  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 346.1k Views 68 Watching
  • Q
    Q
    Quinie
    wrote on last edited by Quinie
    #101
    I'm trying to build this nice litte board. Got a long way but now i'm stuck.
    The BOM for version 3.2.3
    100nF + 100pF Capacitors
    4.7uF Capacitors
    Schematics.
    c1 100nF
    c2 100uF
    c3 4.7uf
    I'm don't have a lot of knowlegde but the 100uF seems te be missing from the BOM. The placement of this part is under the HLK. I have a lot of trouble place the C1 and C2.
    I have a ceramic one with number 104 in C2. I thought this is the 100nF. So should it be in C1? But it's so small and nice. And then C2 is missing from the BOM and the only 100uF I have from an other project is big. It realy won't fit under the HLK.
    Can some-one give some insight on the BOM, C1 and C2, Ceramic code numbers.
    This would realy help me and maybe a few others.
    Also on my board the holes for the fuse 2 where to small had to drill them out. Second the request for a thermal-fuse. But thanks for this great design.
    • S
      shabba
      What order did people solder the components on?
      • S
        shabba
        Anyone? The part list (ie mapping of CX etc) is in this post - not in the doc with the zip file so makes things very confusing.
        Thanks.
        • S
          shabba
          @aproxx Could you clarify the capacitors please? C2 on a post in this thread is 100uF but there are hard to get as ceramics and even the half height ones I have make the arduino stand very high off the board.
          Thanks muchly!
          AWIA 1 Reply Last reply
          • S shabba
            Thanks muchly!
            AWIA
            AWIA
            AWI
            @shabba http://nl.aliexpress.com/item/100pcs-lot-Multilayer-ceramic-capacitor-0-1uF-104-50V-100nF-104M/32429917283.html?ws_ab_test=searchweb201556_7_79_78_77_80,searchweb201644_5,searchweb201560_7
            you can solder these under the processor board
            http://nl.aliexpress.com/item/Free-Shipping-100pcs-lot-100uF-16V-Electrolytic-Capacitor-16V-100UF-5x7mm-Aluminum-Electrolytic-Capacitors/32255105372.html?ws_ab_test=searchweb201556_7_79_78_77_80,searchweb201644_5,searchweb201560_7
            the 100uF does not have to be a ceramic one...
            • S
              shabba
              thanks for reply @AWI - The 100nf one does not go under - it is the 100uF one that does. I have a small electrolytic one (it is slightly smaller than the second link you mention) and there is still not enough space - my arduino is too low - I could try and find higher pin stands. I'm sure some ppl will go off and buy all these parts like me so I hope they are aware. Would have been ideal for a SMD really (like the varistor right beside it).
              • S shabba
                AWIA
                AWIA
                AWI
                @shabba I don't have a 100uF capacitor under the Arduino and don't think there needs to be one... Take a look at the pictures. The two large 4.7 and 100 uF are next to the black box
                • Q
                  Q
                  Quinie
                  #108
                  I still have trouble figuring out the C1 and C2. Here are some picture of my build so far.
                  Not sure all the components are placed correctly.
                  C1 is placed with a small 100nf (104) but BOM in zip say's this is wrong.
                  As you can see i placed this one, cause the 100uf will not fit
                  • Q Quinie
                    AWIA
                    AWIA
                    AWI
                    @Quinie looks correct. This is the position of the large capacitors (mind the polarity - minus to the edge of the board)
                    upload-a8c45995-dbf9-4e64-8814-b1191a43be35
                    I also noticed you mounted the regulator correct. ;-)
                    • S
                      shabba
                      So the regulator needs swapping about and the BOM cap values are incorrect from post (http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board/37) above that states :::
                      C1 100nF capacitor
                      C2 100uF capacitor
                      C3 4.7uF capacitor
                      • bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        Hmmm. I got the 5.5V DC varistor from another AliExpress seller and I'm a bit puzzled as to why it starts smoking after a few seconds. Tried several of them. The HLK gives a solid 5V output. I'm assuming I got some lower voltage varistors by mistake?
                        m26872M 1 Reply Last reply
                        • S shabba
                          C1 100nF capacitor
                          C2 100uF capacitor
                          C3 4.7uF capacitor
                          AWIA
                          AWIA
                          AWI
                          @shabba Right... if you look at the schematics upload-a10f80dc-0eda-4c4b-aa49-e0bbc6f827a8 you can see that the two capacitors can be swapped without consequences
                          S 1 Reply Last reply
                            m26872M
                            m26872M
                            m26872
                            @bjornhallberg Maybe I've missed reading something, but why use a varistor for 5 Vdc and not a zener diode?
                            • AWIA AWI
                              shabba
                              @AWI Thanks! Very true!
                              • m26872M m26872
                                bjornhallbergB
                                bjornhallbergB
                                bjornhallberg
                                @m26872 You're probably right, I just followed the BOM. I'll see if I can stock up on some diodes from AliExpress for future use.
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  #116
                                  Whould a 5.1V zener work?
                                  edit: removed the link to the product so that no one would buy it the specs of it is to tight to be used with HLK.
                                  • Tomas
                                  • Cliff KarlssonC
                                    Cliff KarlssonC
                                    Cliff Karlsson
                                    Just a stupid question, the "G3MB-202P DC-AC PCB SSR In 5VDC,Out 240V AC 2A " What happens if I forget and plug something more power-hungry like a toaster or a microwave-owen? does any of the fuses blow or does the relay break ?
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      there is no fuse on the relay switch so I guess either the PCB or the relay will fail.
                                      • Tomas
                                      • m26872M
                                        m26872M
                                        m26872
                                        I've seen commercial products with a thermal fuse glued to the switching side of the relay. Maybe that would help some in such situation.
                                        • korttomaK korttoma
                                          m26872M
                                          m26872M
                                          m26872
                                          #120
                                          @korttoma A 5.1V zener is probably too tight. The HLK seems rated 5+/-0.2V.
