  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • S shabba
    thanks for reply @AWI - The 100nf one does not go under - it is the 100uF one that does. I have a small electrolytic one (it is slightly smaller than the second link you mention) and there is still not enough space - my arduino is too low - I could try and find higher pin stands. I'm sure some ppl will go off and buy all these parts like me so I hope they are aware. Would have been ideal for a SMD really (like the varistor right beside it).
    AWIA
    AWIA
    AWI
    @shabba I don't have a 100uF capacitor under the Arduino and don't think there needs to be one... Take a look at the pictures. The two large 4.7 and 100 uF are next to the black box
    • Q
      Q
      Quinie
      wrote on last edited by Quinie
      #108
      I still have trouble figuring out the C1 and C2. Here are some picture of my build so far.
      Not sure all the components are placed correctly.
      C1 is placed with a small 100nf (104) but BOM in zip say's this is wrong.
      As you can see i placed this one, cause the 100uf will not fit
      AWIA 1 Reply Last reply
      • Q Quinie
        AWIA
        AWIA
        AWI
        @Quinie looks correct. This is the position of the large capacitors (mind the polarity - minus to the edge of the board)
        upload-a8c45995-dbf9-4e64-8814-b1191a43be35
        I also noticed you mounted the regulator correct. ;-)
          shabba
          So the regulator needs swapping about and the BOM cap values are incorrect from post (http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board/37) above that states :::
          C1 100nF capacitor
          C2 100uF capacitor
          C3 4.7uF capacitor
          • bjornhallbergB
            bjornhallbergB
            bjornhallberg
            Hmmm. I got the 5.5V DC varistor from another AliExpress seller and I'm a bit puzzled as to why it starts smoking after a few seconds. Tried several of them. The HLK gives a solid 5V output. I'm assuming I got some lower voltage varistors by mistake?
            m26872M 1 Reply Last reply
            • S shabba
              C1 100nF capacitor
              C2 100uF capacitor
              C3 4.7uF capacitor
              AWIA
              AWIA
              AWI
              @shabba Right... if you look at the schematics upload-a10f80dc-0eda-4c4b-aa49-e0bbc6f827a8 you can see that the two capacitors can be swapped without consequences
              S 1 Reply Last reply
                m26872M
                m26872M
                m26872
                @bjornhallberg Maybe I've missed reading something, but why use a varistor for 5 Vdc and not a zener diode?
                • AWIA AWI
                  shabba
                  @AWI Thanks! Very true!
                  • m26872M m26872
                    bjornhallbergB
                    bjornhallbergB
                    bjornhallberg
                    @m26872 You're probably right, I just followed the BOM. I'll see if I can stock up on some diodes from AliExpress for future use.
                    • korttomaK
                      korttomaK
                      korttoma
                      #116
                      Whould a 5.1V zener work?
                      edit: removed the link to the product so that no one would buy it the specs of it is to tight to be used with HLK.
                      • Tomas
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        Just a stupid question, the "G3MB-202P DC-AC PCB SSR In 5VDC,Out 240V AC 2A " What happens if I forget and plug something more power-hungry like a toaster or a microwave-owen? does any of the fuses blow or does the relay break ?
                        • korttomaK
                          korttomaK
                          korttoma
                          there is no fuse on the relay switch so I guess either the PCB or the relay will fail.
                          • Tomas
                          • m26872M
                            m26872M
                            m26872
                            I've seen commercial products with a thermal fuse glued to the switching side of the relay. Maybe that would help some in such situation.
                            • korttomaK korttoma
                              m26872M
                              m26872M
                              m26872
                              wrote on last edited by m26872
                              #120
                              @korttoma A 5.1V zener is probably too tight. The HLK seems rated 5+/-0.2V.
                              • m26872M m26872
                                bjornhallbergB
                                bjornhallbergB
                                bjornhallberg
                                @m26872 Indeed, mine is 5.08V (with no load). I ordered some 5.1V and 5.6V 1206 SMD diodes from Ali for future use. Plus some 3.6V. And a set of DIP diodes.
                                rvendrameR 1 Reply Last reply
                                  rvendrameR
                                  rvendrameR
                                  rvendrame
                                  Just to remember, the typical zeners are 1W , which gives a max of 200mA of output capacity, pretty enough for Arduino+radio, but maybe not enough for many relays / Leds etc. And if they burn due overload, they will allow all voltage/current flowing from PSU into arduino.
                                  That explains why we suggested the varistor, in order to short the PSU output and trigger its internal protection. Strange that your varistors didn't survive... Bad lot? Maybe they are not 5.5V as stated?
                                  ESP8266 GW + mySensors 2.3.2
                                  Alexa / Google Home
                                  • rvendrameR rvendrame
                                    m26872M
                                    m26872M
                                    m26872
                                    @rvendrame
                                    No.
                                    The zener will only lead current during over voltage condition and only needs to dissapate enough energy till one of your (multiple?) over current protection trips. Just as your varistor setup is supposed to work.
                                    • m26872M m26872
                                      @rvendrame
                                      No.
                                      rvendrameR
                                      rvendrameR
                                      rvendrame
                                      @m26872 , is it also true in case the PSU itself fail? And what happens if the circuit consumes more current than zener rating? I'm my (poor) knowledge, zeners are more relevant for stabilization, while varistor are effective 'protection' devices...
                                      Alexa / Google Home
                                      • M mvdarend
                                        I spoke too soon... the unit seems to work well, but I hadn't tested if the relay actually switched or not. The status seems to change fine in the serial monitor, but it doesn't seem to be actually switching. I'll have to do some more troubleshooting.
                                        shabba
                                        @mvdarend You discover your issue with the relay?
                                          m26872M
                                          m26872M
                                          m26872
                                          @rvendrame
                                          since we're discussing the PSU secondary side (output side), I think we already presume errors with the PSU. A fuse (over current protection) on the secondary is not just there as a back-up if the PSU internal over current protection fails. The fuse will also prevent your over voltage protection (zener, varistor, ...) from overload/burn/start a fire.
                                          The current from PSU to load will not pass through the zener and hence the rating is irrelevant from that perspective. In other applications where a zener is used as voltage regulator, the full load current will pass through the zener when in idleing and then the rating is critical.
                                          korttomaK 1 Reply Last reply
