  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 341.5k Views 68 Watching
  • Q
    Q
    Quinie
    wrote on last edited by Quinie
    #108
    I still have trouble figuring out the C1 and C2. Here are some picture of my build so far.
    Not sure all the components are placed correctly.
    C1 is placed with a small 100nf (104) but BOM in zip say's this is wrong.
    As you can see i placed this one, cause the 100uf will not fit
    AWIA 1 Reply Last reply
    • Q Quinie
      AWIA
      AWIA
      AWI
      @Quinie looks correct. This is the position of the large capacitors (mind the polarity - minus to the edge of the board)
      upload-a8c45995-dbf9-4e64-8814-b1191a43be35
      I also noticed you mounted the regulator correct. ;-)
        shabba
        So the regulator needs swapping about and the BOM cap values are incorrect from post (http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board/37) above that states :::
        C1 100nF capacitor
        C2 100uF capacitor
        C3 4.7uF capacitor
        • bjornhallbergB
          bjornhallbergB
          bjornhallberg
          Hmmm. I got the 5.5V DC varistor from another AliExpress seller and I'm a bit puzzled as to why it starts smoking after a few seconds. Tried several of them. The HLK gives a solid 5V output. I'm assuming I got some lower voltage varistors by mistake?
          m26872M 1 Reply Last reply
          • S shabba
            C1 100nF capacitor
            C2 100uF capacitor
            C3 4.7uF capacitor
            AWIA
            AWIA
            AWI
            @shabba Right... if you look at the schematics upload-a10f80dc-0eda-4c4b-aa49-e0bbc6f827a8 you can see that the two capacitors can be swapped without consequences
            S 1 Reply Last reply
              m26872M
              m26872M
              m26872
              @bjornhallberg Maybe I've missed reading something, but why use a varistor for 5 Vdc and not a zener diode?
              • AWIA AWI
                shabba
                @AWI Thanks! Very true!
                • m26872M m26872
                  bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  @m26872 You're probably right, I just followed the BOM. I'll see if I can stock up on some diodes from AliExpress for future use.
                  • korttomaK
                    korttomaK
                    korttoma
                    #116
                    Whould a 5.1V zener work?
                    edit: removed the link to the product so that no one would buy it the specs of it is to tight to be used with HLK.
                    • Tomas
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      Just a stupid question, the "G3MB-202P DC-AC PCB SSR In 5VDC,Out 240V AC 2A " What happens if I forget and plug something more power-hungry like a toaster or a microwave-owen? does any of the fuses blow or does the relay break ?
                      • korttomaK
                        korttomaK
                        korttoma
                        there is no fuse on the relay switch so I guess either the PCB or the relay will fail.
                        • Tomas
                        • m26872M
                          m26872M
                          m26872
                          I've seen commercial products with a thermal fuse glued to the switching side of the relay. Maybe that would help some in such situation.
                          • korttomaK korttoma
                            m26872M
                            m26872M
                            m26872
                            wrote on last edited by m26872
                            #120
                            @korttoma A 5.1V zener is probably too tight. The HLK seems rated 5+/-0.2V.
                            • m26872M m26872
                              bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              @m26872 Indeed, mine is 5.08V (with no load). I ordered some 5.1V and 5.6V 1206 SMD diodes from Ali for future use. Plus some 3.6V. And a set of DIP diodes.
                              rvendrameR 1 Reply Last reply
                                rvendrameR
                                rvendrameR
                                rvendrame
                                Just to remember, the typical zeners are 1W , which gives a max of 200mA of output capacity, pretty enough for Arduino+radio, but maybe not enough for many relays / Leds etc. And if they burn due overload, they will allow all voltage/current flowing from PSU into arduino.
                                That explains why we suggested the varistor, in order to short the PSU output and trigger its internal protection. Strange that your varistors didn't survive... Bad lot? Maybe they are not 5.5V as stated?
                                ESP8266 GW + mySensors 2.3.2
                                Alexa / Google Home
                                • rvendrameR rvendrame
                                  m26872M
                                  m26872M
                                  m26872
                                  @rvendrame
                                  No.
                                  The zener will only lead current during over voltage condition and only needs to dissapate enough energy till one of your (multiple?) over current protection trips. Just as your varistor setup is supposed to work.
                                  • m26872M m26872
                                    @rvendrame
                                    No.
                                    rvendrameR
                                    rvendrameR
                                    rvendrame
                                    @m26872 , is it also true in case the PSU itself fail? And what happens if the circuit consumes more current than zener rating? I'm my (poor) knowledge, zeners are more relevant for stabilization, while varistor are effective 'protection' devices...
                                    Alexa / Google Home
                                    • M mvdarend
                                      I spoke too soon... the unit seems to work well, but I hadn't tested if the relay actually switched or not. The status seems to change fine in the serial monitor, but it doesn't seem to be actually switching. I'll have to do some more troubleshooting.
                                      shabba
                                      @mvdarend You discover your issue with the relay?
                                        m26872M
                                        m26872M
                                        m26872
                                        @rvendrame
                                        since we're discussing the PSU secondary side (output side), I think we already presume errors with the PSU. A fuse (over current protection) on the secondary is not just there as a back-up if the PSU internal over current protection fails. The fuse will also prevent your over voltage protection (zener, varistor, ...) from overload/burn/start a fire.
                                        The current from PSU to load will not pass through the zener and hence the rating is irrelevant from that perspective. In other applications where a zener is used as voltage regulator, the full load current will pass through the zener when in idleing and then the rating is critical.
                                        korttomaK 1 Reply Last reply
                                        • m26872M m26872
                                          @rvendrame
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          @m26872 so how do we need to rate the zener? Should the zener be rated so that the fuse will blow before the zener brakes from the current it passes due to an over voltage situation? Or is it OK that the zener brakes to as long as it takes out the fuse first. Then an automatic fuse will no longer work.
                                          • Tomas
