  3. Newbie Problem! Get Started with NRF24L01+
55 Posts 9 Posters 28.0k Views 2 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    Do you have a standalone relay, or a arduino relay board, like this picture?
    http://www.mysensors.org/relay/relayModule.png
    The board contains a transistor. Some boards also have a 'hi-low' switch, if yours have it, you may try to play with it.
    The arduino output is max of 40ma and will eventually burn or not operate correctly if connected directly to a relay. You must have a transistor in between.
    Make sure you relay board contains at least this circuit: http://www.electroschematics.com/8975/arduino-control-relay/
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    F 2 Replies Last reply
    • rvendrameR rvendrame
      F
      F
      fakeJake
      @rvendrame My relay is more like this http://www.elecdesignworks.com/images/stories/virtuemart/product/img_62112.jpg
      Thank you for your reference.
      It has a transistor. I hope it's ok to use. I have tested it by following an instructable.
        F
        F
        fakeJake
        @rvendrame You know what. I'm really thankful for you help and I'm really sorry for dragging you with me. I can turn the light on now. I just have to print "2;1;1;1;2;0;" instead of "2;1;1;1;2;1".
        I will check if I will encounter any problem because of my relay module.
        Again, thank you so much for your help. And I'm really sorry.
        • rvendrameR
          rvendrameR
          rvendrame
          Just swap the 0 & 1 here:
          and it will obey as you expect. Some relays boards have inverted input (Zero/GND is ON and VCC is OFF) ;-)
          I'm glad it worked.
          Alexa / Google Home
          • F
            F
            fakeJake
            This post is deleted!
            • F
              F
              fakeJake
              Is there a way to receive only the last state of the sensors/actuators in the serial?
              instead of:
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=2,pt=2,l=2:1
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=2,pt=2,l=2,st=ok:1
              2;1;1;0;2;1
              it only print the "2;1;1;0;2;1" on the serial
              • F
                F
                fakeJake
                I placed if statement in serial function inside MyGateway.cpp
                where 0 is the gateway address
                void MyGateway::serial(MyMessage &msg) {
                  if (msg.sender != 0); serial(PSTR("%d;%d;%d;%d;%d;%s\n"),msg.sender, msg.sensor, mGetCommand(msg), mGetAck(msg), msg.type, msg.getString(convBuf));
                Still it doesnt work.
                Heres the format:
                    msg.sender = GATEWAY_ADDRESS;
                	msg.destination = destination;
                	msg.sensor = sensor;
                	msg.type = type;
                	mSetCommand(msg,command);
                	mSetRequestAck(msg,ack?1:0);
                	mSetAck(msg,false);
                	if (command == C_STREAM)
                		msg.set(bvalue, blen);
                	else
                		msg.set(value);
                • S
                  Stric
                  Note the ; after the 0) which should not belong there..
                  F 1 Reply Last reply
                  • S Stric
                    F
                    F
                    fakeJake
                    @Stric Removed it but still the read and send appears
                    • F
                      F
                      fakeJake
                      Should I post my new question on another board?
                      Re: s there a way to receive only the last state of the sensors/actuators in the serial?
                        The gateway itself doesn't buffer anything. It just forwards the data from your sensors.
                          F
                          F
                          fakeJake
                          @hek can you please help me on what should I comment out?
                            turn off DEBUG in MyConfig.h (by commenting it out) before comping you gateway sketch to get rid of debug messages.
                              F
                              F
                              fakeJake
                              @hek Thank you! I will try it as soon as I go home. Can you tell me what is the expected output from the gateway if I use static id 2 for a relayActuator that I turned on?
                              will it be just "2;1;1;0;2;1" or will "2;255;x;x;x;x" appear? only the read/send data is hidden
                              • F
                                F
                                fakeJake
                                Is it ok to have two gateways?
