  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • T timropp
    I've got 3 coming, can't wait to figure out what I'm going to use them for :)
    mvader
    I'm deploying mine all over the house.
    in my attics, garage, shed. bedrooms. etc
    I've attached motion and lux sensors to several of them already.
    I tested / proof of concept adding IR transmitters. but these will likely need to be 5v nano's or something as battery power probably won't work with the IR and staying away waiting for messages from the controller.
    • N
      N
      NotYetRated
      Got 3 up just using the built in temp/humidity, making sure all looks ok. Will slowly add motion.
      Any suggested motion sensor for these guys?
      M 1 Reply Last reply
      • N NotYetRated
        mvader
        I'm using that HC501 PIR
        you can connect to the side pin and use 3v instead of the 5v
        • GertSandersG
          GertSandersG
          GertSanders
          @mvader Can you elaborate how you use 3V on the HC501 ? Which side pin ? Can you post an image ?
          • GertSandersG GertSanders
            mvader
            @GertSanders
            if you look at this image
            on the left side where it says "H" by the 3 pins with the jumper.
            i take off the jumper and connect 3v to the H pin
            works great.
            http://www.bdspeedytek.com/wp-content/uploads/1.1.jpg
            • GertSandersG
              GertSandersG
              GertSanders
              @mvader Thanks !
                My Sensebender node started June 10 is still going strong.
                AnticimexA 1 Reply Last reply
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @hek nice, what tool do you use for logging/graphing? Or is it exported and post-processed?
                  hekH 1 Reply Last reply
                  • AnticimexA Anticimex
                    @Anticimex
                    Datamine for Vera. The actual data is stored to my NAS (mounted from vera).
                      @Anticimex
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @hek cool. Can Vera do that now? Vera lite as well? Though the data miner plugin only could use USB mounts.
                        wrote on last edited by hek
                        #331
                        Na, a little hack
                        http://forum.micasaverde.com/index.php/topic,14910.0.html
                        • petoulachiP
                          petoulachiP
                          petoulachi
                          I've just received my sensebender boards and start playing with it.
                          My first goal is to make a door sensor running on battery. I will not use the integrated temp/hum sensor for battery purpose, and use interrupt to have the sensor on sleep the majority of time.
                          Looking at the sketch given with temp/hum, I have one question;
                          on the loop function, we have
                          if ((measureCount == 5) && highfreq)
                              clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
                              highfreq = false;
                          But I don't really understand this ; highfreq is initialized to true in the declaration, and never again. So, does this clock_prescale_set is call only once, meangin that the sensor will run at 1Mhz all the time ?
                          It is the 5 first mesure that are running at normal speed, and then the sensor goes into a "battery efficient" mode ?
                          Why waiting for 5 mesure to do so, and not doing it at startup ?
                          Thanks for your explanation !
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            It's waiting with switching to lower frequency, because it is dumping debug information to the serial port. And when you switch to 1Mhz, the baudrate is "screwed".
                            When that's said, my opinion is that there is not much power to save, with switching to 1Mhz. This is because the MCU is sleeping most of the time, with the RC oscillator switched off. I am thinking that the freq. scaling should be removed in the comming releases
                            • petoulachiP
                              petoulachiP
                              petoulachi
                              Oooh so I guess that also explain why I have strange output on the serial using the default sketch ?
                              Well, I'll start without touching frequency and see how it behave in the next month. This is the sketch I use (not tested yet !). Sleeping all the time, awake but interrupt. When awake, send the Battery % if different from last mesure.
                               * Version 1.0 - Henrik Ekblad
                               * Default sensor sketch for Sensebender Micro module
                               * Act as a temperature / humidity sensor by default.
                               * If A0 is held low while powering on, it will enter testmode, which verifies all on-board peripherals
                               * Battery voltage is as battery percentage (Internal message), and optionally as a sensor value (See defines below)
                              #include <Wire.h>
                              #include "utility/SPIFlash.h"
                              #include <EEPROM.h>
                              #include <avr/power.h>
                              #define RELEASE "1.0"
                              // Child sensor ID's
                              #define CHILD_ID_DOOR 1   // Id of the sensor child
                              // Sensor messages
                              MyMessage msgDoor(CHILD_ID_DOOR, V_TRIPPED);
                              // Global settings
                              int measureCount = 0;
                              int sendBattery = 0;
                              boolean highfreq = true;
                              // Storage of old measurements
                              long lastBattery = -100;
                              boolean oldDoorValue;
                               * Setup code
                                Serial.begin(115200);
                                Serial.print(F("Sensebender Micro FW "));
                                Serial.print(RELEASE);
                                Serial.flush();
                                gw.begin();
                                Serial.flush();
                                Serial.println(F(" - Online!"));
                                gw.sendSketchInfo("Battery Door", RELEASE);
                                // sets the motion sensor digital pin as input
                                pinMode(DIGITAL_INPUT_SENSOR, INPUT);
                                // Activate internal pull-ups
                                digitalWrite(DIGITAL_INPUT_SENSOR, HIGH);
                                gw.present(CHILD_ID_DOOR, S_DOOR);
                               *  Main loop function
                                gw.process();
                                sendBattLevel(false);
                                door(false);
                                gw.sleep(INTERRUPT, CHANGE, 0);
                              void door(bool force)
                                sensor_node.sleep(5);
                                bool tx = force;
                                if (tripped != oldDoorValue)
                                  tx = true;
                                  oldDoorValue = tripped;
                                if (tx)
                                   // Send in the new value
                                   gw.send(msgDoor.set(tripped ?  1 : 0));  // Send tripped value to gw
                               * Sends battery information (battery percentage)
                               * Parameters
                               * - force : Forces transmission of a value
                              void sendBattLevel(bool force)
                                if (force) lastBattery = -1;
                                long vcc = readVcc();
                                if (vcc != lastBattery)
                                  lastBattery = vcc;
                                  // Calculate percentage
                                  vcc = vcc - 1900; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
                                  long percent = vcc / 14.0;
                                  gw.sendBatteryLevel(percent);
                               * Internal battery ADC measuring
                              long readVcc() {
                                #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                                  ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
                                #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                                  ADMUX = _BV(MUX5) | _BV(MUX0);
                                #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
                                  ADcdMUX = _BV(MUX3) | _BV(MUX2);
                                #else
                                long result = (high<<8) | low;
                              BTW, what is the F() function ? instead of Serial.print("Sensebender Micro FW "); why using Serial.print(F("Sensebender Micro FW ")); ?
                              Thanks !
                              • petoulachiP
                                petoulachiP
                                petoulachi
                                Started to solder my 6 sensebender. I've noticed that if I set it to 1Mhz directly, the sensor cannot register itself on the gateway (but unfortunately I dont know why because there's no serial). Putting it at 8Mhz, being detected by the GW with an ID, and I can set it back to 1mhz. Weird.
                                • petoulachiP
                                  petoulachiP
                                  petoulachi
                                  Oh and BTW, which boxes are you using with your Sensebender ? I guess it's maybe the most difficult part of the entire project, finding the perfect box :D
                                  tbowmoT 1 Reply Last reply
                                  • F
                                    F
                                    finge
                                    No, finding a box is the easiest part. This is the "box" for my outdoor temperature. :satisfied:
                                      Wonder how well the hum-sensors work in that enclosure :)
                                      • F
                                        F
                                        finge
                                        Hmm, would Gore-Tex work? I will try find a Gore-Tex bag for the next version :)
                                        • F Fabien
                                          @5546dug said:
                                          @fabian how is the box working out were there any mods and are the stl files ready yet?
                                          Sorry, my 3D printer is out of service, I'm waiting for chinese parts ... I will post correct STL files in 1 or 2 weeks.
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Fabien @5546dug
                                          Hi, any news on this please? I would be good to get a box by Christmas.
