  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • G
    G
    gloob
    @Fabien it seems that you have the same problem as me. I ordered a new set of radio modules to test if it is the fault of the radios. I will give feedback here about my progress.
    I aleady tried to add capacitors on the radio module but this did not help.
    There is also no difference if I power the micro from the FTDI or the battery connector.
    • tbowmoT
      tbowmoT
      tbowmo
      @Fabien
      Unfortunately I don't think there will be a light edition coming out at the moment. Currently the savings is way too small (I'm estimating a savings of 4-5$ compared to the full sensebender edition).
        @Fabien
        Here are some quite nice repair guides
        http://www.circuitrework.com/guides/guides.shtml
        More specifically
        http://www.circuitrework.com/guides/5-1.shtml
        • F
          F
          Fabien
          @gloob it's not a radio problem. Same radio works on the others boards.
          @hek I will try to repair the board ...
            mvader
            wrote on last edited by mvader
            #189
            looking for some help programming this thing.
            I had a pl2303 usb programmer, but it had no DTR, so i orders a new usb programmer
            this one is a cp2102 with a DTR line.
            but still the same problem. it never uploads the code.
            i have the right board, processor and port chosen.
            i have tried all the programmers in the IDE but none work.
            it just says "uploading" and then eventually errors out.
            any suggestions?
            EDIT: nm i read something about switching tx and rx and i figured what the heck and surprise it worked..
            sketch uploaded..
            • T
              tlund
              Hi @tbowmo
              Thanks for bringing this great project to the community.
              I'm trying to understand the sensebender's power profile, especially the sleep current.
              I have previously done some measurements with the atmega328p (pro mini) + NRF. In addition to that I have also looked at the datasheets for the other components on the sensebender.
              It seems the theoretical low sleep current consumption is something like this:
              * nrf24l01+    900nA
              * atmega328p     5uA (with WD)
              * si7021        60nA
              * atsha204      30nA
              * at23df512c   300nA
                =  Total     6.3uA
              The SBMicro seems to draw ~50uA in sleep mode with the default configuration.
              I managed to put the flash memory into "ultra deep sleep"(*), causing the total consumption to drop to ~27uA. So there is still around 20uA that is not accounted for.
              I've also tried putting the atsha204 into sleep, but that did not make any difference (also confirmed by the specs).
              Are there some other settings/sleep modes that have not been enabled yet? What about the atmega itself?
              Do any of you have the a sensebender prototype with separate components, and can test sleep current by removing components one
              by one? (Before I start cutting traces on my own sensebenders in order to zero in on the target component).
              Is there something I'm missing?
              Datasheets:
              ATSHA204
              AT25DF512C
              Si7021 A20
              (*) in setup(): flash.initialize(); flash.ultra_deep_sleep() <- From datasheet
              • tbowmoT
                tbowmoT
                tbowmo
                @tlund
                Interesting figures.. are you sure that you've got a genuine nrf24 chip on the radio? Could be a fake with higher power consumption.
                • T
                  tlund
                  @tbowmo
                  My NRF's are the same $1 nrf's listed in the mysensors store, so probably fake. But I have still measured them to draw ~900nA in powerDown.
                  But I think I have found the culprint now. It seems the extra 20uA is caused by Arduino 1.6.5 (it may be that my installation is faulty).
                  My test setup:
                  • pro mini
                  • nrf
                  • a simple sketch that does gw.sleep(60s)
                  1st test: sketch compiled & uploaded via Arduino 1.0.5-r2: 6uA
                  2nd test: sketch compiled & uploaded via Arduino 1.6.5: 24uA
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @tlund
                    Hmm could it be some optimization that causes the atmega to not go into deepest sleep mode?
                    Maybe someone should have a look at the assembler output from a build with both versions of arduino
                    • F
                      F
                      Fabien
                      I'm back with bad news ... My 5th sensebender have a lot of st:fail like the first one. But now I know why !
                      There is only one same things between the two board which fails : The FTDI connector. It's 90° connector and pins are just below the antenna. And I think tunning is not ok.
                      So, when I go to work I try to remove the FTDI connector and see if connection is better !
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Fabien
                        That ftdi connector could have some effect on the antenna. I specifically made the area below the antenna empty, so that it wouldn't make any problems with the antenna.
                        • F
                          F
                          Fabien
                          So now the good news. I "repair" my 1st SenseBender (only two wire but one on the ATMega) and it works (with the same radio wich failed). I remove the FTDI header and everythings is ok. So now I'm sure the problem is the FTDI header near the antenna. And be carefull, we can have the same problem with battery for example. I suppose minimal distance is about 3.2 cm (lambda/4).
                          But now I have a question : How can I update sketch without header (0° header doesn't fit in case). OTA ? Is ther a tutorial for OTA update with out of the box SenseBenderMicro ?
                          Thank for your help !
                          • G
                            G
                            gloob
                            I have the FTDI headers on the opposite site and I also get this transmission errors.
                            I ordered a new batch of NRF24L01+ modules and will check if the problem still exists.
                              mvader
                              I have my FTDI headers on the other side as well and have no transmission errors.
                              I am using genuine NRF+ radios though.
                              could be the fakes causing a problem
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                I have a male connector on my FTDI thingie, so I just put it in the mounting holes on the micro, and hold it to one of the sides, so it makes contact.
                                • T
                                  tlund
                                  wrote on last edited by tlund
                                  #200
                                  @tbowmo
                                  I tried uploading the sensebender sketch using 1.0.5-r2 with board config "pro mini 328 3.3V 8MHz". The si7021 doesn't work in this configuration, but I managed to get a sleep current of ~6.8uA
                                  I can provide the binary output from the two IDE versions if someone can give me an indication where to find the build binaries.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @tlund
                                    I think it's better if we can get the intermediate asm file from the compiler chain. Will look at it tomorrow evening (I have closed my computer down for the evening today)
                                    • G gbfromhb
                                      @mvader
                                      mvader
                                      @gbfromhb said:
                                      @mvader
                                      I just wanted to follow up and say thanks for the link/info
                                      i was able to get that working.
                                      surprised that they just don't offer a 3v pin.. it works great the way that link shows
                                      Thanks again!
                                      • 5546dug5
                                        5546dug5
                                        5546dug
                                        Has anybody built a box for the standard Sensebender Micro with 2 AA batteries yet.
                                        I would like to get the .stl files if so
                                        Thanks Doug
                                        SparkmanS 1 Reply Last reply
                                        • 5546dug5 5546dug
                                          Thanks Doug
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          Thanks Doug
                                          Hi Doug,
                                          @ServiceXP has posted this one: http://forum.mysensors.org/topic/1566/mysensors-sensebender-micro-3dp-case
                                          Al
