Anybody else seeing - unstable nodes - Need restart every ~24-48 hours?
I built a small home automation setup based on ago controller on a Raspberry pi with a serial gateway.
I have 3 nodes and they all work fine after being plugged in and continue for a while but after 24-48 they stop working.
If I unplug and plug back in they come back to life. I haven't been able to debug as the restart that comes with trying makes them work fine.
At first I though the issue was with the build quality (I solder like a butcher) but I added a temp/humidity sensor on a bread board with good Arduino and am seeing the same issues.
Anybody seeing something like this?
Any ideas how to debug?
Joey -
I had a node with similar behavior. In my case I found that the radio got to high voltage so the radio caused the hole node to freeze.
Most problems are usually related to power supply so I would start the investigation there. -
Most problems are usually related to power supply so I would start the investigation there.I have this on a number of nodes using different power supplies. I have measured the voltage in to the radio arduino. I also have have a decoupling capacitor of 4.7uF across the radio's 3.3V and GND.
While it could be a mem leak if that is the case it in the mysensor lib as my sketch is pretty basic and should be using constant memory . -
While it could be a mem leak if that is the case it in the mysensor lib as my sketch is pretty basic and should be using constant memory .@Joey-Edelstein said:
While it could be a mem leak if that is the case it in the mysensor lib as my sketch is pretty basic and should be using constant memory .Try a large cap, try 47uf
Joey@Joey-Edelstein try posting a code here so we can look better, maybe it's one of libraries?
or interrupt? or something... -
This is the simplest sketch I'm using that is demonstrating the behavior I described:
https://codebender.cc/sketch:103465 -
Have a look here. Remove all Serial.print(...) and Serial.println(...) and try again. Or use Serial.print(F(....)).
interesting. I will give it a try. Thanks!
Just a thought here but if Serial.print("This string that gets allocated every time this is called") and basically is a memory leak shouldn't samples be updated to use Serial.print(F(....)) so the unwashed masses (like me) don't make stupid mistakes?
In the meantime I have updated my most accessible node and will see if this solves my issues.
Maybe you can setup a RF sniffer as seen here http://forum.mysensors.org/topic/242/wireless-nrf24l01-sniffer-for-mysensors and observe what traffic you see when the system or node fails to give you some clues as to what is going on ?
