  3. Newbie Problem! Get Started with NRF24L01+
55 Posts 9 Posters 28.0k Views 2 Watching
  • rvendrameR rvendrame
    How are you powering your node? Your node's radio is constantly fail to transmit (st=fail).
    It's actually the gateway having problems transmitting acks back to node.
    F 1 Reply Last reply
      F
      F
      fakeJake
      I'm powering the nrf modules from same 3.3V supply since I haven't bought a regulator yet. I'll test it again later. I'll be going out to buy them now.
      Just to give me a heads up. What should the serial gateway get after i press the inclusion button?
      • F
        F
        fakeJake
        wrote on last edited by fakeJake
        #23
        Sorry for the late reply
        Each modules are now supplied with 5V and 3.3V.
        This is the serial gateway output:
        0;0;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5:30.2
        1;0;1;0;0;30.2
        0;0;3;0;9;Inclusion started by button.
        0;0;3;0;5;1
        0;0;3;0;5;0
        This is the temp output:
        sensor started, id 1
        send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
        send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
        send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor
        send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
        send: 1-1-0-0 s=0,c=0,t=6,pt=0,l=5,st=fail:1.4.1
        send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:30.2
        st keeps on failing. I checked the nrf supply and it ranges from 3.1v to 3.3 v. Is this bad? I'm using spx2815 since it's the only thing available to me. I placed 10uF capacitor in the 5v input and 3.3v output to ground
          Maybe this may cover it http://www.mysensors.org/download/serial_api_14
          F
          F
          fakeJake
          It only explains the "0;0;3;0;14;" but not the "s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor" that it sends or reads
          • rvendrameR
            rvendrameR
            rvendrame
            @fakeJake , are the node far from gateway, or any obstacle (such as a wall) in between? Another source of interference is for example a microwave.
            ESP8266 GW + mySensors 2.3.2
            Alexa / Google Home
              F
              F
              fakeJake
              They are just 6 inches apart :worried:
              • rvendrameR
                rvendrameR
                rvendrame
                Some people reported trouble with cheap fake radios. If you have spares nRF try replacing one of them or both.
                You mentioned a flotation (3.1 to 3.3) in radio VCC, this can also be a reason, as these nRF are very sensible to power variations.
                Post your sketches too, just incase...
                Alexa / Google Home
                • F
                  F
                  fakeJake
                  I'm using the DallasTemperatureSensor.ino on MySensors library. I just change the gw.begin(); to gw.begin(NULL, 1);
                  // Example sketch showing how to send in OneWire temperature readings
                  #include <OneWire.h>
                  OneWire oneWire(ONE_WIRE_BUS);
                  int numSensors=0;
                  boolean metric = true;
                  MyMessage msg(0,V_TEMP);
                    // Startup OneWire
                    sensors.begin();
                    gw.begin(NULL,1);
                    gw.sendSketchInfo("Temperature Sensor", "1.0");
                       gw.present(i, S_TEMP);
                    gw.process();
                      if (lastTemperature[i] != temperature && temperature != -127.00) {
                    gw.sleep(SLEEP_TIME);
                  • F
                    F
                    fakeJake
                    Good news! The gateway is now working :)
                    I changed the dallas temperature to relay actuator and, yes, it's now working!
                    Bad news is I still don't know what went wrong with my temperature sensor.
                    I'll investigate on it soon.
                    This is the gateway output:
                    0;0;3;0;9;read: 2-2-0 s=255,c=0,t=18,pt=0,l=5:1.4.1
                    2;255;0;0;18;1.4.1
                    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
                    2;255;3;0;6;0
                    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=5:Relay
                    2;255;3;0;11;Relay
                    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.0
                    2;255;3;0;12;1.0
                    0;0;3;0;9;read: 2-2-0 s=1,c=0,t=3,pt=0,l=5:1.4.1
                    2;1;0;0;3;1.4.1
                    This is the relay output:
                    repeater started, id 2
                    send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                    send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                    send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
                    send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                    send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                    I just need to test it.
                    Since I'll be using a gsm to control the relay. Can you help me on what to send to the relay to turn it on/off?
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      @fakeJake , I' m glad it worked with relay sketch.
                      Regarding the temperature, try to move the sensor to other arduino pin. Pin 2 & 3 are used by interrupts and may not play nice with gw.sleep depending on the lib used.
                      To send a message to the relay , you need a controller connected to the GW, either via USB or ethernet. You can also simulate it by entering the message on the Serial monitor.
                      The protocol is described here http://www.mysensors.org/download/serial_api_14
                      Alexa / Google Home
                      • F
                        F
                        fakeJake
                        #31
                        I tried entering message on the serial monitor of the gateway but still no luck.
                        This is the closest thing that I did to tell the relay to turn the light on.
                        Gateway output after I enter "2;0;1;1;2;1;" to the Serial monitor:
                        0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
                        2;255;0;0;17;1.4.1
                        2;255;3;0;6;0
                        2;255;3;0;11;Relay
                        2;255;3;0;12;1.0
                        2;1;0;0;3;1.4.1
                        0;0;3;0;9;send: 0-0-2-2 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                        0;0;3;0;9;read: 2-2-0 s=0,c=1,t=2,pt=0,l=1:1
                        2;0;1;1;2;1
                        Relay output after "2;0;1;1;2;1;" :
                        sensor started, id 2
                        send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                        read: 0-0-2 s=0,c=1,t=2,pt=0,l=1:1
                        send: 2-2-0-0 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                        Incoming change for sensor:0, New status: 1
                        Still it doesn't turn on the light
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          Maybe you can you connect the node also in a USB port, and open a serial monitor for it? You would see if it is receiving the message correctly.
                          Alexa / Google Home
                            F
                            F
                            fakeJake
                            @rvendrame Sorry I forgot to include that, I edited the post
                            • F
                              F
                              fakeJake
                              #34
                              It still doesn't open the light even if I change it to "2;255;1;1;2;1;"
                              I checked the relay using relay.ino from an instructable controlling ac light with relay and it's working.
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                Can we see your sensor's sketch?
                                Alexa / Google Home
                                • F
                                  F
                                  fakeJake
                                  #36
                                  I just changed the gw.begin();
                                  // Example sketch showing how to control physical relays.
                                  // This example will remember relay state even after power failure.
                                    gw.begin(incomingMessage, 2);
                                    gw.sendSketchInfo("Relay", "1.0");
                                    // Fetch relay status
                                      gw.present(sensor, S_LIGHT);
                                      pinMode(pin, OUTPUT);
                                      digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                                    gw.process();
                                    if (message.type==V_LIGHT) {
                                       // Change relay state
                                       // Store state in eeprom
                                       // Write some debug info
                                       Serial.print(message.sensor);
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    Means your are asking to activate relay 'zero'.
                                    So digital pin will be 0 - 1 + RELAY_1 = 0 - 1 + 3 = 2
                                    Conclusion: Try activating relay 1 instead 0. ;-)
                                    Alexa / Google Home
                                      F
                                      F
                                      fakeJake
                                      #38
                                      @rvendrame The light is still not turning on :sweat:
                                      I even change it to "2;257;1;1;2;1" just incase 255 is the message.sensor but it still prints "2;1;1;1;2;1" so I there's no problem there.
                                      read: 0-0-2 s=1,c=1,t=2,pt=0,l=1:1
                                      send: 2-2-0-0 s=1,c=1,t=2,pt=0,l=1,st=ok:1
                                      Incoming change for sensor:1, New status: 1
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        how the relay is connected to arduino pin 3? Is there a transistor in between?
                                        Alexa / Google Home
                                          F
                                          F
                                          fakeJake
                                          #40
                                          @rvendrame No transistor. I just followed MySensors: Build Relay Actuator. I directly connected the 5v, gnd and signal to the arduino.
