  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.5k Views 35 Watching
  • paqorP
    paqorP
    paqor
    I have used the code from epiere. Baking I have not done. I use different power supplies (USB, Samsung and a large controllable power supply). I sometimes feel that contacts do not function properly. But the sensor draws but only about 100 mA = 0.1 A? Then it seems to be on branding. I have three new sensors. Mostly we read that it is only an attempt here is to measure the CO2 content. When I check the values with a measuring instrument with which agree the details here https://olimex.wordpress.com/2015/05/26/experimenting-with-gas-sensors-and-arduino/ Branding should work outdoors? Can you show me a chart or values?
    • paqorP
      paqorP
      paqor
      This post is deleted!
      • HeinzH
        HeinzH
        Heinz
        I used this library:
        https://github.com/GeorgK/MQ135
        Together with this description:
        https://hackaday.io/project/3475-sniffing-trinket/log/12363-mq135-arduino-library
        Simple to use and very good explanations.
        • paqorP
          paqorP
          paqor
          I've read about. It sounds interesting.
          I stand a little hard with the development. Is there a skit for MQ135.h and MYSENSORS?
          I will test this afternoon.
          • HeinzH
            HeinzH
            Heinz
            Hi @paqor,
            I wrote a little sketch which you could use as a start, it uses the MQ135 library.
            I also used a timer library, but this could be replaced by a simple sleep, too.
            RZERO should be changed when calibrating the sensor, this can be done at compile-time or during runtime by sending the value to the sensor via the gateway.
            Unfortunately I could not test the sketch yet, but it should help you getting started.
            If you have a second sensor which provides humidity and temperature then you can also get the corrected ppm from the library,...
            good luck!
            MQ135 MySensor
            A0      white
            D0      black
            GND     brown
            5V      red
            #include <MQ135.h>
            #include "Timer.h"
            Timer timer;
            // 30 seconds
            #define TEMP_UPDATE_INTERVAL 30000
            // MQ135
            #define CHILD_ID_CO2 0
            #define CHILD_ID_R0 1
            #define CO2_SENSOR_ANALOG_PIN 0
            /// Calibration resistance at atmospheric CO2 level
            #define RZERO 300.0
            #define EEPROM_R0 0
            MQ135 gasSensor = MQ135(CO2_SENSOR_ANALOG_PIN, RZERO);
            int lastC02;
            float lastR0;
            // MySensor
            MyMessage msgCO2(CHILD_ID_CO2, V_VAR1);
            MyMessage msgR0(CHILD_ID_R0, V_VAR1);
                gw.sendSketchInfo("MQ135 Sensor", "1.0");
                gw.present(CHILD_ID_CO2, S_AIR_QUALITY);
                gw.present(CHILD_ID_R0, S_CUSTOM);
                uint8_t R02 = gw.loadState(EEPROM_R0);
                // get R0 from EEPROM
                float R0 = R02 * 2;
            	// do a plausibility check
                if (R0 > 1.0 && R0 < 400.0)
                    Serial.print(F("Setting R0 from EEPROM: "));
                else
                    Serial.print(F("Setting default R0: "));
                    R0 = RZERO;
                Serial.print(R0);
                Serial.println(F(""));
                gasSensor.setR0(R0);
                timer.every(TEMP_UPDATE_INTERVAL, timerHandler);
            bool MQ135Changed()
                bool changed = false;
                lastR0 = gasSensor.getRZero();
                Serial.print(F("R0: "));
                Serial.println(lastR0);
                    float ppm = gasSensor.getPPM();
                    Serial.print(F("CO2 ppm: "));
                    Serial.print(ppm);
                    int roundedPpm = (int)ppm;
                    Serial.print(F(" --> "));
                    Serial.println(roundedPpm);
                    if (roundedPpm != lastC02)
                        lastC02 = roundedPpm;
                        changed = true;
                return changed;
            void timerHandler()
                bool airQualityChanged = MQ135Changed();
                if (airQualityChanged)
                    gw.send(msgCO2.set(lastC02));
                    gw.send(msgR0.set(lastR0, 2));
                gw.process();
                timer.update();
            // Gets the R0 value from the gw passes ot to the lib and stores it into the EEPROM.
            void incomingMessage(const MyMessage& message)
                Serial.println(F("Incoming Message:"));
                if (message.isAck())
                    Serial.println(F("This is an ack from gateway"));
                uint8_t sensor = message.sensor;
                if (sensor == CHILD_ID_R0)
                    float R0 = message.getFloat();
                    Serial.print(F("Incoming R0: "));
                    Serial.print(R0);
                    gw.saveState(EEPROM_R0, (uint8_t)(R0/2));
                    gw.send(msgR0.set(R0, 2));
            • paqorP
              paqorP
              paqor
              wrote on last edited by paqor
              #126
              I have compiled from various sources themselves something. The result is https://gleisnetze.de/2015/12/25/das-erste-kleine-programm/ described herein. The most plausible values I received with the MQ135.h library. For that I have then added the transfer after MySensors / FHEM.
              • B
                B
                bhavika
                Hello
                In MiCS 2614 or in any gas sensor. what should be the value of R0... Because in datasheet they mentioned that value is measured in ambient condition. Any default value for that??
                epierreE 1 Reply Last reply
                • B bhavika
                  Hello
                  epierreE
                  epierreE
                  epierre
                  @bhavika said:
                  Hello
                  The datasheed propose the "clean air calibration": "Sensing resistance in air R0 is measured under controlled ambient conditions, i.e. synthetic air at 23 ±5°C and 50 ± 10% RH. Sampling test."
                  so you should go outside and mesure the defautl R0 value in your environment.
                  z-wave - Vera -> Domoticz
                  • HeinzH
                    HeinzH
                    Heinz
                    MQ-135 with 10k results in a R0 of around 360 in my environment. So you could start experimenting with values around 300-500. I had to use a voltage regulator to get reliable values from the sensor.
                    • epierreE
                      epierreE
                      epierre
                      wrote on last edited by epierre
                      #130
                      a little update on the MICS-6814:
                      NO2: sensible
                      CO: flat
                      NH3 flat
                      For the HCHO:
                      sorry for the flat part, some arduino issues at this time
                        Welcome @betthorn, great to have you here.
                        • epierreE
                          epierreE
                          epierre
                          I have had some questions about converting from mg/m3 to ppm gases, here are the weight values and a proposed method:
                          NH3 17.03 g/mol
                          CO2 44.01
                          CO 28.01
                          H2S 34.08
                          NO2 46.01
                          NO 30.01
                          O3 48.00
                          C6H6 78.11
                          C7H8 92.14
                          you have:
                          NO2 50 μg/m3 gives 26,5868821 ppm
                          O3 27 μg/m3 = 0.027 mg/m3 -> (8,31441298,15)/(48101,325)*27=13,7617025 ppm
                          correct me if I'm wrong
                          • epierreE
                            epierreE
                            epierre
                            2016 is where IoT for gas sensors are moving to more maturity, Cooking Hacks / Libellium proposed so far Fibaro sensors, but are now proposing more pricey one that are calibrated.
                            See https://www.cooking-hacks.com/shop/sensors/gas
                            • epierreE
                              epierreE
                              epierre
                              CO2 with MH-Z14
                              NO2 MICS-6814
                              HCHO sensor
                              • B
                                B
                                bhavika
                                wrote on last edited by bhavika
                                #135
                                In MQ135 sensor's datasheet , which line on the curve is used to find out the concentration of benzene?
                                • B bhavika
                                  epierreE
                                  epierreE
                                  epierre
                                  MQ135 is sensitive to particle size, benzene is one of these. I rememer someone who used the chinese datasheet and found a chinese to translate it.
                                  • supersjimmieS
                                    supersjimmieS
                                    supersjimmie
                                    wrote on last edited by supersjimmie
                                    #137
                                    @epierre I am testing a stripped-down version of your code from your AirQuality-MQ135.ino. I stripped it to make it run just stand-alone.
                                    What I don't understand is how to do the calibration. When I run it in outside environment (with 10k resistor), I get these values:
                                    valr 223
                                    Vrl / Rs / ratio:13387 / 20875.00 / 0.00
                                    What would be the next step for calibration?
                                    • supersjimmieS supersjimmie
                                      valr 223
                                      epierreE
                                      epierreE
                                      epierre
                                      @supersjimmie replace MQ135_DEFAULTRO by your value 20875 in the sketch
                                      supersjimmieS 1 Reply Last reply
                                      • epierreE epierre
                                        supersjimmieS
                                        supersjimmieS
                                        supersjimmie
                                        #139
                                        @epierre Thanks, I thought it would be something like that, but that didn't work.
                                        I then got
                                        valr 242
                                        Vrl / Rs / ratio:5464 / 8520.00 / 0.00
                                        Nothing like around 400ppm.
                                        • epierreE
                                          epierreE
                                          epierre
                                          yes for the code must be updated, the value is the CO2 (or something else) detected above the 399 in atmosphere
                                            gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ)));
