  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • alexsh1A alexsh1
    @Anticimex Just an idea - could it be that nonce is not generated in the beginning and requires some time? I'll do some testing tonight
    AnticimexA
    AnticimexA
    Anticimex
    @alexsh1 No, nonces are being generated:
    0;255;3;0;9;SHA256: 86DEAE1DAF50D577A4E2262B33ABF9DEE05DD8FAF84F94F50900000000000000
    0;255;3;0;9;Transmittng nonce
    0;255;3;0;9;Skipping security for command 3 type 17
    0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:86DEAE1DAF50D577A4E2262B33ABF9DEE05DD8FAF84F94F509
    and the generated nonce is not transmitted correctly (st=fail) due to some transport issue.
    alexsh1A 1 Reply Last reply
    • AnticimexA Anticimex
      alexsh1A
      alexsh1A
      alexsh1
      Than I am out of guesses - I cannot explain why st=fail comes up.
      FYG, I tried it without signing and it works just fine. No st=fail.
      There must be something between signing and transportation or transportation after signing?
      AnticimexA 1 Reply Last reply
      • alexsh1A alexsh1
        AnticimexA
        AnticimexA
        Anticimex
        @alexsh1 like I said, signing is not in itself the problem. The problem is that big messages are failing. You can just try by generating big messages yourself and you will get the same problem. I know this by looking on what generates st=fail and it is the transport layer. Signing generates the data to be transmitted, and this data is printed and shown to be correct. Bigger messages require more reliable communications. Shorter messages has a better chance of being transmitted correctly. It is that simple. Many have reported the sake issue and have solved it by improving radio power decoupling, rearranging the sensor placement or improve the power supplies.
          alexsh1A
          alexsh1A
          alexsh1
          #464
          I tried
          1. powering GW/Sensobender from a different source (battery, USB, PSU - 12V in case of GW, 5v in case of sensebender via LDO)
          2. swapped a few radios. Most of these are from working nodes with caps soldered. Maybe I should try completely different ones from a different batch? I mixed up three batches with no improvement.
          3. Tried to place GW and the sensebender 1m/5m/10m apart
          4. GW radio is powered via the AMS1117 3.3v
          So far it is the same result. Not sure I can come up with anything obvious unless you can suggest
          • alexsh1A alexsh1
            I tried
            AnticimexA
            AnticimexA
            Anticimex
            @alexsh1 sorry, I have not much else to suggest except experimenting with delays to see if the issue with failed transmissions at node startup can be avoided. I am no specialist on the radio. I'm the security guy and I see no wrong with the behaviour of those parts so I am short of any more useful suggestions I am afraid.
              @alexsh1
              When did you last update the library (on the gw)? @Yveaux recently added a irq-based de-queuing from the radios FIFO. It could help on improving things.
              Otherwise the only advice I have is to skip any amplified radio on gateway (if you have) and tweak powering of radio power on gw.
                alexsh1A
                alexsh1A
                alexsh1
                #467
                @Anticimex Well, at least we are fine on the security part :-)
                I'll experiment more on the radio part when I have time - why there are only 24h in a day? (rhetorical question)
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @hek said:
                  @alexsh1
                  @hek
                  I downloaded the dev on 26/05 so it is very recent.
                  I have normal radios both ends, but the idea is to have amplified one on the GW as well and change rf24_pa_max. Additionally, I'll try to mix as many radios as I can have. Who knows?
                  To be honest, things were working OKish before as I took it seriously decoupling radios etc. This voodoo dance around radios really irritates me. Life is too short to waist it - I am now thinking seriously switching to RMF69W or probably to RFM95* (Lora)
                  • alexsh1A alexsh1
                    @hek said:
                    @alexsh1
                    @hek
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @alexsh1 yesh i have bashed my head on rf24 stability myself and have decided to base my network on rfm69:s instead. Too much chatter @2.4ghz. I hope the 69:s have better range and they also have the bonus of AES encryption in hw if you want to obfuscate the communication some. Signing adds netter security, but the paranoid can combine signing with encryption :) (yes rf24 can use AES encryption in software, but that cost memory and some overhead instead)
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Whatever I did, did not help to solve st=fail
                      When I disable signing I have got the following (not a signle st=fail):
                      Starting sensor (RNONA-, 2.0.0-beta)
                      Radio init successful.
                      Sensebender Micro FW 1.5 - Online!
                      send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=17,sg=0,st=ok:Sensebender Micro
                      send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.5
                      send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                      send: 3-3-0-0 s=2,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                      send: 3-3-0-0 s=3,c=0,t=13,pt=0,l=0,sg=0,st=ok:
                      isMetric: 1
                      TempDiff :125.61
                      HumDiff  :150.00
                      T: 25.61
                      H: 50
                      send: 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:25.6
                      send: 3-3-0-0 s=2,c=1,t=1,pt=2,l=2,sg=0,st=ok:50
                      send: 3-3-0-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.09
                      send: 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:85
                      I am going to try different channels now with signing
                      • alexsh1A alexsh1
                        isMetric: 1
                        TempDiff :125.61
                        HumDiff  :150.00
                        T: 25.61
                        H: 50
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @alexsh1 yes, without signing your messages are significantly shorter, and thus have a better chance of getting through. You can try experimenting with amplification as well.
                        YveauxY alexsh1A 2 Replies Last reply
                          YveauxY
                          YveauxY
                          @Anticimex just a noob question: do you have an idea of the performance penalty of (software) signing? Any benchmark figures?
                          • YveauxY Yveaux
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @Yveaux no, sorry have not got around to compare them. But software signing is actually quicker due to the single write bit banging for the atsha204a. One way to see the difference is measuring the delay for an ACK to come back from a node that require signed messages. I have no figures, but a node with software signing responds slightly faster.
                            YveauxY 1 Reply Last reply
                              YveauxY
                              YveauxY
                              @Anticimex But is it significantly slower than without any signing?
                              • YveauxY Yveaux
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @Yveaux yes. But I know that significant improvements can be made in the nonce whitening. It incrementally calculates a hash which is which is far less efficient than calculate the hash of a buffer. So there are room for improvements. I just wish there were more time, and now my arduinos are packed down so I wont be able to test. But volunteers are welcome, I can still code :)
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  Do you think a message size has anything to do with st=fail?
                                  • alexsh1A alexsh1
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @alexsh1 yes, like I have said here and in other topics, signing often gets the blame for transmission problems because with signing the maximum message buffer is used, and larger messages are more difficult to transmit than short ones. So if you have a poor connection, odds are that a larger message will fail more often than a short one.
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      I do not think its signing, but I think it is implementation of signing and sending.
                                      I do not get st=fail after the initial 9 messages not even once. Something is just very-very odd.
                                      • ximinezX
                                        ximinezX
                                        ximinez
                                        I'm seeing the same failed signings when the device powers up, but it doesn't fail after those.
                                        • ximinezX ximinez
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          Did you manage to get it sorted?
