  3. Multisensor PIR problem [solved]
53 Posts 7 Posters 27.0k Views 3 Watching
  • R Offline
    R Offline
    rvendrame
    wrote on last edited by rvendrame
    #21
    #define PIR_SENSOR_DIGITAL 3           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define HUMIDITY_SENSOR_DIGITAL_PIN 2
    #define LIGHT_SENSOR_ANALOG_PIN 0
    Are you connecting both DHT and PIR at same pin 2 ? That must be the cause (DHT is triggering the interruption, I think you want only the PIR to trigger it).
    Edit: looks like your PIR is at pin 3 , and DHT on pin 2 --- Should be the inverse? The PIR should be on pin 2 (to trigger the interrupt).
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    SweebeeS 1 Reply Last reply
    • R rvendrame
      SweebeeS Offline
      SweebeeS Offline
      Sweebee
      @rvendrame Pir sensor is defined as 3
      interrupt pin is defined as INT1: 3 - 2 = 1
      • R Offline
        R Offline
        rvendrame
        #23
        So PIR must connect on PIN 1 and not PIN 3.
        Edit: Better, how did you connect DHT and PIR?
        Alexa / Google Home
        N SweebeeS 2 Replies Last reply
        • R rvendrame
          N Offline
          N Offline
          n3ro
          wrote on last edited by n3ro
          #24
          @rvendrame The DHT is on pin 2 and the pir on pin 3. i use the MYS PCB.
          i suspect the delay function disturb the sleep function. if i dont use the delay, the dht cant "heat up".
          far as I know the interrupt is only an internal value. right?
          pimatic + MySensors + Homeduino + z-way
          https://github.com/n3roGit/MySensors_n3ro
          • R Offline
            R Offline
            rvendrame
            Yes, it looks fine. What exactly error are you having? From your first serial monitor, it looks like your sensor woke on every 10min aprox, ( 6608 / 11148 / 15441 ).
            Alexa / Google Home
            N 1 Reply Last reply
            • R rvendrame
              N Offline
              N Offline
              n3ro
              #26
              @rvendrame
              if i use this:
              #include <readVcc.h>
              #include <DHT.h>
              #define NODE_ID 10                       // ID of node
              unsigned long SLEEP_TIME = 600000;        // Sleep time between reports (in milliseconds)
              #define CHILD_ID_PIR 1                   // Id of the sensor PIR
              #define CHILD_ID_HUM 2                   // Id of the sensor HUM
              #define CHILD_ID_TEMP 3                  // Id of the sensor TEMP
              #define CHILD_ID_LIGHT 4                 // Id of the sensor LIGHT
              // Initialize Variables
              MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
              MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
              DHT dht;
              float lastTemp;
              float lastHum;
              boolean metric = true;
              int oldBatteryPcnt;
              int lastLightLevel;
              int MIN_V = 2700; // empty voltage (0%)
              int MAX_V = 3200; // full voltage (100%)
                gw.begin(NULL, NODE_ID, false);
                //PIR
                gw.sendSketchInfo("Motion Sensor", "1.0");
                pinMode(PIR_SENSOR_DIGITAL, INPUT);      // sets the motion sensor digital pin as input
                digitalWrite(PIR_SENSOR_DIGITAL, HIGH);
                gw.present(CHILD_ID_PIR, S_MOTION);
                //DHT
                gw.sendSketchInfo("Humidity", "1.0");
                //LIGHT
                gw.sendSketchInfo("Light Sensor", "1.0");
                gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
                // Measure battery
                float batteryV = readVcc();
                int batteryPcnt = (((batteryV - MIN_V) / (MAX_V - MIN_V)) * 100 );
                if (batteryPcnt > 100) {
                  batteryPcnt = 100;
                if (batteryPcnt != oldBatteryPcnt) {
                  gw.sendBatteryLevel(batteryPcnt); // Send battery percentage
                  oldBatteryPcnt = batteryPcnt;
                Serial.print("---------- Battery: ");
                Serial.println(batteryPcnt);
                // Read digital motion value
                boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH;
                Serial.print("---------- PIR: ");
                Serial.println(tripped);
                gw.send(msgPir.set(tripped ? "1" : "0")); // Send tripped value to gw
                //DHT
                //delay(dht.getMinimumSamplingPeriod());
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
                  Serial.print("---------- Temp: ");
                  Serial.println(temperature);
                if (isnan(humidity)) {
                  lastHum = humidity;
                  Serial.print("---------- Humidity: ");
                  Serial.println(humidity);
                // Light
                int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
                //Serial.println(lightLevel);
                  gw.send(msgLight.set(lightLevel));
                  lastLightLevel = lightLevel;
                  Serial.print("---------- Light: ");
                gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
              i get this output after starting:
              sensor started, id 10
              send: 10-10-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
              send: 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
              read: 0-0-10 s=255,c=3,t=6,pt=0,l=1:M
              send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:Motion Sensor
              send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
              send: 10-10-0-0 s=1,c=0,t=1,pt=0,l=5,st=ok:1.4.1
              send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=8,st=ok:Humidity
              send: 10-10-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
              send: 10-10-0-0 s=3,c=0,t=6,pt=0,l=5,st=ok:1.4.1
              send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Light Sensor
              send: 10-10-0-0 s=4,c=0,t=16,pt=0,l=5,st=ok:1.4.1
              send: 10-10-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:100
              ---------- Battery: 100
              ---------- PIR: 1
              send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:1
              send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:16.6
              ---------- Temp: 16.60
              send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:43.8
              ---------- Humidity: 43.80
              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:39
              ---------- Light: 39
              ---------- PIR: 0
              send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:0
              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:37
              ---------- Light: 37
              ---------- PIR: 1
              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:34
              ---------- Light: 34
              ---------- PIR: 0
              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:36
              ---------- Light: 36
              ---------- PIR: 1
              ---------- PIR: 0
              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:38
              ---------- Light: 38
              The DHT gives only output the first start and the pir interrupt works perfect.
              When delay(dht.getMinimumSamplingPeriod()); is activated the DHT works and the pit interrupts the whole time :(
              In this configuration the arduino never sleeps ..
              ---------- PIR: 1
              send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:16.5
              ---------- Temp: 16.50
              send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:43.9
              ---------- Humidity: 43.90
              ---------- PIR: 1
              ---------- PIR: 0
              ---------- PIR: 0
              ---------- PIR: 0
              EDIT: i have changed the sleeptime for testing to a shorter time
              • R rvendrame
                SweebeeS Offline
                SweebeeS Offline
                Sweebee
                @rvendrame When the PIR is connected to PIN3 the interrupt is INT1. Pin 1 does not have an interrupt.
                Only pin 2 and pin 3 have an interrupt.
                Pin 2 = int0
                pin 3 = int1
                • R Offline
                  R Offline
                  rvendrame
                  if you put the delay() inside that 'if ( mills() > mytime ) ' , what happens?
                  Alexa / Google Home
                  • SweebeeS Sweebee
                    Pin 2 = int0
                    pin 3 = int1
                    N Offline
                    N Offline
                    n3ro
                    @Sweebee is it possible to fix the problem when DHT is connected to pin 4?
                    • R Offline
                      R Offline
                      rvendrame
                      It worth a try ...
                      Alexa / Google Home
                      • R rvendrame
                        N Offline
                        N Offline
                        n3ro
                        @rvendrame
                        i have posted it before this post:
                        "What is this number? Did you print the milis()?
                        send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
                        6608 <<<<<<"
                        in the posted sketch the delay is inside millis
                        • R Offline
                          R Offline
                          rvendrame
                          I didn't find the if ( millis() > my time) in the last sketch you posted ...
                          Alexa / Google Home
                          • N Offline
                            N Offline
                            n3ro
                            if i use this
                            #include <DHT.h>
                            unsigned long SLEEP_TIME = 10000;        // Sleep time between reports (in milliseconds)
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                            int oldBatteryPcnt;
                            int lastLightLevel;
                            long mytime = 0;
                              //PIR
                              //DHT
                              //LIGHT
                              if ( millis() > mytime )  {
                                //DHT
                                  if (!metric) {
                                  lastHum = humidity;
                                mytime = millis() + dht.getMinimumSamplingPeriod();
                            i get this output:
                            ---------- PIR: 1
                            send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:17.2
                            ---------- Temp: 17.20
                            ---------- PIR: 1
                            ---------- PIR: 0
                            ---------- PIR: 0
                            ---------- PIR: 0
                            ---------- PIR: 1
                            ---------- PIR: 0
                            ---------- PIR: 1
                            ---------- PIR: 0
                            ---------- PIR: 1
                            ---------- PIR: 0
                            ---------- PIR: 0
                            ---------- PIR: 0
                            • SweebeeS Offline
                              SweebeeS Offline
                              Sweebee
                              This can't work well. Your interrupt is set on pin1 - 2 = int-1?
                              What happens when you remove the pir and use a switch instead?
                              • SweebeeS Sweebee
                                N Offline
                                N Offline
                                n3ro
                                @Sweebee
                                is #define INTERRUPT PIR_SENSOR_DIGITAL-2 wrong?
                                when i use a switch it looks OK
                                • R Offline
                                  R Offline
                                  rvendrame
                                  @n3ro , what is wrong at your last test? The PIR is reporting 0 and 1, and from time to time there is a temp/hum report as well.
                                  Alexa / Google Home
                                  • R rvendrame
                                    N Offline
                                    N Offline
                                    n3ro
                                    @rvendrame in my last test the pir sends endless 0 and dont sleep
                                    • R Offline
                                      R Offline
                                      rvendrame
                                      Which arduino PIN do you use to connect the PIR?
                                      Alexa / Google Home
                                      • R rvendrame
                                        N Offline
                                        N Offline
                                        n3ro
                                        • R Offline
                                          R Offline
                                          rvendrame
                                          Perfect. If it is working fine with a switch --- Maybe your PIN is triggering false positives? Or maybe the PIR output is floating a bit, and arduino is triggering it more than it should?
                                          Alexa / Google Home
