  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 655.6k Views 35 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    @tbowmo said:
    absolute maximum voltage is 3.6V
    But will all components work properly on 3.3V?
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • tbowmoT
      tbowmoT
      tbowmo
      @rvendrame
      Yes they would
      • rvendrameR
        rvendrameR
        rvendrame
        @tbowmo thx a lot!
        Alexa / Google Home
        • D
          doblanch
          I didn't find mention of it. What is the expected battery life ?
          I was going to replace AA by CR123 to gain in space.
          thkx
            I posted some measurements above. Hard to say a definite battery life expectation. Depends on many factors such as battery quality, send frequency and what external sensors you attach.
            D 1 Reply Last reply
              @gol
              It was measured by @blacey to 0.05 mA while sleeping and 0.95 mA during transmit. @tbowmo got some higher figures but they were most probably related to running a NRF24L01+ clone.
              @jeylites
              Yes, have a look at the bootloader here:
              https://github.com/mysensors/Arduino/tree/master/MYSBootloader
              You can test OTA updates using the MYSController. It overwrites program memory in-place during boot. If communication goes down or fails during this process the node won't boot up again (you have to upload a new sketch while connected to you computer).
              The sensbender has a external flash which means we can safely store the OTA firmware while normal sketch is running. When everything has been downloaded the DualOptiboot moves new firmware from flash to program memory during bootup. The code for this has been written (in development branch) but has not been tested yet (I failed handsoldering them :() .
              doblanch
              wrote on last edited by doblanch
              #38
              @hek I computed that sending a value every minute with a 10 seconds of communication every minute (wakeup), the autonomy for a single 3V 1500mA CR123 lithium battery is around 1 year (312 Days). Around 2 year for a dual Lithium AA, I guess.
              If there is 5 second of wakeup every minute, it's 500 days for a single cell CR123.
              Purely theorical... but it gives an order of magnetude.
                doblanch
                @hek Of course it's difficult to predict, it's just to have an order of magnitude, specially if I want to use a CRV123 3V battery. I don't want to change it every 2 months. One year should be good.
                • H
                  H
                  Hausner
                  wrote on last edited by Hausner
                  #40
                  Would this work with a 3,7V Li-Ion 18650 cell? Because I've got a S... load from old laptops
                  • tbowmoT tbowmo
                    @rvendrame
                    absolute maximum voltage is 3.6V, above that you'll let the magic smoke out of the following components:
                    • Si7021
                    • external flash
                    • radio module.
                    Only the atmega328 and atsha204 will survive.
                    korttomaK
                    korttomaK
                    korttoma
                    • Si7021
                    • external flash
                    • radio module.
                    Refering to what @tbowmo said and if you measure your batteries you will find that they will give more than 4V when fully charged I came to the conclusion that this is not a good idea.
                    However if someone has a good proposal for how these kind of batteries are best used with the Sensebender Micro I would like to know also.
                    • Tomas
                      Mickey
                      wrote on last edited by Mickey
                      #42
                      mcp1702 for example...
                      • greglG
                        greglG
                        gregl
                        Really nice board!
                        I think it would be good to have ( ver 2? ) a space for a voltage reg. Perhaps as an option, just put the pads on the pcb and user can add regulator if they need to.
                        This way larger batteries such as the 18650 cells could be used.
                        jeylitesJ 1 Reply Last reply
                        • greglG gregl
                          Really nice board!
                          jeylitesJ
                          jeylitesJ
                          jeylites
                          I think version 2 should have a voltage regulator and about the same number of outputs as Arduino Nano.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @jeylites
                            It's designed to be a simple, minimal, small sensor node.. Operating from 2xAA batteries. So there is no need for voltage regulator onboard, I know this both simpilfies the circuit, but also makes some limitations on the powersource.
                            What you are asking for, is an Arduino Nano, this has voltage regulator, and the number of IOs that you want :)
                            • tbowmoT tbowmo
                              @jeylites
                              jeylitesJ
                              jeylitesJ
                              jeylites
                              @tbowmo I have nothing against Sensebender Micro. I just feel there should be Sensebender full size version to facilitate the number of I/O one may need.
                              • G
                                G
                                gloob
                                So the shipment will start today for the preorders? I'm really excited to receive the new sensors.
                                tbowmoT 1 Reply Last reply
                                • G gloob
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @gloob
                                  Yes, they should.
                                  (Just checked.. 177 sensebender micro boards pre-ordered as I write this)
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    It would be nice to know how many devices has been preordered.
                                    • Tomas
                                    • HoffanH
                                      HoffanH
                                      Hoffan
                                      I must ask one thing.
                                      Which Radiochannel are there as default in the code in the sensebender Micro??
                                      hekH 1 Reply Last reply
                                      • HoffanH Hoffan
                                        @Hoffan
                                        It comes with the default from MyConfig (76)
                                        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyConfig.h
                                        • korttomaK korttoma
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          see the post above your latest? ;) I have just written it ther :)
                                          blaceyB 1 Reply Last reply
