  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.9k Views 35 Watching
  • tbowmoT tbowmo
    @rvendrame
    absolute maximum voltage is 3.6V, above that you'll let the magic smoke out of the following components:
    • Si7021
    • external flash
    • radio module.
    Only the atmega328 and atsha204 will survive.
    korttomaK
    korttomaK
    korttoma
    @Hausner said:
    Would this work with a 3,7V Li-Ion 18650 cell? Because I've got a S... load from old laptops
    • Si7021
    • external flash
    • radio module.
    Refering to what @tbowmo said and if you measure your batteries you will find that they will give more than 4V when fully charged I came to the conclusion that this is not a good idea.
    However if someone has a good proposal for how these kind of batteries are best used with the Sensebender Micro I would like to know also.
    • Tomas
      Mickey
      wrote on last edited by Mickey
      #42
      mcp1702 for example...
      • greglG
        greglG
        gregl
        Really nice board!
        I think it would be good to have ( ver 2? ) a space for a voltage reg. Perhaps as an option, just put the pads on the pcb and user can add regulator if they need to.
        This way larger batteries such as the 18650 cells could be used.
        jeylitesJ 1 Reply Last reply
        • greglG gregl
          Really nice board!
          jeylitesJ
          jeylitesJ
          jeylites
          I think version 2 should have a voltage regulator and about the same number of outputs as Arduino Nano.
          • tbowmoT
            tbowmoT
            tbowmo
            @jeylites
            It's designed to be a simple, minimal, small sensor node.. Operating from 2xAA batteries. So there is no need for voltage regulator onboard, I know this both simpilfies the circuit, but also makes some limitations on the powersource.
            What you are asking for, is an Arduino Nano, this has voltage regulator, and the number of IOs that you want :)
            • tbowmoT tbowmo
              @jeylites
              jeylitesJ
              jeylitesJ
              jeylites
              @tbowmo I have nothing against Sensebender Micro. I just feel there should be Sensebender full size version to facilitate the number of I/O one may need.
              • G
                G
                gloob
                So the shipment will start today for the preorders? I'm really excited to receive the new sensors.
                tbowmoT 1 Reply Last reply
                • G gloob
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @gloob
                  Yes, they should.
                  (Just checked.. 177 sensebender micro boards pre-ordered as I write this)
                  • korttomaK
                    korttomaK
                    korttoma
                    It would be nice to know how many devices has been preordered.
                    • Tomas
                    • HoffanH
                      HoffanH
                      Hoffan
                      I must ask one thing.
                      Which Radiochannel are there as default in the code in the sensebender Micro??
                      hekH 1 Reply Last reply
                      • HoffanH Hoffan
                        @Hoffan
                        It comes with the default from MyConfig (76)
                        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyConfig.h
                        • korttomaK korttoma
                          tbowmoT
                          tbowmoT
                          tbowmo
                          see the post above your latest? ;) I have just written it ther :)
                          blaceyB 1 Reply Last reply
                          • tbowmoT tbowmo
                            blaceyB
                            blaceyB
                            blacey
                            wrote on last edited by blacey
                            #53
                            @tbowmo Well, the fact that you can't order any more means there were at least 200 pre-ordered, right?
                              wrote on last edited by hek
                              #54
                              Well, first batch was 200 units (180 sold). Guess they want a few spare once if they have failures during test.
                              They are preparing for batch two but the Si7021-A20-GM humidity sensor was a bit hard to source at the moment. Will be solved soon. Not sure why preorders was disabled though, will check.
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @hek
                                Is the MySensors API/library set being updated to include the code needed for the on-board thermometer/humidity sensors for the Sensebender Micro, or will we be using another library?
                                I have not ordered any of these but was considering them for an upcoming project to measure temperature/humidity.
                                  No, it won't be included in the core MySensors library.
                                  https://github.com/mysensors/Arduino/tree/master/libraries/SI7021
                                  • DwaltD
                                    DwaltD
                                    Dwalt
                                    Has anyone who preordered these boards received any update (shipping confirmation) from ITead? Originally their website estimated May 20 ship date.
                                    • G
                                      G
                                      gloob
                                      I did a preorder for the items but did not get any new information about the shipment.
                                      The status of the items is still "processing".
                                        I've asked Itead for an update. But they're on china time so hopefully we'll get reply in a few hours.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          There is an update on iteadstudios facebook page, that they have finished assembling today, and will proceed to testing tomorrow.
                                          So hopefully they will start shipping soon.
