  3. Looped Repeater
Looped Repeater
9 Posts 3 Posters 3.6k Views 1 Watching
  • P Offline
    P Offline
    pdeprost
    In my installation all nodes are repeaters.
    When I switch off the gateway, the nodes search a new route and begins to loop.
    When I switch back the gateway ON. some nodes never find the correct route again.
    I have then to power off all the nodes excepted the gateway and restart each node one by one.
    Where is my mistake ?
    Pierre
    • P Offline
      P Offline
      pdeprost
      Please ... help me ...
      • hekH Offline
        hekH Offline
        It might take a while for all nodes to restore a working topology.
        @celonunes might have found a bug that could explain part of this behaviour.
        • P Offline
          P Offline
          pdeprost
          I understand that the topology reconstruction may take some times ... But after more than 24 hours of waiting some nodes are not connected to the gateway.
          I only have 7 nodes in home and they are close to each other. They are all repeaters . It is may be too much repeaters ??
          • hekH Offline
            hekH Offline
            No point in having this many repeaters if they are close to each other.
            Start by having none of them. And add one if needed.
            • M Offline
              M Offline
              maglo18
              I have the same situation. My solution is to add manually repeater id in each node.
              P 2 Replies Last reply
              • M maglo18
                P Offline
                P Offline
                pdeprost
                • M maglo18
                  P Offline
                  P Offline
                  pdeprost
                  @maglo18
                  Thank you .... Happy to know ... I am not alone with this problem.
                  Do you mean that each repeater have a fixed parent's node ID.
                  And when you give "0" as parent node... that's a first level repeater linked to the gateway ??
                  For the "non-reaepter" nodes did you fix the parent id too ?
                  • M Offline
                    M Offline
                    maglo18
                    Yes and yes. first lever repeater should have id 0. All my nodes have static repeater or gateway id. Now i don't have loops after restart gateway.
