  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 346.1k Views 68 Watching
  • toabhishekvermaT
    toabhishekvermaT
    toabhishekverma
    Sorry I didnt get your questions .. do you mean dimensions of 220-3.3v converter. Here they are.
    output 2.5W 3.3V/0.8A +-0.2V size: 30x20x18mm
    I am not from electronics background so didn't get what holding resistance means?
    YveauxY 1 Reply Last reply
    • toabhishekvermaT toabhishekverma
      YveauxY
      YveauxY
      @toabhishekverma No, I meant for the relay ;-)
      What's the resistance of the 3V coil? I want to know the current flowing when the relay is active.
      • toabhishekvermaT
        toabhishekvermaT
        toabhishekverma
        @Yveaux Still no idea about it. Check link if you get something from it. what I know is it can bear up to 10A current and can be controlled using 3v .... my order still in shipping so don't know more then that.
          YveauxY
          YveauxY
          @toabhishekverma Ah, ok. Didn't know they were still in transit.
          Maybe @GertSanders has them 'on stock'?
          HenryWhiteH GertSandersG 2 Replies Last reply
          • YveauxY Yveaux
            HenryWhiteH
            HenryWhiteH
            HenryWhite
            @Yveaux http://www.songle.com/en/pdf/20084141716341001.pdf
            • HenryWhiteH HenryWhite
              YveauxY
              YveauxY
              @HenryWhite Awesome! Didn't even think of looking for a datasheet of a Chinese relay ;-)
              • P
                P
                Porky6666
                Another source :
                50Pieces/Lot JRC-21F 4100 3V DC 6 Pins Miniature PCB Relay Brand New
                http://s.aliexpress.com/MNVv2myE
                • YveauxY Yveaux
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @Yveaux No, also still waiting for the order to arrive. But a coil resistance of 20-25 Ohm means driving the coil with a FET. Not directly from a atmega328 pin.
                  HenryWhiteH 1 Reply Last reply
                  • P Porky6666
                    Another source :
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @Porky6666 : only switches 3A, SONGLE relay can switch 10A.
                    • GertSandersG GertSanders
                      HenryWhiteH
                      HenryWhiteH
                      HenryWhite
                      Correct. Here's how I wired the songle relay on my Lithium Ion Sensor PCB:
                      I wouldn't trust both of them when it comes to switching high amp devices over 3A. I think there is a reason no german electronics shop sells songle relays :smile:
                      Plus, relays from an electronics shop in your country might cost the same than the songle relays or will just be a tiny bit more expensive.
                      At least this is true for 5V relays. 3V relays are hard to find (at least in germany)
                        GertSandersG
                        GertSandersG
                        GertSanders
                        I agree, I plan to switch lights, so my preference goes to the 10A model, just to be sure. I have used the SONGLE 5V versions, and none have ever given me reason to doubt their quality. Since I found a 3V3 powersupply I want to try building a full 3V3 board. Should be fun.
                        • toabhishekvermaT
                          toabhishekvermaT
                          toabhishekverma
                          @HenryWhite why do we need D1 Diode (if i am write) in that circuit? do this circuit will not work without diode?
                          (sorry dont know much about electronics)
                            HenryWhiteH
                            HenryWhiteH
                            HenryWhite
                            wrote on last edited by HenryWhite
                            #213
                            @toabhishekverma https://en.m.wikipedia.org/wiki/Flyback_diode
                            in short: It is needed to protect the NPN transistor from damage.
                            The circuit will work without diode, But eventually damage the transistor.
                            • m26872M
                              m26872M
                              m26872
                              @GertSanders Have you breadboarded your 3.3V design? I'm a bit worried that removing linear converter will impair the performance of the our fussy nRF clones due to less power supply ripple rejection. I think those going for the ESP8266 are better off.
                              • T
                                tomkxy
                                Anyone has an idea where to source the 5.5V varistor? I received a bunch from AliExpress following which seem to be broken.
                                I found this link http://www.farnell.com/datasheets/575651.pdf. However, there seem to be a bunch of 5.5 V varistor. Can anybody help me figuring out the right ones?
                                icebobI 1 Reply Last reply
                                • T tomkxy
                                  icebobI
                                  icebobI
                                  icebob
                                  @tomkxy I'm using this one: http://hu.farnell.com/multicomp/mcvz1206m050agt/varistor-multilayer-4vac-0402/dp/2462756
                                  T 1 Reply Last reply
                                  • m26872M m26872
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    wrote on last edited by GertSanders
                                    #217
                                    @m26872 I have not used the 3V3 version of the Hilink converter, it was just shipped today (ordered last week). It will take a few more weeks to reach me. But then I will test it on my ac board. We will see.
                                    23/FEB: Update: the converters are here. I will make a node with this converter version this weekend.
                                    • icebobI icebob
                                      tomkxy
                                      Thanks! It's a pity that the chinese "varistors" seem to be jumpers. I even saw in some offers on AliExpress that they are referred to as jumpers.
                                      • T
                                        tomkxy
                                        How can I check whether the solid state relay works at all. My assembled board receives messages and sets state properly, I have 5V on the pin, however the relay does not seem to switch. Should I hear it? Any other ideas for "debugging"?
                                        • T tomkxy
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          #220
                                          @tomkxy
                                          Measure the resistance over the AC terminals of the SSR. It should be very high when "open" en very low when "closed". SSRs do not make sounds when they switch, so sound will not give a clue if they work.
