  3. Multisensor PIR problem [solved]
53 Posts 7 Posters 27.0k Views 3 Watching
  • SweebeeS Offline
    SweebeeS Offline
    Sweebee
    wrote on last edited by Sweebee
    #41
    If a switch works than the only could be the pir itself. You have enabled the pull-up resistor so an open collector should not give floats.
    You already told that a sketch with a pir only worked fine?
    Well, i can test what happens with my dht22 and a pir tomorrow (with your sketch).
    N 1 Reply Last reply
    • SweebeeS Sweebee
      N Offline
      N Offline
      n3ro
      @Sweebee thy this would be very nice :)
      You find my sketch here:
      https://github.com/n3roGit/MySensors_n3ro/tree/master/MotionSensor_DHT_light_battery_mod
      pimatic + MySensors + Homeduino + z-way
      B 1 Reply Last reply
      • N n3ro
        B Offline
        B Offline
        BulldogLowell
        @n3ro
        you are sending an update on the PIR status every time the arduino wakes from a sleep, which you don't need.
        Also, and this probably isn't a problem right now, but will case a problem later, use unsigned subtraction in your millis( ) timers
        could not see where you were using the library, so I commented it out below, not having it on my computer
        I also made a few more notes in the code:
        //#include <readVcc.h> // cannot see where you are using this library yet
        #include <DHT.h>
        #define NODE_ID 10                       // ID of node
        unsigned long SLEEP_TIME = 10000UL;        // Sleep time between reports (in milliseconds)
        #define CHILD_ID_PIR 1                   // Id of the sensor PIR
        #define CHILD_ID_HUM 2                   // Id of the sensor HUM
        #define CHILD_ID_TEMP 3                  // Id of the sensor TEMP
        #define CHILD_ID_LIGHT 4                 // Id of the sensor LIGHT
        #define PIR_SENSOR_DIGITAL 3           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
        #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
        #define HUMIDITY_SENSOR_DIGITAL_PIN 2
        #define LIGHT_SENSOR_ANALOG_PIN 0
        // Initialize Variables
        MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
        MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = true;
        boolean lastTripped = false;
        int oldBatteryPcnt;
        int lastLightLevel;
        unsigned long mytime;
        //int MIN_V = 2700; // empty voltage (0%)
        //int MAX_V = 3200; // full voltage (100%)
          gw.begin(NULL, NODE_ID, false);
          gw.sendSketchInfo("Motion Sensor", "1.0"); // here you call it motion sensor
          pinMode(PIR_SENSOR_DIGITAL, INPUT_PULLUP);
          gw.present(CHILD_ID_PIR, S_MOTION);
          //gw.sendSketchInfo("Humidity", "1.0"); // here you call it humidity
          //gw.sendSketchInfo("Light Sensor", "1.0");// pick a name for your sketch, it will only be one
          gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
          // why send this every time?
          boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH;
          Serial.print("---------- PIR: ");
          Serial.println(tripped);
          gw.send(msgPir.set(tripped ? "1" : "0"));
          if (tripped != lastTripped)  // only need to update controller on a change.
            gw.send(msgPir.set(tripped? "1" : "0"));
            Serial.println(tripped? "tripped" : " not tripped");
            lastTripped = tripped;
          if ( millis() - mytime >= SLEEP_TIME )  //use UNSIGNED SUBRTACTION im your millis() timers to avoid rollover issues later on down the line
            if (isnan(temperature))
            else if (temperature != lastTemp)
              lastTemp = temperature;
              if (!metric)
              Serial.print("---------- Temp: ");
              Serial.println(temperature);
            if (isnan(humidity))
            else if (humidity != lastHum)
              lastHum = humidity;
              Serial.print("---------- Humidity: ");
              Serial.println(humidity);
            mytime = millis();
          gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); // Sleep until interrupt detected from motion sensor. Send update every SLEEP_TIME.
        • B BulldogLowell
          @n3ro
          #include <DHT.h>
          DHT dht;
          float lastTemp;
          float lastHum;
          int oldBatteryPcnt;
          int lastLightLevel;
                if (!metric)
                lastHum = humidity;
              mytime = millis();
          N Offline
          N Offline
          n3ro
          @BulldogLowell
          Hey, its a good idea to send only PIR if changed!
          The unused code in the sketch is because i have reduced the used functions to the minimum to debug it better. The full sketch has LDR and battery lifetime output too.
          i have added some extra output in the modified sketch:
          #include <DHT.h>
          DHT dht;
          float lastTemp;
          float lastHum;
          int oldBatteryPcnt;
          int lastLightLevel;
              Serial.println(tripped ? "tripped" : " not tripped");
                if (!metric)
                lastHum = humidity;
              mytime = millis();
            else
              Serial.println("no millis");
            Serial.println(millis());
            Serial.println(mytime);
            Serial.println(SLEEP_TIME);
          send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
          ---------- PIR: not tripped
          no millis
          2185
          no millis
          2189
          no millis
          2193
          no millis
          2195
          no millis
          2197
          no millis
          2201
          no millis
          2203
          no millis
          2205
          no millis
          2209
          no millis
          2211
          no millis
          You can see that the "if millis" will never used .:(
          • N Offline
            N Offline
            n3ro
            i think millis didnt work with sleep. the counter is not increasing when sleeping..
            • B Offline
              B Offline
              BulldogLowell
              you dont need this:
              since you are sleeping longer than the minimum sampling period
              try like this, removing the timer, just use the sleep period t update temp/humidity (untested):
              #include <DHT.h>
              DHT dht;
              float lastTemp;
              float lastHum;
              int oldBatteryPcnt;
              int lastLightLevel;
                  if (!metric)
                  lastHum = humidity;
              • B BulldogLowell
                you dont need this:
                #include <DHT.h>
                DHT dht;
                float lastTemp;
                float lastHum;
                int oldBatteryPcnt;
                int lastLightLevel;
                    if (!metric)
                    lastHum = humidity;
                N Offline
                N Offline
                n3ro
                @BulldogLowell
                when i use this sketch the PIR works but the DHT cant read:
                • B Offline
                  B Offline
                  BulldogLowell
                  check the connections
                  • B BulldogLowell
                    N Offline
                    N Offline
                    n3ro
                    @BulldogLowell the wires are OK.
                    In sleep the DHT cant warm-up. so the dht need 2 sec before read. when i dont use the delay i cant read it.
                    i dont understand why the interrupt didnt work with the enabled delay.
                    do you have tested on a arduino?
                    • N Offline
                      N Offline
                      n3ro
                      now its working. when i use PIN4 for DHT.:)
                      • R Offline
                        R Offline
                        rvendrame
                        @n3ro, i'm glad you fixed it. DHT was on PIN3 before, right? Pin 2 & Pin3 are connected to the interrupts, maybe this was the problem.
                        ESP8266 GW + mySensors 2.3.2
                        Alexa / Google Home
                        • R rvendrame
                          N Offline
                          N Offline
                          n3ro
                          @rvendrame yes i think so. but now its ok =)
                          • N n3ro
                            B Offline
                            B Offline
                            BulldogLowell
                            :clap:
