  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 341.4k Views 68 Watching
  • B
    B
    bruno
    SuperCool!! :smile: :smile: :smile:
    I have business trip to China in the middle of May, so I can take the PCBs directly from dirtypcbs!
    Many Thanks for your work!!
    • A
      A
      aproxx
      The latest version of this board is available here!
      Because of the large number of request a second (optional) solid state relay has been added to the board. Enjoy!
      J 1 Reply Last reply
      • B
        B
        bruno
        Thanks!!
        ranginkamanR 1 Reply Last reply
        • A aproxx
          J
          J
          jemish
          @aproxx Where is the button/ Switch connection pin.
          A 1 Reply Last reply
          • J jemish
            A
            A
            aproxx
            @jemish
            It's on the middle of the board on the top side. 4 pins are present to use as switch inputs. 2 pins are ground, and then pin 4 and 7 are available as well.
            By closing the connection between pin 4 and ground you will switch te status of relay 1. When closing the connection between ground and pin 7 you'll switch the status of relay 2.
            • A aproxx
              Hi all,
              **UPDATE April 17 2016 **
              The latest version of this board is available HERE.
              After spending a few months on this forum and a few prototypes later, I decided I wanted to build a small but cheap PCB which could be placed in either the wall behind the light switch, or above the lamp.
              Besides the boards I've seen on this forum, I wanted these boards to contain a module to go from 230v AC to 5/3.3v DC in order to power an Arduino nano and the NRF module. I eventually ended up with a PCB which is about 4 by 4.5cm. So with all components attached I'm hoping to get in stuffed in a 5x5x3cm plastic printed case.
              Modules which I've used to power the board:
              [http://www.aliexpress.com/item/5-pcs-HLK-PM01-AC-DC-220V-to-5V-Step-Down-Power-Supply-Module-Intelligent-Household/32319202093.html?spm=2114.32010308.4.19.8oKfZg
              UPDATE: 2015/09/18
              As promised, I've got an update for this project. The board has been tested in the past week, and everything is working as expected. Compared to the previous board I've posted, I have updated the following:
              • Solder pads of LE33CZ have been placed a little wider apart to avoid short circuit while soldering.
              • Solder pads of the resettable fuse (Fuse2) has been placed closer together to better fit the fuses of the BOM.
              • Moved the NRF24L01 connector a bit away from the solid state relay. Should make it easier to solder.
              • Moved Fuse2 to another location on the board, away from the 230v circuit.
              Some 3D pictures (Top and bottom):
              Anyone who is interested can order the PCB HERE
              Some documentation, complete list of required components and all gerber / DipTrace files (in case you would like to make some modifications) can be found here: MySensors board v3.2.3.zip.
              Z
              Z
              zebmina
              @aproxx I have a few left-over boards from the earlier release - where the holes for fuse2 were smaller than required (PTC Resettable Fuses 250V 1A TRF250-1000 PPTC Polymeric PTC PolySwitch). I wanted to use up the remaining boards, and wondering if the following fuse could be a substitute (USA-based, leads are smaller diameter and would fit the holes) - MF-R110 FUSE PTC RESETTABLE 1.10A HOLD MF-R110 110 MF.
              Thanks for your guidance.
              • Fat FlyF
                Fat FlyF
                Fat Fly
                http://www.aliexpress.com/item/5V-700mA-3-5W-AC-DC-Precision-Buck-Converter-AC-220v-to-5v-DC-step-down/32649591757.html?spm=2114.30010308.3.1.M5SbfZ&ws_ab_test=searchweb201556_0,searchweb201602_3_10057_10056_10065_10037_10055_10054_301_10059_10033_10058_10032_10017_107_10060_10061_10052_414_10062_10053_10050_10051,searchweb201603_2&btsid=985260cb-f95b-4394-b27e-6cd482ca0330
                Nca78N 1 Reply Last reply
                • Fat FlyF Fat Fly
                  Nca78N
                  Nca78N
                  @Fat-Fly these tiny boards have really bad isolation and are dangerous tu use.
                  And did you have a look at this 1-diode "rectifier" ? The ripple is probably awful and the result will affect the quality of the radio transmission.
                  Saving 0.5$ compared to an HLK is really not worth it !
                  • B bruno
                    Thanks!!
                    ranginkamanR
                    ranginkamanR
                    ranginkaman
                    wrote on last edited by ranginkaman
                    #269
                    @bruno tanke you, very good.
                    I share it in facebook.
                    http://behsazmadar.ir
