  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.0k Views 35 Watching
    Could be noisy power supply, not adequate decoupling capacitor on the radio, radio interference from other devices nearby (wifi or else)
    • Mitja BlazinsekM
      Mitja BlazinsekM
      Mitja Blazinsek
      wrote on last edited by Mitja Blazinsek
      #562
      i try at least three different radios with and without capacitors gw an sensors are close (20cm) and like i said sensbender worked fine till i try to upload program on it
      AnticimexA 1 Reply Last reply
        Did you try a completely different radio module from another manufacturer?
        • Mitja BlazinsekM Mitja Blazinsek
          AnticimexA
          AnticimexA
          Anticimex
          @mitja-blazinsek how do you supply power to the radio module?
          • Mitja BlazinsekM
            Mitja BlazinsekM
            Mitja Blazinsek
            yust plug in socket on sensbender micro
            • Mitja BlazinsekM
              Mitja BlazinsekM
              Mitja Blazinsek
              is it possible that si some problem with my arduino IDE maybe some library tomorrow i will try to reinstall arduino
              • D
                D
                dklinkman
                @MITJA BLAZINSEK - So I built my first Sensebender Micro this weekend and it works great. Radio works at distance (>10Meters). Advertises temp and hum at proper intervals. Plus battery level occasionally. And I can update the firmware via Arduino IDE (v1.8.1) and USB. Everyone's path and experience is different so here's what I did.
                The build was simple. I just added the socket for the radio. Oh and a piece of right angle pin header for the FTDI interface.
                For powering I currently use a FTDI Basic 3v3 from Sparkfun. Provides power plus USB serial for programming and debugging. I have a few 2xAAA cell holders on order for powering from battery.
                Once built I also plugged in a radio. I have tried the generic NRF24 low and high power versions with no problems either way. The high power is the PA LNA type with the external antenna. The low power is what is in the picture down below.
                Setting up the Arduino IDE was a bit of a chore but the instructions at > link < are very good.
                At the end make sure you use the Boards Manager to install the MySensors AVR Boards (add MySensors to the search) so you can choose the "Sensebender Micro" as your 'board'. This last step isn't explicitly mentioned on the link. If that board isn't selected your results will be disappointing. I know from experience.
                For the MySensors library be sure to install the latest release which is 2.2.0. I had to use the drop down list for the MySensors library in the Library Manager to install that version. But I l already had a lower version installed, plus a development release installed manually, and this was right around the official 2.2.0 release date, so who knows.
                I run Windows 7 Professional SP1 and the Arduino IDE version 1.8.1. Updating the firmware via USB works fine. I have not tried OTA updates yet though I plan to. That should be interesting.
                Your mileage may vary. I hope this helps anyone dipping their toe for the first time.
                -d
                • Mitja BlazinsekM
                  Mitja BlazinsekM
                  Mitja Blazinsek
                  i did all this i try even downgrade my sensor library and its same the interest thing that even other boards not working (arduino nano) a had some assembled and programmed nano that i play with about 6month ago and it work fine, then try to upload relay code on it and nothing everything (didn't touch wiring) i try to program it doesn't work even if it was working before, so i think it must be something with my arduino ide
                  • Mitja BlazinsekM
                    Mitja BlazinsekM
                    Mitja Blazinsek
                    reinstal arduino, libary, clear eprom nothing gonna lose my mind i think i'm gonna throw everything in trash :rage:
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @mitja-blazinsek how do you power your board? USB from pc? That might not work. Try a USB power supply instead. Or a different pc. Or a completely different power source, like batteries.
                      • Mitja BlazinsekM
                        Mitja BlazinsekM
                        Mitja Blazinsek
                        i just try this and its same
                        is it possible that is anythig with gw i'm using official sensebender gw
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Mitja-Blazinsek
                          Just to be sure, you haven't used a customized channel / network address on the gateway, that you forgot to set on the nodes?
                            You could also try moving the node further away (5-10 m) from the gateway.
                            • Mitja BlazinsekM
                              Mitja BlazinsekM
                              Mitja Blazinsek
                              i try new serial gw on nano but same problem i delete all nodes and when i turn on some sensors my controller find it only one node without name. My only working sensor (one of the woking sensebender out the box) display 2 nodes one without name and node with sensebender micro name what for is that first node ID 0
                              screen shot how it display every sensor:
                              • Mitja BlazinsekM
                                Mitja BlazinsekM
                                Mitja Blazinsek
                                now even sensbender micro that it work on sensbender gw don't work on my gw it work only if i connect sensbender gw
                                • Mitja BlazinsekM
                                  Mitja BlazinsekM
                                  Mitja Blazinsek
                                  look like everything that i programmed not working about half years ago when i start with my sensors everything that i try work bu when i have time to play with mysensors again nothing worked make me crazy i have full box of sensors and boards but nothing cant get to work only sensbender gw and sensbender micro that i didn't touch i think that must be something with arduino ide
                                  • Mitja BlazinsekM
                                    Mitja BlazinsekM
                                    Mitja Blazinsek
                                    ok my gw now work sorry i forget to connect radio vcc :relaxed: but everything else not working every sensor i try triple check wiring bothing :rage:
                                      without any debug info nobody can help you
                                      • Mitja BlazinsekM
                                        Mitja BlazinsekM
                                        Mitja Blazinsek
                                        16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
                                        25 TSM:INIT
                                        26 TSF:WUR:MS=0
                                        33 TSM:INIT:TSP OK
                                        35 TSF:SID:OK,ID=56
                                        37 TSM:FPAR
                                        73 TSF:MSG:SEND,56-56-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        2081 !TSM:FPAR:NO REPLY
                                        2083 TSM:FPAR
                                        2119 TSF:MSG:SEND,56-56-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        4127 !TSM:FPAR:NO REPLY
                                        4129 TSM:FPAR
                                        4165 TSF:MSG:SEND,56-56-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        6173 !TSM:FPAR:NO REPLY
                                        6175 TSM:FPAR
                                        6211 TSF:MSG:SEND,56-56-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        8219 !TSM:FPAR:FAIL
                                        8220 TSM:FAIL:CNT=1
                                        8222 TSM:FAIL:DIS
                                        8224 TSF:TDI:TSL
                                        18226 TSM:FAIL:RE-INIT```
                                          ok, and gateway?
