  3. Looped Repeater
Looped Repeater
9 Posts 3 Posters 3.7k Views 1 Watching
  • P
    P
    pdeprost
    In my installation all nodes are repeaters.
    When I switch off the gateway, the nodes search a new route and begins to loop.
    When I switch back the gateway ON. some nodes never find the correct route again.
    I have then to power off all the nodes excepted the gateway and restart each node one by one.
    Where is my mistake ?
    Pierre
    • P
      P
      pdeprost
      Please ... help me ...
        It might take a while for all nodes to restore a working topology.
        @celonunes might have found a bug that could explain part of this behaviour.
        • P
          P
          pdeprost
          I understand that the topology reconstruction may take some times ... But after more than 24 hours of waiting some nodes are not connected to the gateway.
          I only have 7 nodes in home and they are close to each other. They are all repeaters . It is may be too much repeaters ??
            No point in having this many repeaters if they are close to each other.
            Start by having none of them. And add one if needed.
              maglo18
              I have the same situation. My solution is to add manually repeater id in each node.
              P 2 Replies Last reply
              • M maglo18
                P
                P
                pdeprost
                This post is deleted!
                • M maglo18
                  P
                  P
                  pdeprost
                  @maglo18
                  Thank you .... Happy to know ... I am not alone with this problem.
                  Do you mean that each repeater have a fixed parent's node ID.
                  And when you give "0" as parent node... that's a first level repeater linked to the gateway ??
                  For the "non-reaepter" nodes did you fix the parent id too ?
                    maglo18
                    Yes and yes. first lever repeater should have id 0. All my nodes have static repeater or gateway id. Now i don't have loops after restart gateway.
