  3. EnergyMeterPulseSensor reporting incorrect power draw?
8 Posts 2 Posters 2.9k Views 1 Watching
  • T
    twosh
    I'm using the unmodified code from EnergyMeterPulseSensor.ino (as my power meeter uses 1000 imp / kWh) with a Nano v3 (clone) and a LM393 Light Sensor. The Nano is powered via the USB-port from a 230 V wall plug, the radio is on the Nano's 3v3 pin, and the light sensor on the 5v pin. I'm using a Vera Edge UI7 as controller and having a Nano V3 (clone) as a serial gateway.
    The issue I'm having is that the reported current wattage as well as the cumulative kWh is way of. I'm currently drawing 150 W +/- 5 W but the sensor is showing 615 watts current draw and within an hour the kWh has risen to almost 60 kWh as you can see below:
    What could be the cause for this? Should I calibrate the sensor or something? Any suggestions at all are welcome! :)
    Thanks,
    Tim
    AWIA 1 Reply Last reply
    • T twosh
      Thanks,
      Tim
      AWIA
      AWIA
      AWI
      @twosh Are you able to measure the pulse output from the light sensor to see if you the right pulse rate comes in?
      T 1 Reply Last reply
      • AWIA AWI
        twosh
        Thanks for the fast reply! I'm sorry, but I'm not sure how I would do that?
        • T twosh
          AWIA
          AWIA
          AWI
          @twosh with a volt meter or by sending the pulse to serial print and looking at the serial output.
          • T
            twosh
            @AWI Ok! I'll dig out my volt meter and try. I guess I'll measure between the digital out and ground?
            • T twosh
              AWIA
              AWIA
              AWI
              @twosh sounds fine if you mean the digital out of the light sensor (or in of the Arduino) :smiley:
              • T
                twosh
                Alright - as usual, the code and hardware is fine -> stupid user error! :P
                @AWI The pulses were indeed not reported as expected - thanks for putting me on the right track! The LM393 is directional and I had to bend it toward the power meter's light - I had it basically 90 degrees off (as it came in the mail). That done the values are absolutely perfect.
                Big thanks to @AWI !
                • T twosh
                  AWIA
                  AWIA
                  AWI
                  @twosh Glad it helped.. .I only learn the hard way myself
