  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 450.5k Views 35 Watching
  • M moskovskiy82
    Used the air quality script for MQ7 but throwed out all the conversions and calibrations. Just reading the plain input from the analogue pin.
    I targeted this as a smoke detector but it seems this sensor highly depends on the humidity of the surrounding air. Are there any existing formulas to correct for the humidity of the surounding air?
    And on one sensor i have some irratical data as shown below (blue). I wonder if it's a power supply (black and green is DHT) or a broken sensor?
    epierreE
    epierreE
    epierre
    @moskovskiy82 well looks like a strange sensor... try averaging several samples/// always remember to have it running several days before measuring for there are chemical left from china factories...
    z-wave - Vera -> Domoticz
    • wreinerW
      wreinerW
      wreiner
      #162
      Hey all,
      I've got a question regarding the calibration function in https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino :
      $ grep MQCalibr *
      AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro0 = MQCalibration(MQ2_SENSOR,10,RL0,SmokeCurve);
      AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro1 = MQCalibration(MQ6_SENSOR,10,RL1,LPGCurve);
      AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro2 = MQCalibration(MQ131_SENSOR,10,RL2,O3Curve);
      AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro3 = MQCalibration(TGS2600_SENSOR,10,RL3,C2H5OH_terCurve);
      AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro4 = MQCalibration(MQ135_SENSOR,10,RL4,CO_secCurve);
      AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro6 = MQCalibration(TGS2602_SENSOR,1,RL6,C7H8Curve);
      AirQuality-Multiple_Gas_Sensor1_4.ino:float MQCalibration(int mq_pin, double ppm, double rl_value,float *pcurve )
      Th function MQCalibration should calibrate the sensor in clean air, the calibration function uses the PPM concentration of the gas in a clean air environment.
      You already use the appropriate value for i.e. CO2 (around 399 PPM) in the MQ135 sketch - but why are you using those obscure values in the calibration (1, 10) here?
      Thanks in advance!
      epierreE 1 Reply Last reply
      • wreinerW wreiner
        Hey all,
        $ grep MQCalibr *
        Thanks in advance!
        epierreE
        epierreE
        epierre
        Well, I didn't know the concentration in clean air so I had to put in a value even random... I took the hypothesis there are very few in the air so low value.
        • epierreE epierre
          @tantt2810 said:
          Hi everyone,
          I have an CO2 MG811 sensor. I don't know where tcm pin connect with ?
          Please help me. Thank you so much !!!!
          this is an analogic sensor, so VCC/Gnd to power it, and readings on analogic Aout
          tantt2810T
          tantt2810T
          tantt2810
          @epierre
          Thank you. Your mean is Vcc->5V, GND->GND, Dout->Digital pin, Aout->Analog pin. Is it right?
          But I don't know the tcm pin connect with ? I have read datasheet but I don't find any info about tcm pin. Please help me. Thank you so much !!!
          • alexsh1A
            alexsh1A
            alexsh1
            @epierre
            Readings of my MQ135 are going up and down like a yo-yo. Not sure how to read them really?
            What do you think?
            • B
              B
              bhavika
              I am confused with MiCS 4514 sensor. What I had done is :
              using MiCS quick start evaluation board, measured ADC value
              calculated Vout and from that calculated R0.
              Rs/R0 concentration gives me high value, which is not possible, My data is as follows
              clean air file is used for the purpose of R0 value
              https://drive.google.com/file/d/0B8sF8a6FHoseWjhWOHRoYzIxakk/view?usp=sharing
              and Polluted file is used to calculate the actual pollution
              https://drive.google.com/file/d/0B8sF8a6FHoseR1BnclhCUHdibEU/view?usp=sharing
              I am confused. Please help me
              VirV 1 Reply Last reply
              • tantt2810T tantt2810
                @epierre
                epierreE
                epierreE
                epierre
                wrote on last edited by epierre
                #167
                @tantt2810 said:
                @epierre
                do not use the digital pin !!! it only reacts with the potentiometer in on/off mode, so useless... you need to power the device with Vcc/Gnd, and read the output with Aout (A stands for analog). The last one forget it.
                tantt2810T 1 Reply Last reply
                • alexsh1A alexsh1
                  @epierre
                  What do you think?
                  epierreE
                  epierreE
                  epierre
                  @alexsh1 is that raw ADC output or with a calculation ? normaly this should go up or down but not in sucha drastic way
                  alexsh1A 1 Reply Last reply
                  • epierreE epierre
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @epierre
                    This is a value gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ))) reported to Domoticz.
                    It does not make any sense to me at all.
                    • epierreE epierre
                      @tantt2810 said:
                      @epierre
                      tantt2810T
                      tantt2810T
                      tantt2810
                      @epierre
                      Thanks you so much !!! Good job, Good boy =)).
                      • alexsh1A alexsh1
                        @epierre
                        epierreE
                        epierreE
                        epierre
                        @alexsh1 said:
                        @epierre
                        same for mle, sometime it is good to have two piece to compare their behavior... I have 3 o them ...
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @epierre do you think it is a faulty sensor though?
                          • tantt2810T
                            tantt2810T
                            tantt2810
                            wrote on last edited by tantt2810
                            #173
                            Can I use pinMode(digitalpin, OUTPUT) to turn off sensor? Or Is there any way to wirte a function that turn off sensor?
                            I want to remote it on web to turn on or off it.
                            • supersjimmieS
                              supersjimmieS
                              supersjimmie
                              For those who are trying to use an MQ135 module from e-bay or other sellers, on a small pcb with a chip, LED and potmeter:
                              It took me a while until I figured out that the little chip has a very big influence on the value that you read on the A-out pin.
                              Only after removing the connection between the A-out pin and the little chip, I got normal measurements.
                              I also replaced the small resistor marked "102" with a 10k resistor, to make measurements more compatible with code that uses a 10k pull down resistor. But that was already a known issue, found on many other places.
                                epierreE
                                epierreE
                                epierre
                                well no, powering is through Vcc/GND, so you whould use a switch on this. Digital pins do not gives enough power for such sensors.
                                • alexsh1A alexsh1
                                  epierreE
                                  epierreE
                                  epierre
                                  coud be, hard to know without possibility to compare to another one.
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @epierre
                                    This is what I discovered. When nobody is around the sensor 'settles' on a particular value. However, when there is anyone around in the room, the sensor reading goes up and down - see the snapshot attached. Any idea what the problem may be?
                                    • epierreE
                                      epierreE
                                      epierre
                                      @alexsh1 hard to say, could be something moving inside if someone makes vibration around and thus this strange reaction... the down curve at the end is correct, the in between not
                                      • E
                                        E
                                        Elfnoir
                                        Can you check the reception level?
                                        I had same behaviour with an old temperature/humidity module; need to move it to another place in the room, and works perfectly now :-)
                                        • E Elfnoir
                                          epierreE
                                          epierreE
                                          epierre
                                          temp/hum are "less" sensitive on environment, here the sensors heats up to 40-60° (or more) so temp/hum is not the most impacting (I can be wrong anyway ;-)
