  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • F
    F
    Fabien
    no, message are not recieve. I find someting :
    When I touch the NRF24 antenna (just a little it sifficient), it works. fine.
    Strange, same radio on other sensebender doesn't need this and other radio on this sensebender need to bo "touch".
    I try with 10uF additionnal on NRF but no change ...
      wrote on last edited by hek
      #182
      Do you use a socket or is the NRF module directly soldered onto the sensbender?
      (a bad connection in socket could be a problem... and when you press NRF module it has connection again)
      • F
        F
        Fabien
        Yes it's directly sold (and very hard to change with metallised hole). I will give a last try with another radio ...
        • F
          F
          Fabien
          Ok end of story ... sensebender card is dead ! 2 metallized hole were destroy by solder/unsoldering NRF modules.
          Hope my last Sensebender will work. And if there is a batch with light version I will reuse T/H sensor
          • G
            G
            gloob
            @Fabien it seems that you have the same problem as me. I ordered a new set of radio modules to test if it is the fault of the radios. I will give feedback here about my progress.
            I aleady tried to add capacitors on the radio module but this did not help.
            There is also no difference if I power the micro from the FTDI or the battery connector.
            • tbowmoT
              tbowmoT
              tbowmo
              @Fabien
              Unfortunately I don't think there will be a light edition coming out at the moment. Currently the savings is way too small (I'm estimating a savings of 4-5$ compared to the full sensebender edition).
                @Fabien
                Here are some quite nice repair guides
                http://www.circuitrework.com/guides/guides.shtml
                More specifically
                http://www.circuitrework.com/guides/5-1.shtml
                • F
                  F
                  Fabien
                  @gloob it's not a radio problem. Same radio works on the others boards.
                  @hek I will try to repair the board ...
                    mvader
                    wrote on last edited by mvader
                    #189
                    looking for some help programming this thing.
                    I had a pl2303 usb programmer, but it had no DTR, so i orders a new usb programmer
                    this one is a cp2102 with a DTR line.
                    but still the same problem. it never uploads the code.
                    i have the right board, processor and port chosen.
                    i have tried all the programmers in the IDE but none work.
                    it just says "uploading" and then eventually errors out.
                    any suggestions?
                    EDIT: nm i read something about switching tx and rx and i figured what the heck and surprise it worked..
                    sketch uploaded..
                    • T
                      tlund
                      Hi @tbowmo
                      Thanks for bringing this great project to the community.
                      I'm trying to understand the sensebender's power profile, especially the sleep current.
                      I have previously done some measurements with the atmega328p (pro mini) + NRF. In addition to that I have also looked at the datasheets for the other components on the sensebender.
                      It seems the theoretical low sleep current consumption is something like this:
                      * nrf24l01+    900nA
                      * atmega328p     5uA (with WD)
                      * si7021        60nA
                      * atsha204      30nA
                      * at23df512c   300nA
                        =  Total     6.3uA
                      The SBMicro seems to draw ~50uA in sleep mode with the default configuration.
                      I managed to put the flash memory into "ultra deep sleep"(*), causing the total consumption to drop to ~27uA. So there is still around 20uA that is not accounted for.
                      I've also tried putting the atsha204 into sleep, but that did not make any difference (also confirmed by the specs).
                      Are there some other settings/sleep modes that have not been enabled yet? What about the atmega itself?
                      Do any of you have the a sensebender prototype with separate components, and can test sleep current by removing components one
                      by one? (Before I start cutting traces on my own sensebenders in order to zero in on the target component).
                      Is there something I'm missing?
                      Datasheets:
                      ATSHA204
                      AT25DF512C
                      Si7021 A20
                      (*) in setup(): flash.initialize(); flash.ultra_deep_sleep() <- From datasheet
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @tlund
                        Interesting figures.. are you sure that you've got a genuine nrf24 chip on the radio? Could be a fake with higher power consumption.
                        • T
                          tlund
                          @tbowmo
                          My NRF's are the same $1 nrf's listed in the mysensors store, so probably fake. But I have still measured them to draw ~900nA in powerDown.
                          But I think I have found the culprint now. It seems the extra 20uA is caused by Arduino 1.6.5 (it may be that my installation is faulty).
                          My test setup:
                          • pro mini
                          • nrf
                          • a simple sketch that does gw.sleep(60s)
                          1st test: sketch compiled & uploaded via Arduino 1.0.5-r2: 6uA
                          2nd test: sketch compiled & uploaded via Arduino 1.6.5: 24uA
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @tlund
                            Hmm could it be some optimization that causes the atmega to not go into deepest sleep mode?
                            Maybe someone should have a look at the assembler output from a build with both versions of arduino
                            • F
                              F
                              Fabien
                              I'm back with bad news ... My 5th sensebender have a lot of st:fail like the first one. But now I know why !
                              There is only one same things between the two board which fails : The FTDI connector. It's 90° connector and pins are just below the antenna. And I think tunning is not ok.
                              So, when I go to work I try to remove the FTDI connector and see if connection is better !
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Fabien
                                That ftdi connector could have some effect on the antenna. I specifically made the area below the antenna empty, so that it wouldn't make any problems with the antenna.
                                • F
                                  F
                                  Fabien
                                  So now the good news. I "repair" my 1st SenseBender (only two wire but one on the ATMega) and it works (with the same radio wich failed). I remove the FTDI header and everythings is ok. So now I'm sure the problem is the FTDI header near the antenna. And be carefull, we can have the same problem with battery for example. I suppose minimal distance is about 3.2 cm (lambda/4).
                                  But now I have a question : How can I update sketch without header (0° header doesn't fit in case). OTA ? Is ther a tutorial for OTA update with out of the box SenseBenderMicro ?
                                  Thank for your help !
                                  • G
                                    G
                                    gloob
                                    I have the FTDI headers on the opposite site and I also get this transmission errors.
                                    I ordered a new batch of NRF24L01+ modules and will check if the problem still exists.
                                      mvader
                                      I have my FTDI headers on the other side as well and have no transmission errors.
                                      I am using genuine NRF+ radios though.
                                      could be the fakes causing a problem
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        I have a male connector on my FTDI thingie, so I just put it in the mounting holes on the micro, and hold it to one of the sides, so it makes contact.
                                        • T
                                          tlund
                                          wrote on last edited by tlund
                                          #200
                                          @tbowmo
                                          I tried uploading the sensebender sketch using 1.0.5-r2 with board config "pro mini 328 3.3V 8MHz". The si7021 doesn't work in this configuration, but I managed to get a sleep current of ~6.8uA
                                          I can provide the binary output from the two IDE versions if someone can give me an indication where to find the build binaries.
