  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @gloob
    We'll continue selling, as long as there is a demand for it :)
    • G
      G
      gloob
      I believe in your product and ordered 5 new ones. The house has too many rooms.
      • S
        Stric
        Got mine today. Haven't tried them yet.
          @Stric
          Nice! Where do you live? Wonder when it will show up in Sweden....
          • S
            Stric
            Sweden :) Umeå/Täfteå to be specific.. Neighborhood next to your brother..
              Sweet.. hope it arrives before the weekend then.
              • H
                H
                HenkeP
                @Stric Did you get a "avi", or did they end up in the mail-box directly? I got a "avi" today but it might be also for any of the constant inflow of stuff from aliexpress... Can't wait for my 4 pieces Sensebender to show up! :)
                S 1 Reply Last reply
                • H HenkeP
                  Stric
                  @HenkeP Got an avi, RsomethingsomethingHK I believe.. The box said "10 printed circuit boards", which is a funny way of saying "3 printed circuit boards + some stuff".
                  • G
                    G
                    gloob
                    Were you able to track the items? My tracking number says that it left Hong Kong yesterday to my destination (Germany). Can't wait to get the first batch into hands.
                    • G
                      G
                      gol
                      I can confirm that the first sensebenders now also have arrived in Gothenburg, Sweden.
                      • G
                        G
                        gol
                        My first Senseboard is now Up and Running. Have even tested to reinstall the sketch. No issues so far. Thanx for this product.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @gol
                          Nice to hear :)
                          I have to wait until Monday, before I can pick mine up at the post office.. (they tried to deliver it today, when I wasn't at home, so just left me a note that I could pick it up on Monday)
                          • G gol
                            marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            This is not a 'product', this is pure fun ;)
                            Fulltime Servoy Developer
                            • H
                              H
                              HenkeP
                              Picked up my four devices yesterday and two of them are up and running using the pre-loaded sketch and it works like a charm!
                              But i have a question regarding the battery level reporting, I can see the following in the code:
                              // Battery voltage is repported as child sensorId 199, as well as battery percentage (Internal message)
                              But it seems to only present temp and hum as sensors and no voltage:
                              gw.present(CHILD_ID_TEMP,S_TEMP);
                              gw.present(CHILD_ID_HUM,S_HUM);
                              What is it i'm failing to understand? I just setup Domoticz and in there I have not yet got a good way of presenting historical battery levels, it just shows the latest internal battery level message. To get a better understanding on the battery life performance it is necessary to be able to create a graph. I thought I could use the voltage level for this but I can only see the internal message :-(
                              Thanks,
                              Henrik
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                #95
                                @HenkeP
                                That's a leftover from my initial battery monitoring code. It could be re-implemented quite easily, in the battery reporting routine, you could report actual voltage measured, as an extra sensor
                                (I actually thought that I had removed everything related to the old monitoring code)
                                Edited
                                I have updated the sketch for sensebender micro, to include sending battery voltage measurements as a sensor value. This is not enabled by default though, and people need to recompile it, with a #define uncommented.
                                do a pull from mysensors github, to get the latest sourcecode
                                  @hautomate said:
                                  3,091 in stock
                                  That's the old A10. It would probably work but A20 has some firmware fixes and more tests performed on it.
                                  I have nothing to say about the price. It is the same as for A20.. As you can see it is the most expensive part on the micro board (30% of it's price).
                                  twosh
                                  Would you consider a Sensebender Micro Light-version without this component? i mean, if it's 30 % of the price, not available and not imo a critical component (you could always add your own humidity/temp sensors), there are quite a few reasons why a light version would be tempting. At least to me. :)
                                  Cheers,
                                  Tim
                                  • sundberg84S
                                    @twosh @hek A Sensebender Light would be great is my opinion. Im not looking for these advances futures, only a simple and as cheap as possible board to run on batteries and a temp sensor. Br Andreas
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      #98
                                      @twosh, @sundberg84
                                      Well, it's a temperature sensor, and humidity in one :). If you are going to use other sensor types (DS1820, or cheaper humidity/temperature sensors), you also need to have a booster circuit, in order to boost battery voltage to 3V minimum (as they don't operate on voltages lower than that).
                                      So in the end, you'll buy both booster circuits, and sensors, which will be close to the same price as the Si7021 in the end, to get the same functionality.
                                      And since you (probably) are using a cheap booster circuit from ebay, the battery would not last that long, so you buy lot's of batteries to feed the booster circuitry :)
                                      But when that's said, we could ask itead if they could make a "barebone" unit, without the Si7021 mounted, and then provide a quote on that type of sensor.
                                      • sundberg84S
                                        @tbowmo
                                        Thank you for your answer tbowmo - i see your logic.
                                        But if you want to use it with say, light, motion or another sensor with this board - do I need a booster?
                                        • H
                                          H
                                          hawk_2050
                                          I'll add my voice to the requests for a 'lite' version of the Sensebender Micro board. My ideal would be to provide an option without the A20 secure signing IC placed, but leaving the Si7021 in.
                                          Cheers
                                          Richard
