  3. Anybody else seeing - unstable nodes - Need restart every ~24-48 hours?
13 Posts 7 Posters 5.4k Views 1 Watching
  • J
    J
    Joey Edelstein
    I built a small home automation setup based on ago controller on a Raspberry pi with a serial gateway.
    I have 3 nodes and they all work fine after being plugged in and continue for a while but after 24-48 they stop working.
    If I unplug and plug back in they come back to life. I haven't been able to debug as the restart that comes with trying makes them work fine.
    At first I though the issue was with the build quality (I solder like a butcher) but I added a temp/humidity sensor on a bread board with good Arduino and am seeing the same issues.
    Anybody seeing something like this?
    Any ideas how to debug?
    Joey
    A 1 Reply Last reply
    • korttomaK
      korttomaK
      korttoma
      I had a node with similar behavior. In my case I found that the radio got to high voltage so the radio caused the hole node to freeze.
      Most problems are usually related to power supply so I would start the investigation there.
      • Tomas
      J 1 Reply Last reply
      • A
        A
        andriej
        Running out of memory - that's the problem for most of programs/nodes.
        I have this problem in one too, so I made a code to restart node every x hours.
        • korttomaK korttoma
          J
          J
          Joey Edelstein
          I have this on a number of nodes using different power supplies. I have measured the voltage in to the radio arduino. I also have have a decoupling capacitor of 4.7uF across the radio's 3.3V and GND.
          While it could be a mem leak if that is the case it in the mysensor lib as my sketch is pretty basic and should be using constant memory .
          RJ_MakeR 1 Reply Last reply
            The library does not use any dynamic allocation. So I doubt it it a memory leak situation.
            • J Joey Edelstein
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              Try a large cap, try 47uf
              RJ_Make
              • J Joey Edelstein
                Joey
                A
                A
                andriej
                @Joey-Edelstein try posting a code here so we can look better, maybe it's one of libraries?
                or interrupt? or something...
                • J
                  J
                  Joey Edelstein
                  This is the simplest sketch I'm using that is demonstrating the behavior I described:
                  https://codebender.cc/sketch:103465
                  • H
                    H
                    HarryDutch
                    @Joey-Edelstein
                    Have a look here. Remove all Serial.print(...) and Serial.println(...) and try again. Or use Serial.print(F(....)).
                    • H HarryDutch
                      @Joey-Edelstein
                      J
                      J
                      Joey Edelstein
                      interesting. I will give it a try. Thanks!
                      • J
                        J
                        Joey Edelstein
                        Just a thought here but if Serial.print("This string that gets allocated every time this is called") and basically is a memory leak shouldn't samples be updated to use Serial.print(F(....)) so the unwashed masses (like me) don't make stupid mistakes?
                        In the meantime I have updated my most accessible node and will see if this solves my issues.
                          The normal Serial.println() using char-array does not leak memory. The F()-version just uses less of the precious RAM by keeping the strings in flash.
                          So the F() is really good to use, especially if you're sketch is big.
                          • G
                            G
                            GaryStofer
                            Maybe you can setup a RF sniffer as seen here http://forum.mysensors.org/topic/242/wireless-nrf24l01-sniffer-for-mysensors and observe what traffic you see when the system or node fails to give you some clues as to what is going on ?
