline
                                          ferpando
                                          @hek
                                          I almost got it but for some reason the call_timer is not being excuted. Not even the first time.
                                          Looking at the logs, i can see that the 6 commands are sent really quickly within milliseconds, and as you can see at the end, only 3 of the messages get through, leaving 3 lost
                                          08	03/20/15 14:26:46.549	Scene::RunScene running 81 test6on <0x2f250680>
                                          08	03/20/15 14:26:46.550	JobHandler_LuaUPnP::HandleActionRequest device: 219 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                                          08	03/20/15 14:26:46.550	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                                          50	03/20/15 14:26:46.553	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                                          50	03/20/15 14:26:46.554	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                                          50	03/20/15 14:26:46.554	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;0;1;1;2;1 <0x2b2c1000>
                                          04	03/20/15 14:26:46.556	<Job ID="42" Name="" Device="219" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.4574000" Runtime="0.2382000" Status="Successful" LastNote=""/> <0x2b2c1000>
                                          08	03/20/15 14:26:46.562	JobHandler_LuaUPnP::HandleActionRequest device: 221 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                                          08	03/20/15 14:26:46.562	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                                          08	03/20/15 14:26:46.595	JobHandler_LuaUPnP::HandleActionRequest device: 216 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                                          08	03/20/15 14:26:46.596	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                                          08	03/20/15 14:26:46.597	JobHandler_LuaUPnP::HandleActionRequest device: 215 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                                          08	03/20/15 14:26:46.598	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                                          08	03/20/15 14:26:46.599	JobHandler_LuaUPnP::HandleActionRequest device: 218 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                                          08	03/20/15 14:26:46.600	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                                          50	03/20/15 14:26:46.601	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                                          50	03/20/15 14:26:46.602	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                                          50	03/20/15 14:26:46.602	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;1;1;1;2;1 <0x2b2c1000>
                                          04	03/20/15 14:26:46.604	<Job ID="43" Name="" Device="221" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.40816000" Runtime="0.2283000" Status="Successful" LastNote=""/> <0x2b2c1000>
                                          50	03/20/15 14:26:46.605	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                                          50	03/20/15 14:26:46.606	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                                          50	03/20/15 14:26:46.606	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;2;1;1;2;1 <0x2b2c1000>
                                          04	03/20/15 14:26:46.608	<Job ID="44" Name="" Device="216" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.11100000" Runtime="0.2205000" Status="Successful" LastNote=""/> <0x2b2c1000>
                                          50	03/20/15 14:26:46.610	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                                          50	03/20/15 14:26:46.610	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                                          50	03/20/15 14:26:46.610	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;3;1;1;2;1 <0x2b2c1000>
                                          08	03/20/15 14:26:46.614	JobHandler_LuaUPnP::HandleActionRequest device: 220 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                                          08	03/20/15 14:26:46.614	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                                          04	03/20/15 14:26:46.620	<Job ID="45" Name="" Device="215" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.20340000" Runtime="0.9573000" Status="Successful" LastNote=""/> <0x2b2c1000>
                                          50	03/20/15 14:26:46.624	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                                          50	03/20/15 14:26:46.624	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                                          50	03/20/15 14:26:46.625	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;4;1;1;2;1 <0x2b2c1000>
                                          04	03/20/15 14:26:46.627	<Job ID="46" Name="" Device="218" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.25886000" Runtime="0.5533000" Status="Successful" LastNote=""/> <0x2b2c1000>
                                          50	03/20/15 14:26:46.628	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                                          50	03/20/15 14:26:46.629	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                                          50	03/20/15 14:26:46.629	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;5;1;1;2;1 <0x2b2c1000>
                                          04	03/20/15 14:26:46.631	<Job ID="47" Name="" Device="220" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.15803000" Runtime="0.2479000" Status="Successful" LastNote=""/> <0x2b2c1000>
                                          50	03/20/15 14:26:46.672	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> processIncoming msg: 6;0;1;1;2;1 <0x2e850680>
                                          50	03/20/15 14:26:46.673	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue        : {6;0;1;1;2;1, 6;1;1;1;2;1, 6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                                          50	03/20/15 14:26:46.674	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, 0, 0, } <0x2e850680>
                                          50	03/20/15 14:26:46.674	luup_log:130: ****<-*->**** Arduino: msg found in pos: 1. Removing from list... <0x2e850680>
                                          50	03/20/15 14:26:46.677	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue updated: {6;1;1;1;2;1, 6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                                          50	03/20/15 14:26:46.677	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, 0, } <0x2e850680>
                                          50	03/20/15 14:26:46.678	luup_log:130: ****<-*->**** Arduino: ****<-->**** Set variable: 6;0;1;1;2;1 <0x2e850680>
                                          50	03/20/15 14:26:46.678	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariable <0x2e850680>
                                          50	03/20/15 14:26:46.679	luup_log:130: ****<-*->**** Arduino: Setting variable 'Status' to value '1' <0x2e850680>
                                          50	03/20/15 14:26:46.679	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                                          50	03/20/15 14:26:46.679	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:upnp-org:serviceId:SwitchPower1,Status, 1, 219 <0x2e850680>
                                          06	03/20/15 14:26:46.680	Device_Variable::m_szValue_set device: 219 service: urn:upnp-org:serviceId:SwitchPower1 variable: Status was: 0 now: 1 #hooks: 4 upnp: 0 v:0x9b41e8/NONE duplicate:0 <0x2e850680>
                                          50	03/20/15 14:26:46.680	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                                          50	03/20/15 14:26:46.684	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1426858006, 219 <0x2e850680>
                                          06	03/20/15 14:26:46.685	Device_Variable::m_szValue_set device: 219 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1426688846 now: 1426858006 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2e850680>
                                          50	03/20/15 14:26:46.685	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                                          50	03/20/15 14:26:46.686	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1426858006, 217 <0x2e850680>
                                          06	03/20/15 14:26:46.686	Device_Variable::m_szValue_set device: 217 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1426857982 now: 1426858006 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2e850680>
                                          50	03/20/15 14:26:46.687	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                                          50	03/20/15 14:26:46.688	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 14:26, 217 <0x2e850680>
                                          50	03/20/15 14:26:46.752	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> processIncoming msg: 6;1;1;1;2;1 <0x2e850680>
                                          50	03/20/15 14:26:46.753	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue        : {6;1;1;1;2;1, 6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                                          50	03/20/15 14:26:46.753	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, 0, } <0x2e850680>
                                          50	03/20/15 14:26:46.754	luup_log:130: ****<-*->**** Arduino: msg found in pos: 1. Removing from list... <0x2e850680>
                                          50	03/20/15 14:26:46.754	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue updated: {6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                                          50	03/20/15 14:26:46.755	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, } <0x2e850680>
                                          50	03/20/15 14:26:46.755	luup_log:130: ****<-*->**** Arduino: ****<-->**** Set variable: 6;1;1;1;2;1 <0x2e850680>
                                          50	03/20/15 14:26:46.756	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariable <0x2e850680>
                                          50	03/20/15 14:26:46.756	luup_log:130: ****<-*->**** Arduino: Setting variable 'Status' to value '1' <0x2e850680>
                                          50	03/20/15 14:26:46.756	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                                          50	03/20/15 14:26:46.757	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:upnp-org:serviceId:SwitchPower1,Status, 1, 221 <0x2e850680>
                                          06	03/20/15 14:26:46.757	Device_Variable::m_szValue_set device: 221 service: urn:upnp-org:serviceId:SwitchPower1 variable: Status was: 0 now: 1 #hooks: 4 upnp: 0 v:0x9b41e8/NONE duplicate:0 <0x2e850680>
                                          50	03/20/15 14:26:46.759	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                                          50	03/20/15 14:26:46.759	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1426858006, 221 <0x2e850680>
                                          06	03/20/15 14:26:46.760	Device_Variable::m_szValue_set device: 221 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1426688847 now: 1426858006 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2e850680>
                                          50	03/20/15 14:26:46.760	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                                          50	03/20/15 14:26:46.761	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1426858006, 217 <0x2e850680>
                                          06	03/20/15 14:26:46.761	Device_Variable::m_szValue_set device: 217 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1426858006 now: 1426858006 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2e850680>
                                          50	03/20/15 14:26:46.762	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                                          50	03/20/15 14:26:46.762	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 14:26, 217 <0x2e850680>
                                          50	03/20/15 14:26:46.862	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> processIncoming msg: 6;2;1;1;2;1 <0x2e850680>
                                          50	03/20/15 14:26:46.863	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue        : {6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                                          50	03/20/15 14:26:46.863	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, } <0x2e850680>
                                          50	03/20/15 14:26:46.864	luup_log:130: ****<-*->**** Arduino: msg found in pos: 1. Removing from list... <0x2e850680>
                                          50	03/20/15 14:26:46.864	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue updated: {6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
